Results 1 to 53 of 53
Thread: Hardway's 1971 240z #8011 - Build and Repair Thread
  1. #1
    Registered User Hardway's Avatar
    Member ID
    CZCC-26208
    Join Date
    Jan 2012
    Location
    Austin TX
    Posts
    659
    Default Hardway's 1971 240z #8011 - Build and Repair Thread
    As described in my previous post I am now the proud owner of 1971 240z Series-1 #8011. The post can be seen here -> http://www.classiczcars.com/forums/o...0z-8011-a.html This is the most complete 240z I have owned and has been the recipient of a lot of time and money in regards to both parts and labor. However, it is not 100% and has plenty of room for me to add my personal touch and tinker with it as it needs things.
    One of the first items on the to-do list was to remove the over rider bar on the front bumper. The reason for this is because the hood was making contact with it and it was keeping the hood from opening all the way.
    After about 15 minutes of carefully remove the screws that held it in place I had the bar off. I have never been a fan of them anyway so I was happy to see it go. Now the hood opens like it is supposed to and I am on the hunt for some bumper guard strips.
    Now that the hood opens I wanted to change the oil, bleed the brakes, and possibly bleed the clutch. Before I could get to those items, the next item on the list unfortunately is a new radiator. I did not notice the two pin holes in the middle of the radiator core until I got it home and was taking pictures of the car. Only under the light of the camera flash did the shallow puddle of coolant in the lower radiator flange appear. A quick check with a bright flashlight confirmed it had been slowly leaking for quite some time. I do not knock the seller or myself for this because neither one of us saw it even when the car was on the rack at the seller’s shop. Cough it up to “comes with the territory”
    08/1970 240z Series-1 #8011 - Silver, black int., 2.4L I-6, 5spd, 90% restored.
    06/1973 VW Karmann Ghia - Black convertible, 4spd, 1600cc air-cooled engine.
    11/2013 Scion FR-S - Silver, 6spd, a car with the soul of a Z for the modern times.
    Restoration thread of my old '72 240z -> http://www.classiczcars.com/forums/o...1972-240z.html
  2. #2
    Member ID
    CZCC-26208
    Join Date
    Jan 2012
    Location
    Austin TX
    Posts
    659
    Default
    So like all cars that come in to my possession they seem to wind up on jack stands within a week of purchase. However, I am determined to never ever have this car off the road for more than a few days at a time. For now, on the jack stands it goes.
    The radiator came out with little drama. Once out and the electric fans removed I could see it had been repaired before, possibly several times.
    With the car off the ground and the radiator out it and allowed me to get a better look at everything. It is very satisfying to see this car has not seen a parking lot curb or other front end damage during its life time as everything appears to be very straight and true.
    I made plans to drop the radiator off at a local shop I have used in the past with good results.
    Next up was the brakes. Everything is pretty new on the car including the DOT 5 fluid in the brake reservoirs. After posting up some questions about keeping it flushing it I decided to keep it based on the advantages it offers for a regularly driven street car. I started with adjusting up the rear brakes as I could tell they were not correct when I pulled the wheels off. A few turns of the wheel cylinder adjustment screw had them providing the correct amount of drag on the drums. Since my wife was available to help me I made her comfortable in the driver seat and did a full bleed all the way around. Sure enough, there was a ton of air in the rear brake lines! Once removed and everything buttoned up the pedal was much firmer and confident in its operation. Job done!
  3. #3
    Member ID
    CZCC-26208
    Join Date
    Jan 2012
    Location
    Austin TX
    Posts
    659
    Default
    Next up was an oil change. The previous owner told me the car probably had less than 200 miles put on it in the last year or so but it had also been over a year since the last oil change. The oil still looked okay but it was time for it to go. I picked up a new Wix filter, a 5qt jug of Castrol GTX 10W-30, and a bottle of Risolene Zinc additive. I know everyone uses a different oil or additive but I have had good results with this setup so I am sticking with it. The oil drained with no issues but the filter was a different story.
    After using my trusty filter wrenches I quickly determined it was going nowhere and I was only damaging the filter in the process. This was pretty disappointing to run in to but again, it comes with the territory.
    So out comes the punch and drill. I used a series of bits to drill the hole big enough so my large screw driver could go through. I did not want to risk the screwdriver just tearing the top of the filter apart.
    I really thought one hole would get it done. Unfortunately it took two holes to give me enough range of motion to finally get the filter to spin off.
    Since the rubber seal was still stuck to the block once I got the filter off I can only guess that either A. someone forgot to oil the seal before putting it on or B. the oil had just disappeared due to time. For a quick comparison here is what the Penzoil filter looks like next to the Wix. The seal size is the same but as you can see the overall diameter is bigger on the Wix. Since the Wix is shorter than the Penzoil I am sure they hold about the same amount of oil.
    That was enough excitement for one weekend. Looking forward to the upcoming 3-day weekend!
