Results 1 to 5 of 5
Thread: No reverse lights, charge light on voltmeter turns on when shifting to reverse
  1. #1
    Registered User
    Member ID
    CZCC-30550
    Join Date
    Jun 2014
    Location
    New Orleans
    Age
    40
    Posts
    2
    Default No reverse lights, charge light on voltmeter turns on when shifting to reverse
    Hi y'all,
    Sorry if this is a repeat, but I haven't been able to find an issue quite like this in the forums.
    I've got a '76 280z that I purchased with a 5 speed from a later car already installed. The reverse lights stopped working a few weeks ago, so I checked all the connections, replaced the switch, swapped bulbs, and I still get nothing. The strange thing is that when the car is running and I shift into reverse, or press the switch manually without it being installed, the red "charge" light in the voltmeter comes on. There is some voltage coming through at the sockets, but not a full 12 volts.
    All other lights and switches function perfectly, I've checked the FSM to insure that the wires I'm plugging into the switch are the right ones, and I know they're the same ones that came off the old switch because I removed the old one and installed the new one myself.
    Has anybody out there experienced anything like this? Any help at all would be greatly appreciated.
    Thanks!
  2. #2
    Low Budget/High Value
    Member ID
    CZCC-20342
    Join Date
    Oct 2009
    Location
    Washington County, OR
    Posts
    3,629
    Default
    Is the engine running when the charge light comes on? Or is everything off? The reverse switch just completes a circuit, allowing power to flow through the reverse lamps. Seems like you might have a short somewhere between the switch and the lights, maybe drawing enough current to overload the alternator at idle, or actually shorted through the Charge lamp wire.
    Attached Thumbnails Attached Thumbnails Click image for larger version.
Name:	1976 Page BE-16 Top.PNG
    1976 280Z, with some minor modifications
  3. #3
    Registered User
    Member ID
    CZCC-30550
    Join Date
    Jun 2014
    Location
    New Orleans
    Age
    40
    Posts
    2
    Default
    Charge light only comes on with the engine running, nothing happens if the ignition switch is set to On without the motor running.
    I'll try to trace the harness the rest of the way back and see if I can find a short.
    I've never been much good at electrical work. Any tips or common issues to look for while I'm poking around in there? If I've got to dive into it, I want to make sure I get everything done that I can while I'm in there.
    Thanks for the help!
  4. #4
    Registered User Kurbycar32's Avatar
    Member ID
    CZCC-23586
    Join Date
    Feb 2011
    Location
    Manteca, CA
    Posts
    337
    Default
    Quote Originally Posted by Nola280 View Post
    Use an actual voltmeter, not a test light. Don't use crimp or twist type electrical connectors, instead use solder and heat shrink whenever possible. When I did my 260z I opened every single connection cleaned with both electrical contact cleaner and a nylon brush and reassembled. Between that, cleaning every ground connection and replacing one bad wire that a PO installed to bypass my brake light circuit all of my gremlins went away. Action photos here:
    https://sites.google.com/a/thecomput...60z/electrical
    Early 1974 260z
    https://sites.google.com/a/thecomputerrehab.com/260z/
  5. #5
    Registered User JeffMopar's Avatar
    Member ID
    CZCC-3372
    Join Date
    Jan 2003
    Location
    Wallingford, CT. USA
    Posts
    90
    Default
    Hello All,
    Just a quick thought. Make sure your ground near the bulbs is clean and has a good connection. Having a bad ground shows as crazy syptoms when the power tries to find an alternate ground. Hope that helps.
    Jeff
    72 240Z, undergoing full restoration HLS30-73866
Thread Information
Users Browsing this Thread
There are currently 1 users browsing this thread. (0 members and 1 guests)
Similar Threads
  1. Reverse Lights
    By OniZ in forum Electrical (S30)
    Last Post: 03-27-2011, 04:44 AM
  2. reverse lights don't work
    By raltz in forum Help Me !!
    Last Post: 10-11-2010, 10:09 AM
  3. reverse light button?
    By driftmunky in forum Open Discussions
    Last Post: 05-03-2010, 02:58 AM
  4. reverse lights stay on all the time
    By angry_dave in forum Help Me !!
    Last Post: 12-04-2009, 10:56 AM
  5. Reverse light Sensor Help
    By xhricardo in forum Electrical (S30)
    Last Post: 04-14-2006, 10:54 PM
Tags for this Thread
Bookmarks
Bookmarks
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
