Results 1 to 7 of 7
Thread: E-88 head swapping
  1. #1
    Registered User Hunter260Z's Avatar
    Member ID
    CZCC-24528
    Join Date
    Jun 2011
    Location
    Timberlake, NC
    Posts
    207
    Default E-88 head swapping
    Trying to gain a few hp. I have aiready swapped the flat tops(carbs) out for round tops. Would like to go to a 72 E-88 head and a stock 260z cam or a stage 2 cam. Also change the exhaust manifold to a 72 or add a header.Also replace the timing chain. Hoping to gain about 15-20 hp.Is this possible.
    Ray
    1974 Datson 260Z
    RLS30-27748 Matching #'s
    L26 Stock w/72 Round Tops
    Interpart Front Spoiler
    Addco Front & Rear Sway Bars
    My Very First Car
    Purchased 5/23/1974
  2. #2
    Supporting Member Diseazd's Avatar
    Member ID
    CZCC-14126
    Join Date
    Mar 2007
    Location
    Richmond
    Posts
    1,852
    Default
    Use the early E88 head, install L28 valves and seats, then bore it out .040 inches, use an Isky Stage III cam and you should pick up 15 h.p. or even more.
    http://www.flickr.com/photos/1404980...7600346077563/
    ______________________________________________
    http://www.flickr.com/photos/1404980...7603350695459/
    70, 71, 2 72's, and a 73 240z....
    90 300zx and a 1996 Acura NSX.....but who's counting?
  3. #3
    Registered User
    Member ID
    CZCC-3609
    Join Date
    Feb 2003
    Location
    Clearwater,Florida USA
    Age
    74
    Posts
    4,424
    Default
    72 E88 - milled a few thousands to make sure it is straight/flat and increase compression slightly..
    L28 valves/seats
    Mild Port Matching {no need for polishing}
    Use the 72 exhaust manifold {headers only add heat/noise unless you do significant rework on the head, add cam's and free flowing exhaust - for that matter the free flowing exhaust will add more than the header}.
    Diseard's Cam
    70-72 SU's fine tuned [you can pick up about 3HP if you leave the air filer and cover off for track events}
    Electronic Ignition with good wires
    Most "stock" but good running L24's in the 240Z's will put down around 120HP at the rear wheels. So do a chassis dyno run before you start changing things. Then do another run after - that's the only way you will know if it was money well spent.
    Yes, 15HP at the rear wheels should be possible if the engine is property tuned..
    FWIW,
    Carl
    Oh.. BTW - if you change cam's and timing chain - make sure the cam timing is dialed in correctly. If you are having a shop do the work - ask to watch that process being done.
    Last edited by Carl Beck; 07-03-2014 at 05:08 PM. Reason: Added note about dialing in new cam timing
  4. #4
    Registered User madkaw's Avatar
    Member ID
    CZCC-7622
    Join Date
    Dec 2004
    Location
    bloomington IN
    Age
    56
    Posts
    2,288
    Default
    Tune - tune - tune
    Dyno before , then after like Carl said.
    I got 155rwhp from my L24 with SU's and all of Carls suggestions.
    Steve
    71 240z,bw-5sp 2.4-40 over,balanced,e-88,big valves,ported&polished, stage2,header, triple Mikuni's 40's
    3.90 Subaru STI LSD
  5. #5
    Low Budget/High Value
    Member ID
    CZCC-20342
    Join Date
    Oct 2009
    Location
    Washington County, OR
    Posts
    3,629
    Default
    Seems like an N42 or N47 L28 head would be a good choice. It already has the bigger valves and essentially the same combustion chamber size. Isn't it about where you end up after modifying the E88?
    1976 280Z, with some minor modifications
  6. #6
    Member ID
    CZCC-7622
    Join Date
    Dec 2004
    Location
    bloomington IN
    Age
    56
    Posts
    2,288
    Default
    I believe that depends on what e-88 head we are talking about.
    An early e88 with bigger valves will down around 41.5. The earlier head will not be a fully OPEN chamber like the 42 or 47 head.
    Steve
    3.90 Subaru STI LSD
  7. #7
    Registered User siteunseen's Avatar
    Member ID
    CZCC-24724
    Join Date
    Jul 2011
    Location
    Alabama
    Posts
    1,967
    Default
    I just wanted to write something so I'd get the green arrow. This is great!
    Mark Maras likes this.
    1972 240Z #918 New Sight Orange
    1977 280Z #305 Light Blue Metallic
    1972 240Z #110 Persimmons Red
Thread Information
Users Browsing this Thread
There are currently 1 users browsing this thread. (0 members and 1 guests)
Similar Threads
  1. Head, not sure if head gasket or head cracked at this stage.
    By restorerestore in forum Engine and Drivetrain (S30)
    Last Post: 04-18-2014, 11:27 AM
  2. Cam swapping What If?
    By coop in forum Engine and Drivetrain (S30)
    Last Post: 02-26-2011, 12:47 AM
  3. Swapping Out the AFM
    By TomoHawk in forum Fuel Injection (S30)
    Last Post: 11-11-2010, 03:20 PM
  4. Swapping 280 to a 240
    By SCCA_racer in forum Open Modification Discussions
    Last Post: 01-12-2004, 01:32 PM
  5. Head Swapping
    By Ed in forum Parts Swapping (S30)
    Last Post: 04-23-2003, 05:36 PM
Bookmarks
Bookmarks
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
