Results 1 to 6 of 6
Thread: Camber plates?
  1. #1
    Registered User
    Member ID
    CZCC-28990
    Join Date
    Feb 2013
    Location
    Brisbane
    Age
    40
    Posts
    186
    Default Camber plates?
    Going to be doing a bit of work on my white 77 240k soon. Got all the bits ready for the manual conversion and thought I would do some suspension work while I'm going. Picked up some low king springs a while ago but am thinking I will need to put in camber plates to keep it straight. Front looks to be well aligned at the moment with standard tyres and rims. The rear is running some big negative camber and I will be looking into that at the same time(maybe sagged springs?) but will be leaving the rear height standard if it looks ok once camber is corrected. So my question is regarding camber plates have you guys fitted any and if so which do you recommend. Have seen plenty on ebay but little specifically for 240k. Some universal for Nissan look good but quality and fit? Trying to stick to budget but any help appreciated. I don't drive the car much or very far and never putting it on the track
    Universal Camber Adjustment Plates Nissan Datsun 240Z 260Z 280Z 200sx 240sx | eBay
  2. #2
    ケンメリ 240k Style's Avatar
    Member ID
    CZCC-28810
    Join Date
    Dec 2012
    Location
    Melbourne
    Age
    36
    Posts
    533
    Default
    Mate DATSPORT make them I think as it's a common racing upgrade on 1600/510's to use 240K struts and brakes. My old man has a set in his 1600 using DATSPORT camber tops
    Adam
    1975 HGC110 "YONMERI" Datsun 240K GL Sedan
    1976 KHGC110 "KENMERI" Datsun 240K GL Coupe
    1978 MGC210 "Japan" Datsun 240K sedan (sold)
    http://japanesenostalgiccar.com/foru...hp?f=7&t=24596
    Contact Jason at info@jdmfactory.com.au for all your YJ / JDM needs !!
  3. #3
    Registered User
    Member ID
    CZCC-29592
    Join Date
    Sep 2013
    Location
    Perth
    Posts
    39
    Default
    Quote Originally Posted by 240k Style View Post
    But Datsport also want $560 for the pair, as opposed to the $150 these eBay ones will cost with postage. Yamaha Cam I looked into it (admittedly not too hard) and couldn't find any as cheap as those eBay ones previous. Keep this thread updated if you find something.
  4. #4
    Registered User
    Member ID
    CZCC-28990
    Join Date
    Feb 2013
    Location
    Brisbane
    Age
    40
    Posts
    186
    Default
    From what I can see the most important difference between the cheapest and dearest plates is the bush/bearing option. Cheapest is to have a bush to take rotational force from steering, then comes spherical bearing which is better than bush at load life and turning force(better for steering and life of component). Best of all is the thrust bearing which is great for load and steering forces. I have to weigh up my intended use vs cost/quality of components.Kmac also do one for 240k K-MAC Suspension Camber and Caster adjuster kits to suit Datsun
    Think for my intended use the spherical bearings will suffice? Ebay option looks ok but my only concern is the height at which my strut top will sit when installed. Could be higher or lower, I will have to have a look and a bit of a guess as it maybe different?
  5. #5
    Member ID
    CZCC-28810
    Join Date
    Dec 2012
    Location
    Melbourne
    Age
    36
    Posts
    533
    Default
    I'll eventually go DATSPORT option but my car will see track time so makes sense I suppose
    Adam
  6. #6
    Registered User
    Member ID
    CZCC-29592
    Join Date
    Sep 2013
    Location
    Perth
    Posts
    39
    Default
    I remember finding these on YaJ auctions
    Import Monster | View CUSCO GC110
    The part number is 226 410A, chase up a Cusco dealer near you and see if they can find something?
    Distributor Distributor English page CUSCO
Thread Information
Users Browsing this Thread
There are currently 1 users browsing this thread. (0 members and 1 guests)
Similar Threads
  1. weld-in camber plates?
    By timsz in forum Suspension and Steering (S30)
    Last Post: 07-20-2011, 07:39 AM
  2. Camber plates+ strut bar
    By i3rfnp3 in forum Suspension and Steering (S30)
    Last Post: 12-03-2006, 05:56 PM
  3. Camber Plates
    By hmsports in forum Open Racing Discussions
    Last Post: 07-20-2004, 08:33 PM
  4. camber plates?
    By hcb240z in forum Open Racing Discussions
    Last Post: 04-20-2004, 07:38 PM
  5. Adjustable Camber Plates ???
    By nixcars in forum Suspension and Steering (S30)
    Last Post: 07-01-2003, 05:54 AM
Bookmarks
Bookmarks
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