  4. #4
    Member ID
    CZCC-26208
    Join Date
    Jan 2012
    Location
    Austin TX
    Posts
    659
    Default
    During the work week I heard back from the radiator shop and the news was not good. They could not repair the existing core and they wanted over $400 to re-core it. Their advice, just buy a new one. I found a Champion 3-row all aluminum radiator part# CC110 on Ebay for $215 shipped. The seller, Big Dog Performance was “Johnny on the spot” getting it shipped out. They were also wonderful to work with. Thank you Sue and Chuck! PLUG: If you need a Champion radiator for your Z they have the best prices and service. The radiator arrived safe and sound via FedEx on Thursday July 3rd. Below are the Christmas pictures showing how it arrived and unwrapping it. I must say my initial inspection revealed a high quality radiator that was well packed and well made. Being aluminum it was significantly lighter than the old brass radiator I pulled out.
    Installation was just the reverse of taking the old one out. One change I made was going back to the stock style mechanical fan. The electric fans I removed were triggered by a temp probe that had to be pushed all the way through the radiator core. I could not bring myself to start bending up the fins on a brand new radiator for the probe. The mechanical clutched fan is an extra I got with another car a few years ago. It was in good shape but I will eventually buy a new one along with an MSA shroud to match the rest of the near pristine engine bay.
  5. #5
    Member ID
    CZCC-26208
    Join Date
    Jan 2012
    Location
    Austin TX
    Posts
    659
    Default
    Since I had the car on jack stands this was going to be the best time to replace the rear hatch strut as it would allow me to work on it without bending over. The strut on the car looks to be the original. Since the car included a wooden stick in the hatch area it appears to have been out of service for a long time.
    I picked up a Stabilus SG 225005 off Ebay for $40 shipped. This came at the recommendation of Blue in a post from a few years ago regarding another source for hatch struts. As you can see the new strut on the right is just a hair longer than the original.
    It took a little time to get the upper bracket off the old strut. A cut off wheel and a few hits with a punch cleared the pin enough to remove the bracket.
    The instructions did not say what order to install the bolts and spacers so I did what seemed logical to me. I also replaced the upper 10mm bolts with some new ones as the rear most bolt’s threads did not look good. Fortunately the threads in the hatch were still in good shape. The end result is a hatch lid that securely stays up on its own. It also provides a large enough opening so you are not hitting your head on the hatch lid while loading stuff in to it.
  6. #6
    Member ID
    CZCC-26208
    Join Date
    Jan 2012
    Location
    Austin TX
    Posts
    659
    Default
    With so many things accomplished I figured a celebratory drive was in order. A quick trip around the neighborhood reminded just how hard the tires were as well as mildly flat spotted. The tires on the car were some Pirelli P44 205-70-14 that were from the late 70’s or early 80’s according to the seller. These are apparently popular with the vintage Mercedes crowd but on the Z they looked almost truck like. They also rubbed pretty bad when turning sharply so they had to go.
    I jumped online and determined a 195-60-14 would be more appropriate. Discount Tire carries Barum tires which is part of the Continental tire family. Their model, the Bravuris 2 seemed to have good reviews amongst enthusiasts around the net and were priced right at $55/ea. They had a 4th of July special going that included $50 off if you made the appointment to buy on July 4th. I performed the appropriate clicks and set an appointment for 10am the next morning.
    When I arrived at the tire shop in the morning I checked out the tire to make sure it was what I wanted. I knew just by looking at it that it would not fill up the wheel well as much but also should have no chance of rubbing. Plus, the tread pattern looked good so I gave it the thumbs up. A swipe of the credit card authorizing $258.60 and 45 minutes later I was back on the road with fresh rubber. The short drive home revealed just how bad the old tires were and that I had made the right choice. The car steered easier, tracked better, and just rode nice. While I don’t love the way it looks right now once the suspension settles a little more in the front I think it will look better.
    That is all for now. I am still working to source one or two fuel door knobs/locks and debating if I want to put my Datsun script emblem on the hatch. I am on the fence about this as I know when I go to remove it the pins will most likely break off and I will have to source another one or apply it with emblem tape.
  7. #7
    It's awesome bartsscooterservice's Avatar
    Member ID
    CZCC-28929
    Join Date
    Jan 2013
    Location
    Gendt, The Netherlands
    Age
    32
    Posts
    857
    Default
    Looking good !
    HLS30 32581, 5/71 Matching numbers
    Jay Leno : You know one week after the Americans have walked on the moon, the Japanese introduced this sports car, and…if you’re a car guy pretty equal. I mean walking on the moon was pretty good, but how many times you’d gonna walk on the moon? But here was an affordable sports car that had real performance and looked like it cost a lot more than it did.
  8. #8
    Supporting Member Zedyone_kenobi's Avatar
    Member ID
    CZCC-16285
    Join Date
    Mar 2008
    Location
    Houston
    Age
    46
    Posts
    2,919
    Default
    You sir are a man after my own heart. VERY nice work
    A word of advice though. You just put an aluminum Radiator on a metal frame car. You will want to put some sort of rubber in between the radiator and the metal frame to prevent galvanic corrosion due to the dissimilar metals. It may save you some headaches in the future. Your car is a thing to behold. I wish my 71 had as clean a background as yours did. But we all get to a point where we bond with the car. You are well on your way to 'making it yours'.
    Keep the pics and updates coming buddy.
