Results 1 to 3 of 3
Thread: Recommended Spark Plugs with a PerTronix Ignition Kit with new coil
  1. #1
    Registered User
    Member ID
    CZCC-29967
    Join Date
    Dec 2013
    Location
    Panama
    Age
    43
    Posts
    157
    Default Recommended Spark Plugs with a PerTronix Ignition Kit with new coil
    What model of NGK spark plugs should i use if i haven an PerTronix Ignition Kit with new coil and electric fuel pump installed in my 1972 240z?
    Should i strive for NGK-R spark plugs?
  2. #2
    Semi-retired admin Arne's Avatar
    Member ID
    CZCC-8596
    Join Date
    Jun 2005
    Location
    Eugene, Oregon, USA
    Age
    63
    Posts
    8,465
    Default
    The only important part here is the coil. If your coil is hotter than stock, you can use the wide-gap version of the stock plugs. I ran BP6ES-11 with Pertronix and a Crane PS-20 coil.
    Arne - Former owner, HLS30-37705, 7/71, 905 Red
    Car blogs - 240Z - Porsche 911
  3. #3
    Registered User Jarvo2's Avatar
    Member ID
    CZCC-26781
    Join Date
    Mar 2012
    Location
    Plainfield, IL
    Age
    42
    Posts
    238
    Default
    I just upgraded to NGK (7133) BPR6ES-11 and have a Pertronix...I run much better now. Its more the spark plug gap than the plug in this case. The old points needed a smaller gap, where as the electronic ignition fires best with a wider gap.
    Dave
    Windy City Z Club (Chicago)
    1972 240z, restoration in progress
    http://jarvas240z.blogspot.com
Thread Information
Users Browsing this Thread
Similar Threads
  1. Spark before Pertronix and coil but not after. Help!!!
    By scaldwell1972 in forum Help Me !!
    Last Post: 05-08-2011, 04:38 PM
  2. Pertronix 1.5 vs 3.0 OHM coil and Tach
    By akorna in forum Electrical (S30)
    Last Post: 02-08-2010, 10:03 PM
  3. recommended plugs and dist. wires on my '75 280Z
    By shadesh in forum Engine and Drivetrain (S30)
    Last Post: 04-06-2008, 03:10 PM
  4. Ignition/distributor - no spark to plugs. Help!
    By ron32966 in forum Electrical (S30)
    Last Post: 01-14-2008, 02:51 PM
  5. ZX ignition/Stock Coil - Ballast = Dead Coil?
    By sideshowbob in forum Engine and Drivetrain (S30)
    Last Post: 08-20-2005, 07:44 AM
Bookmarks
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
