Results 1 to 5 of 5
Thread: 83' zx 5 speed in 78 280z
  1. #1
    Registered User
    Member ID
    CZCC-30512
    Join Date
    Jun 2014
    Location
    NJ
    Age
    29
    Posts
    2
    Default 83' zx 5 speed in 78 280z
    I know there are similar threads but none that deal with my specific trans and I would really like to be sure before starting. So I've gathered from reading other posts that the transmission should bolt right in but I'm unsure about all of the extra wire ports that seem to be on the 83' trans. Can they be left in connected? And is there anyway I can tell if this transmission is from a turbo or non turbo version (I hear the non turbo is better) any feedback would be great will post a pic if that will help expedite the process
  2. #2
    Registered User tlorber's Avatar
    Member ID
    CZCC-20299
    Join Date
    Oct 2009
    Location
    Los Angeles
    Age
    55
    Posts
    1,190
    Default
    I put an '82 ZX tranny into my '73 and had no issues beside a 1/4" conflict with an aftermarket exhaust. The only electrical I remember hooking up was the reverse light. Just make sure your pressure plate and throwout bearing collar go together.
    Tlorber
    '73 240 +/- done
    '73 240 survivor
    '69 SRL 311
    '54 GMC Going onto S10 frame w/LS motor
    '99 Lexus GS Driver
  3. #3
    Low Budget/High Value
    Member ID
    CZCC-20342
    Join Date
    Oct 2009
    Location
    Washington County, OR
    Posts
    3,629
    Default
    The non-turbo transmission does not require a new driveshaft. The turbo transmission does. The turbo transmission has a very different shifting mechanism. The non-turbo will look almost identical to what you have now. That's one way to tell, if you're already sure that it's an 83 280ZX transmission.
    The extra switch wires can just be left disconnected.
    1976 280Z, with some minor modifications
  4. #4
    Registered User EuroDat's Avatar
    Member ID
    CZCC-26512
    Join Date
    Feb 2012
    Location
    The Netherlands
    Posts
    1,420
    Default
    The only switch you need is the reverse switch which has two green wires going to it.
    The turbo models had a completly different Borg warner T5 transmission in the manual models.
    Chas
    Chas
    5/77 280Z HLS30 403100 with some modifications
    Original colour: 305 Light Blue. The PO changed it to Red
  5. #5
    Registered User
    Member ID
    CZCC-30512
    Join Date
    Jun 2014
    Location
    NJ
    Age
    29
    Posts
    2
    Default
    Thank you for all of the info guys very helpful!
Thread Information
Users Browsing this Thread
Similar Threads
  1. 280z 5 speed and 280zx 5 speed differences
    By bbcountach in forum Parts Swapping (S30)
    Last Post: 09-09-2014, 09:27 AM
  2. Shifter for 280Z 5-Speed?
    By Oiluj in forum Engine and Drivetrain (S30)
    Last Post: 10-15-2010, 05:20 PM
  3. Which is Better 280Z or ZX 5 speed?
    Last Post: 12-03-2009, 11:33 AM
  4. 78 280z 5-speed into 78 280z 2+2 auto
    By anthony280z2+2 in forum Parts Swapping (S30)
    Last Post: 02-06-2009, 10:01 AM
  5. 280Z 5 speed, How bad is it?
    By Neal G in forum Engine and Drivetrain (S30)
    Last Post: 07-28-2008, 08:51 AM
Tags for this Thread
Bookmarks
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