    1971 240Z HLS30-38691
    93.9% done and getting better every day
    Now with 100% more DATSUN SPIRIT L28 Power
    1968 Datsun 2000 SRL311-03416
  9. #9
    Member ID
    CZCC-26208
    Join Date
    Jan 2012
    Location
    Austin TX
    Posts
    659
    Default
    Thanks for the compliments guys! You are spot on with your assessment and recommendation Zed. I just placed an order for a MSA fiberglass fan shroud and I just received my new fan clutch. When I take everything off to swap it I will pull the radiator away from the core support and insulate it with some foam tape and grommets around the holes. I was in a bit of a hurry to do the radiator swap over the weekend as I had friends coming in to town that wanted to see and go for a ride in the Z. They all agreed this is the best one I have owned was bought well. I am even drove it to work to today so I could take it to my locksmith to ensure the extra keys they made fit the cylinders properly.
  10. #10
    Registered User Mike W's Avatar
    Member ID
    CZCC-19584
    Join Date
    Jun 2009
    Location
    Austin, TX
    Posts
    243
    Default
    Jeff,
    I played around with a number of different solutions for isolating the radiator from the frame. Zedy is 100% correct that dissimilar metals can cause unwanted corrosion so it is important that you do this at some point.
    In any case, what I found worked best for me were some rubber grommets that I purchased from McMaster Carr. I had to purchase a bag of 50 or so, so I have plenty of them left over and would be happy to offer you a few for your Z. I also have all of the correct hardware to go along with the grommets.
    Just give me a shout and I'd be happy to provide you what you need for a proper mount.
    Mike.
  11. #11
    Nova Scotia,Canada,Earth Blue's Avatar
    Member ID
    CZCC-7641
    Join Date
    Jan 2005
    Location
    NS
    Posts
    4,085
    Default
    Using grommets for shock & vibration isolation helps with the rad welds/brazing too.
    There is scarcely anything in the world that some man cannot make a little worse, and sell a little more cheaply.
    The person who buys on price alone is this man's lawful prey.
    John Ruskin (1819 - 1900)
    ZCars in Eastern Canada seaport ready for shipment to Europe
    http://ZSportCanada.com
  12. #12
    Member ID
    CZCC-26208
    Join Date
    Jan 2012
    Location
    Austin TX
    Posts
    659
    Default
    You guys are right and I will be addressing this sooner than later. I actually picked up some grommets tonight that are a thick rubber which I think will work perfectly. I appreciate the offer Mike and will let you know if what I bought does not work out.
  13. #13
    HLS30A 17574 djwarner's Avatar
    Member ID
    CZCC-27817
    Join Date
    Aug 2012
    Location
    Central FLorida
    Posts
    405
    Default
    In case you guys have forgotten, our aluminum heads sit on an iron block. Talk about dissimilar metal corrosion. An alternative solution (pun intended) is to use waterless coolant. Jay Leno's garage had a video on it. I began using it after installing an aluminum radiator.
    I've been using it for more than a year including high speed cruising in 92+ degree days with no problems.
    1971 240Z HLS30A 17574 L24-021025
  14. #14
    Supporting Member Diseazd's Avatar
    Member ID
    CZCC-14126
    Join Date
    Mar 2007
    Location
    Richmond
    Posts
    1,852
    Default
    ........I always use distilled water with anti freeze......no minerals and metals to feed electrolysis.
    http://www.flickr.com/photos/1404980...7600346077563/
    ______________________________________________
    http://www.flickr.com/photos/1404980...7603350695459/
    70, 71, 2 72's, and a 73 240z....
    90 300zx and a 1996 Acura NSX.....but who's counting?
  15. #15
    Member ID
    CZCC-7641
    Join Date
    Jan 2005
    Location
    NS
    Posts
    4,085
    Default
    I think some of you Texans are cornering the Silver Z market.
  16. #16
    Registered User LeonV's Avatar
    Member ID
    CZCC-19146
    Join Date
    Apr 2009
    Location
    Bay Area, CA
    Posts
    1,961
    Default
    Quote Originally Posted by djwarner View Post
    With a gasket in between...
    Also, "regular" antifreeze performs the same function, regarding corrosion. Waterless Coolant isn't anything magic, it's just a brand name.
    2/74 260Z
  17. #17
    Member ID
    CZCC-27817
    Join Date
    Aug 2012
    Location
    Central FLorida
    Posts
    405
    Default
    LeonV, the gasket doesn't make any difference when current can flow through the head bolts. Here is the link, Ya pays ya money and ya takes ya choice.
  18. #18
    Member ID
    CZCC-19146
    Join Date
    Apr 2009
    Location
    Bay Area, CA
    Posts
    1,961
    Default
    I don't need marketing propaganda to make my decisions, thanks. This topic has already been discussed, if not here then on HybridZ, MSDS and all. A properly maintained cooling system will not corrode. I've examined enough L-series blocks and heads (among others) to see the effects of neglecting your cooling system, as well as maintaining it. Believe me, I know very well that theoretical stuff is fun to talk about but it helps to have a glimpse of reality when doing so.
    Anyway, I don't want to derail this thread any further. There are some good points made in this thread (post #21 shares my sentiments, among others): http://www.ffcars.com/forums/17-fact...s-coolant.html
    2/74 260Z
  19. #19
    Member ID
    CZCC-26208
    Join Date
    Jan 2012
    Location
    Austin TX
    Posts
    659
    Default
    Over the past few weekends I have had some time to work on the Z but unfortunately no time to post any updates. With a free Tuesday night on my hands I wanted to let you guys know what I have been up to. First and foremost, to everyone’s relief I addressed the issue of the aluminum radiator being bolted directly to the car. I knew there no shortage of options out there as many owners have used strip of rubber to various grommets and other things to use as a spacer. Knowing I did not want to use anything with adhesive on it I knew using a piece of foam rubber weather stripping was out. I then turned my focus to using some sort of grommet and then it hit me. I remembered when I repaired the toilet in one of our bathrooms that the bolt kit included some rubber reinforced washers. I figured the size should be pretty close to the size of the bolts holding on the radiator. A quick stroll down the plumbing aisle at Home Depot revealed the perfect parts kit. At $1.62 per kit I bought two so I had a total of 8 rubber washers. Each kit comes with everything you see and take note that 2 of the washers are slightly thicker than the other 2.
    After about 20 minutes of working on it all the washers/spacers were installed. The fit snug around the bolts but not so tight that they were pain to install. For less than $5 my problem was solved and the best part it is nothing permanently attached to the vehicle.
    With the radiator wrapped up I turned my attention to installing my new fan clutch. With the fan off I installed some new water pump studs along with a dab of thread locker on each. The studs are part of a Dorman water pump stud pack and included all 4 studs, lock washers, and nuts.
    The fan clutch swap took just a few minutes. The difference between how tight the new clutch is compared to the old one was night and day.
    A few minutes with my 10mm box wrench and the fan was back on. With the spacers installed it brings the radiator closer to the fan. I did not have any issues installing it and based on how close it is I am going to run without a shroud and see how things look.
    I drove out to the local Cars and Coffee meet the next day after doing this work. Between plenty of toll-way driving at 75mph and stop & go driving the needle never reached the half way mark. Job done!
  20. #20
    Member ID
    CZCC-26208
    Join Date
    Jan 2012
    Location
    Austin TX
    Posts
    659
    Default
    One of the great things about older cars is the opportunities they present in bringing parts back to life. One such part for my car is the Datsun script emblem that goes on the hatch. I did a refurb job on a used emblem I got off of Ebay. It came out so well I decided to post a thread about it here -> http://www.classiczcars.com/forums/b...tml#post460651
  21. #21
    Registered User EhlersRS's Avatar
    Member ID
    CZCC-21096
    Join Date
    Mar 2010
    Location
    Cedar Rapids, IA
    Age
    44
    Posts
    228
    Default
    Jeff,
    Your car looks great! I had the same issue with the oil filter on my car, but the filter sat on the car for +20 years from the last oil change in 1989! At first I tried the big screwdriver punched through the filter, but that wasn't enough torque, so I had to use an old metal rod to break it loose. In the end the filter was mangled, but I got it off!
    Keep up the good work!
    Robert S.
    1971 240Z HLS30-21244
  22. #22
    Registered User 73str86's Avatar
    Member ID
    CZCC-25856
    Join Date
    Dec 2011
    Location
    Augusta, Georgia, United States
    Posts
    79
    Default
    Belated congrats for the new Z. I followed your other thread, and still look at it for my gradual rebuilt rear drivetrain install.
    Question about your 240z tint strip on the windshield. Is it applied to the inside or outside of your windshield? I found a N.O.S. one on eBay a year or two ago, and tried applying it to the inside. Maybe it was because it was a 30 year old piece of film, or my lack of skills, but I failed miserably and gave up. Recently a gentleman told me tint strips are applied to the outside. Figured I'd ask.
    http://www.hookit.com/members/triingsoldier/
  23. #23
    Registered User Hunter260Z's Avatar
    Member ID
    CZCC-24528
    Join Date
    Jun 2011
    Location
    Timberlake, NC
    Posts
    207
    Default
    Back in 1976 mine went on the inside. Now they could go on the outside, I don't know. It would be a pain in the butt to clean the windshield if it was on the outside.
    Ray
    1974 Datson 260Z
    RLS30-27748 Matching #'s
    L26 Stock w/72 Round Tops
    Interpart Front Spoiler
    Addco Front & Rear Sway Bars
    My Very First Car
    Purchased 5/23/1974
  24. #24
    Member ID
    CZCC-26208
    Join Date
    Jan 2012
    Location
    Austin TX
    Posts
    659
    Default
    The 240-Z strip across the windshield is on the inside. It was put on by the original owner per my conversation with him. The second owner attempted to scrap it off at some point on the passenger side but it appeared to be coming off in little pieces so he gave up. I am honestly not a big fan of it but I am leaving it alone for now and will remove when the windshield is pulled for paint later down the road.
  25. #25
    Member ID
    CZCC-26208
    Join Date
    Jan 2012
    Location
    Austin TX
    Posts
    659
    Default
    With the mornings being a little cooler in the Austin I decided to work on replacing the non-functioning Pioneer 8-track that came in my 240z. I already picked up a replacement heater control panel off of the Datsun Parts for Sale Facebook page. The one in the car was in very sad shape and probably not restore-able.
    I knew I was in for a treat when I saw pieces of wood holding up the 8-track unit.
    Based on the helpful how-to threads here on the site I got the panel pulled out to access the wiring. To do so I needed to get to all the control cables which mean getting around the blower motor housing. However with the ARA A/C box in the car this was impossible. Out came the glove box liner that was on its last leg and then the ARA box. It was strange to see a coat hanger snaked around the back of the dash as if it was helping hold up the ARA box.
    A wiring connections and things to fiddle with and she finally came out.
    It was at this point I was reminded of how sketchy the wiring is on this car and knew this was the time to address. My car has the typical parking light circuit burn hole which now serves as a routing point for an in-line fused wire that replaces it. In addition a blown fuse has been circumvented with a piece of wire wrapped around it. This entire cluster will be addressed but I am still trying to decide which direction to go. New fuse box from MSA for $200 or possibly put something together myself for less?
    With the heater panel components disassembled and cleaned using my Shop-Vac with a brush attachment I inspected the control lever assembly. As expected it was dry as a bone and one of the cables on the bottom was distorted while the other was missing entirely. I will be sourcing new cables as these are very rough.
    Setting the control levers aside and adding to the parts list I took some time to inspect the blower motor. A quick 12 volts to the primary wires proved the motor worked but being 40 years old it drew a lot of amps to run. With everything on the bench now is the time to do the Honda blower motor upgrade. I will be sourcing these parts over the next few days as well as cleaning up the box and giving it some fresh paint. For now, it was nice to get rid of all the nasty oily foam and the expanding foam. Within a few minutes it was much nicer to look at and handle.
    That is all for now. Time to do some more parts research and shopping!
  26. #26
    Registered User CanTechZ's Avatar
    Member ID
    CZCC-8626
    Join Date
    Jun 2005
    Location
    Chilliwack, BC
    Age
    59
    Posts
    101
    Default
    Quote Originally Posted by Hardway View Post
    I noticed that there are two brackets, outside of the horns, on your lower rad support. Did a PO add these for fog lights? I ask because a PO of my car must have added these strange brackets to mine which I can only guess were used to hang lights from, they look like they are shelf brackets from a hardware store. I do plan to remove them.
    Mike
    Click image for larger version.
    '70 240Z - (HLS30-06521) restoring stock, owned since '78
    http://www.classiczcars.com/photopos...r=8626&cat=500
    '13 Audi A5 S-Line
    '04 GMC Sierra SLT Quad Cab
    '88 Suzuki Samurai - SPOA, 1.6L EFI, 31" Mud Kings, 5:13's, Custom Bush Bar, CRX Seats.
    '91 Suzuki Samurai - 2" Body Lift, Smittybilt Bumper, Warn 6000, Prelude Seats. - Sold
    '80 Suzuki LJ80 project - Sold
  27. #27
    Member ID
    CZCC-26208
    Join Date
    Jan 2012
    Location
    Austin TX
    Posts
    659
    Default
    Good eye Mike! To be honest, I don't know what the brackets are for. They do appear to be factory mounts as they look to be factory spot welds. Just glancing at them I wonder if the horns are actually supposed to be mounted on them since they have threaded holes. I am sure others will chime in but if needed I can take some more pictures of them this evening.
  28. #28
    Member ID
    CZCC-8626
    Join Date
    Jun 2005
    Location
    Chilliwack, BC
    Age
    59
    Posts
    101
    Default
    I also thought the brackets on your car were very stock looking, especially compared to the obvious add on ones on my car. This was just a question out of curiosity, as I have not seen brackets like yours before.
    '13 Audi A5 S-Line
  29. #29
    Rust Free'ish zKars's Avatar
    Member ID
    CZCC-12190
    Join Date
    Jul 2006
    Location
    Calgary, AB Canada
    Posts
    1,256
    Default
    Wow, another "I ain't not never seed nuttin' like that b'for" moment. I'd swear those were factory looking spot welds holding them brackets. No average anybody would use welds like that to add brackets like that.
    Even the captured nut in the center looks factory. If its a square nut tacked on its four corners, that would just about settle it.
    Please, some worthy Z historian chime in and tell us "yup, seen those a thousand times on Z's from...." or the like and put us out of our questioning misery!
    And CanTechZ, I just love your brackets too. Some real engineering there with those interlinked springs. Vibration dampers??
    Jim
    73 240Z HLS30 149331
    69 510 PL510 77603
    www.zKars.com
    www.calgaryzclub.ca
    Reference materials
    www.xenonS30.com
  30. #30
    Member ID
    CZCC-7641
    Join Date
    Jan 2005
    Location
    NS
    Posts
    4,085
    Default
    Hi Jim,
    They are on VIN S30-00002
    I check all of my other photos of early vins and they are not on any HLS30 photos I have including HLS30-00013
  31. #31
    Member ID
    CZCC-21096
    Join Date
    Mar 2010
    Location
    Cedar Rapids, IA
    Age
    44
    Posts
    228
    Default
    Jeff,
    I've been folllowing the progress of your new Z and appreciate the level of detail you've put into the improvements! I bought a Series I ash tray from the same place as your heater control panel. Originally they didn't want to ship parts, but seeing your response on Facebook prompted me to inquire about shipping again. Thankfully they were able to send me a nice ash tray and I can finally stop looking for a replacement.
    Keep up the great work!
    Robert S.
  32. #32
    Member ID
    CZCC-26208
    Join Date
    Jan 2012
    Location
    Austin TX
    Posts
    659
    Default
    Thank you for the compliments EhlersRS! Yeah, I was really happy Shane was willing to ship some of the smaller parts. The ability to get parts outside of Ebay from other states at very fair prices is definitely providing support for the classic Z community.
    I must admit, the mysterious front brackets have me intrigued. I looked in my ’71 FSM and there are no pictures or mention of the brackets anywhere. I am sure there is a reasonable explanation for them and I would love to hear it. For now, here are some more pictures of the brackets.
    And one from under the car even though the valance panel is covering 95% of it.
  33. #33
    Member ID
    CZCC-7641
    Join Date
    Jan 2005
    Location
    NS
    Posts
    4,085
    Default
    This non-series one has them too
  34. #34
    Member ID
    CZCC-28929
    Join Date
    Jan 2013
    Location
    Age
    32
    Posts
    857
    Default
    Checked other pictures on google and most early 240z's don't have them. It could be a factory thing, but what did they want to mount to them ?
  35. #35
    Registered User
    Member ID
    CZCC-30784
    Join Date
    Sep 2014
    Location
    Scottsdale, AZ
    Age
    60
    Posts
    3
    Default
    Blue, what does that mean, 'non-series' ?
    Rob
    1972 240Z - Stock L24, SU's, 5spd, 4.11
    Scottsdale, AZ
    Big on potential
  36. #36
    Member ID
    CZCC-7641
    Join Date
    Jan 2005
    Location
    NS
    Posts
    4,085
    Default
    Quote Originally Posted by Rob1972 View Post
    Hi Rob,
    Series 1 is a slang term for grouping the first North American HLS30 models made between Oct 69 and Jan 71. The typical way to identify a car in the group is to look for the hatch vents that were later replaced by B pillar vents ~February 71.
    note: there were many changes between 69 and 71 so there are differences in the Series 1 group. The north american 240z's production continued into 73.
  37. #37
    Member ID
    CZCC-7641
    Join Date
    Jan 2005
    Location
    NS
    Posts
    4,085
    Default
    The metal pockets (also on the front of the lower rad support) on the passenger side (right of the right (passenger) bracket) look interesting as well.
  38. #38
    Member ID
    CZCC-26208
    Join Date
    Jan 2012
    Location
    Austin TX
    Posts
    659
    Default
    Good eye Blue! I have never noticed those until you pointed them out. I posted this topic up on the Datsun 240z Lovers FB site and a member thought the brackets could possibly be for mounting a G-Nose. We know they are factory brackets based on the spot welds and the fact other cars have them too. So far the possibility of them being for installing a G-Nose seems the most plausible so far. In regards to the small pocket on the passenger side, its hard to tell if other cars have these or nor and if they are related to the mysterious brackets.
  39. #39
    Registered User
    Member ID
    CZCC-30784
    Join Date
    Sep 2014
    Location
    Scottsdale, AZ
    Age
    60
    Posts
    3
    Default
    Thanks Blue, I know about Series 1 and their identifiers, but you said 'non-series' ?
    Rob
    Scottsdale, AZ
    Big on potential
  40. #40
    Registered User
    Member ID
    CZCC-30784
    Join Date
    Sep 2014
    Location
    Scottsdale, AZ
    Age
    60
    Posts
    3
    Default
    I'll check my fairly original 72 this weekend for mystery brackets.
    Rob
    Scottsdale, AZ
    Big on potential
  41. #41
    Member ID
    CZCC-7641
    Join Date
    Jan 2005
    Location
    NS
    Posts
    4,085
    Default
    I guess I should have used a numeral or hyphenated further. The "non-series one" above is a bit awkward
    Hi Jeff,
    Yes I thought G-Nose too as they seem to be on later VIN Z's.
    I was looking for 432 and ZG pics but I can't seem to spot these brackets.
  42. #42
    Member ID
    CZCC-8626
    Join Date
    Jun 2005
    Location
    Chilliwack, BC
    Age
    59
    Posts
    101
    Default
    Quote Originally Posted by zKars View Post
    Thanks, I can't take credit for the design as a PO "engineered" them. I will soon be removing and repurposing them........
Name:	shelf bracket.jpg
    Mike
    '13 Audi A5 S-Line
  43. #43
    Member ID
    CZCC-8626
    Join Date
    Jun 2005
    Location
    Chilliwack, BC
    Age
    59
    Posts
    101
    Default
    Mystery bracket update. I was doing a search for NOS frame rails and this Ebay auction popped up, the rails are a set with the lower front cross member and it has the mystery brackets and the pockets as well:
    1970 1973 Datsun 240Z Frame Rails | eBay
    There's only a few hours left so here's a couple of pics from the add
Name:	240Z frame rail-1s.jpg
ID:	74706Click image for larger version.
Name:	240Z frame rail-4s.jpg
    You never no what will show up on Ebay.
    Mike
    '13 Audi A5 S-Line
  44. #44
    Registered User
    Member ID
    CZCC-30484
    Join Date
    May 2014
    Location
    Ocean Springs, MS
    Posts
    9
    Default
    Interesting, I would not have thought those were replaceable. Sold for 745 dollars.
    1974 260Z
    Gary
  45. #45
    Registered User
    Member ID
    CZCC-23125
    Join Date
    Dec 2010
    Location
    Spartanburg, SC
    Age
    50
    Posts
    468
    Default
    Yes, absolutely replaceable but for the most part I believe NOS rails are unavailable as far as I know. Lots of work and you would really want to do it on a frame rack to make it easier and straight. Lots of spot welds to cut out and reweld. Several hundred I would think and you would have to take a lot of the interior out of floor boards to deal with the heat from rewelding. It would have to be a very special car for me to be willing to do all the work. I have done welding projects half this ambitious and have learned I hate cutting spot welds!
    Charles
  46. #46
    Member ID
    CZCC-26208
    Join Date
    Jan 2012
    Location
    Austin TX
    Posts
    659
    Default
    I am finally back with an update. It has taken me awhile to get back due to some professional changes and challenges in my life. It is good to see the conversation around the brackets has continued. Who would have thought some NOS frame rails would show up on Ebay! Neat to see that the NOS pieces have the brackets on them. What brackets are really for, we may never know.
    A lot of this work was done over the course of several weekends, usually just spending a few hours each day working on it. After a conversation in a thread over in the Electrical section on what route to go with the fuse box I ordered a new upgraded fuse box from MSA. At the same time I ordered one of Dave’s parking light harnesses, corner light flasher conversion, and I already had the headlight harness from when I owned my previous 240z.
    The new fuse box from MSA is a high quality piece. Even at $200 it is still a good deal as it is pretty much a plug and play affair
    Back when I removed the old fuse box I was immediately drawn to the black around the sheaths for the two primary power wires going to the box. It is obvious they have seen some heat during their life and this will need to be addressed.
    The terminals in the sheaths are where the large flat spade connectors go to.
    The new fuse box is 95% plug and play and the new box offers 10ga crimp connectors to cut and transplant your old fuse box power connectors to the new one.
  47. #47
    Member ID
    CZCC-26208
    Join Date
    Jan 2012
    Location
    Austin TX
    Posts
    659
    Default
    Knowing I did not want to reuse my old connectors I did some research and found new female connectors are available but new sheaths in the proper size was not. Another reason I did not want to reuse anything from the old box was the age of the wire itself. Over time copper wire corrodes by nature. After 40+ years the wiring for the Z’s fuse box was no different. The copper itself has become green and oily to the touch. The insulation was also a little brittle but one could clearly see the green residue from the corrosion. All of this creates resistance thus creating heat.
    NOTE: Keep in mind that all the wiring in the car probably looks like the pictures above. This is why it is so important to take as much load off the original wiring harness as possible. This can be accomplished by installing the various relay harnesses shown above and is exactly why I am doing it now.
    I located some new crimp on 12-10ga female spade connectors at Auto Zone. I installed a few inches of yellow 10ga wire and crimped it in to the connectors on the new fuse box. At the other end I crimped the new female connectors. With the new box installed I connected everything. It takes a little work as the new fuse box harness curves in the wrong direction. Since I did not have sheaths for the power wires I double heat shrink wrapped them for protection. This way if I ever need to service or disconnect the fuse box I only have to sacrifice a few cents worth of shrink wrap.
  48. #48
    Member ID
    CZCC-26208
    Join Date
    Jan 2012
    Location
    Austin TX
    Posts
    659
    Default
    With the new fuse box installed and tested I finished the installation of the headlight relay harness as well as the parking light harness. There is not anything to show but I will say that just like the MSA fuse box they are high quality components. All Z owners should look in to installed them as each one only takes about 20 minutes to install. For the headlight harness I mounted is relays using a hole that originally held the voltage regulator for the alternator.
    With all of the pre-radio electrical work done I turned my attention back to the blower motor and heating system. With my “while I am at it-itis” in full effect I decided now was the time to upgrade to a Honda blower motor. The blower motor in the car worked but was very heavy, had a metal cage fan, and probably drew more power than a new unit. I was lucky to find a complete blower housing out of a Honda Civic on Ebay for $50 shipped.
    I tested the blower motor and it was good so I removed it and masked off for painting. Definitely not one of my finest masking job but it accomplished the goal none the less.
    With that done I went back to the Z’s blower motor housing. Once it was disassembled I started cleaning it off only to discover 2 holes had been drilled in the bottom of it. I am not sure what they could have been for as the ARA A/C box did not utilize them.
    So with a body shaping hammer and anvil I went about working the area back down while being careful not to hammer too deep and losing the curve of the housing.
    After that a couple of zaps with my MIG welder filled the holes and I flattened them with an air powered abrasive disc.
  49. #49
    Member ID
    CZCC-26208
    Join Date
    Jan 2012
    Location
    Austin TX
    Posts
    659
    Default
    With the holes filled I went about removing the rest of the old paint and surface rust. Once clean I laid down a few light coats of Rustoleum satin black.
    Unfortunately the paint did not setup properly as various imperfections made themselves known. Since this side would be facing visible to passengers I wanted to make sure it was right. I took scuffing pad to flatten and remove the paint. After another clean up I tried again and it came out much better.
    While the paint was drying I cleaned up and resealed the vent assembly that sits on the back of the motor housing. I chose not to fully disassemble and paint this since it would have been very labor intensive and 99% of it is hidden behind the blower housing. It was still in good shape so it was best left alone. The new seals will help insure it functions properly for years to come.
    Now that the blower housing was dry and looking good it was time to install the Honda blower motor. The gold cad screws that came with the Honda unit was course threaded and could not be used. The original screws that were in the housing were in sad shape so I sourced the replacements below from Home Depot along with some rubber insulated washers. I could have used regular flat washers as I have a million of them but these seem to fit the best.
    I reassembled the blower motor box and wired up the new motor. Again, everything is serviceable and no original connectors were cut or altered. I think the end result is quite nice!
  50. #50
    Member ID
    CZCC-26208
    Join Date
    Jan 2012
    Location
    Austin TX
    Posts
    659
    Default
    I wanted to do a trial fit of the blower motor assembly to ensure the top cowl seal was the correct thickness. Before I could this I discovered the mounting holes has been a little chewed up, probably by whoever messed with the A/C before and sprayed foam fill everywhere. No worries as a few minutes with a tap and some oil cleaned everything up.
    A quick test mount showed everything was good so I moved back to the heater panel and cables. Since my cables were not in good shape I sourced a used set on Ebay. They were exactly what I needed and cost me $40 shipped.
    I picked up a used dash HVAC panel off the Datsun parts Facebook page. It was pricey at $110 shipped but seeing that new ones are $300 and my old one was toast it was a good deal. It is in very good condition and had already been cut for a modern stereo. I chose to hold off on touching it up until it was installed.
    Then I went about the task of reinstalling everything on to the back of the panel. Before I installed the control lever assembly I cleaned and re-greased the lever pivot points. This should help to provide years of smooth action.
    I carefully went about the process of reinstalling it the panel in the car, connecting the fan speed motor, and hooking up all the control cables. The blower motor assembly was reinstalled for the final time and everything hooked up to it.
  51. #51
    Member ID
    CZCC-26208
    Join Date
    Jan 2012
    Location
    Austin TX
    Posts
    659
    Default
    After all that was done I finished wiring up the new stereo. It is an Alpine CDE-143BT. I had installed a model very similar to this in another car and really liked it. Given all the features it has plus Alpine’s high quality I think it is the best value in car stereos.
    I ran the mic over to the driver side visor. It is just clipped on and nothing was cut or altered to install it.
    For right now I am using 2 Pioneer 6x9’s from a previous stereo installation project. The boxes are from Custom Sounds and ran $30. It is not the highest quality speaker setup but they get the job done for now. Down the road I will install some kick panel speakers and re-locate the rear speakers to they are not so visible.
    That is all for now. Due to my current budget limitations and the peak driving season upon us in Texas I have no more plans at this time. 2015 will be the next time any projects are undertaken on the Z. For now, it’s time to get out and enjoy it.
  52. #52
    Registered User grannyknot's Avatar
    Member ID
    CZCC-26437
    Join Date
    Feb 2012
    Location
    Toronto
    Posts
    698
    Default
    Great job on the blower box, isn't that fun connecting up those 4 hard wire/cables?
    I've done that job 3 times now and hope I never have to do it again.
    You'll like the Honda blower, I found it moved about 2x as much air as the old blower.
    Chris
    1970 240Z HLS30 01955 March/70
  53. #53
    Member ID
    CZCC-7641
    Join Date
    Jan 2005
    Location
    NS
    Posts
    4,085
    Default
    I like seeing you use the tap set young grasshopper
Thread Information
Users Browsing this Thread
There are currently 1 users browsing this thread. (0 members and 1 guests)
Similar Threads
  1. It's Mine! - New Owner of 1971 240z #8011
    By Hardway in forum Open S30 Z Discussions
    Last Post: 06-26-2014, 08:13 PM
  2. #00655 Build Thread
    By theczechone in forum Check Out My Ride
    Last Post: 03-13-2013, 10:22 AM
  3. 240Z Build Thread
    By Prowler in forum Open S30 Z Discussions
    Last Post: 03-27-2010, 11:49 PM
  4. 1971 240z hatch repair PICs need help!
    By wickiewicked in forum Body and Paint (S30)
    Last Post: 07-30-2006, 01:30 AM
  5. a z build thread for me
    By vipv35 in forum Introductions and Z Stories
    Last Post: 05-31-2006, 05:28 PM
Bookmarks
Bookmarks
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
