Results 1 to 2 of 2
Thread: Upper spring seat bump stop
  1. #1
    Registered User
    Member ID
    CZCC-24522
    Join Date
    Jun 2011
    Location
    Montreal, Canada
    Posts
    27
    Default Upper spring seat bump stop
    Ok, so I've got a poly bushing kit, including 4 bump stops. Here are what my current upper spring seats look like (I have 2 of each):
    Click image for larger version.
ID:	73032Click image for larger version.
    The first one seems to have an integrated bump stop. Should I try to remove it (looks bound pretty solidly)? Also, when disassembling my suspension, I noticed that there ware NO strut bearings! Are they necessary? I think there are supposed to be at the front?
    My new KYB dust boots also come with white bump stops. Which way would be best?
  2. #2
    Registered User er34gtt2000jp's Avatar
    Member ID
    CZCC-8081
    Join Date
    Mar 2005
    Location
    Sacramento CA
    Age
    45
    Posts
    466
    Default
    I'd replace all four while you have them apart. Inexpesive parts and no telling how many more bumps that orange thing will take before its toast.
    On the strut bearing issue, the fronts should have a bearing in the "hat" that has the three studs in it and the rears should have a similarly shaped plastic spacer.
Thread Information
Users Browsing this Thread
There are currently 1 users browsing this thread. (0 members and 1 guests)
Similar Threads
  1. Spacers for seat belt upper shoulder strap swivels?
    By BTF/PTM in forum Interior (S30)
    Last Post: 04-03-2010, 09:52 AM
  2. Strut Boot / Bump Stop 240Z
    By biddljj in forum Suspension and Steering (S30)
    Last Post: 09-29-2008, 09:42 PM
  3. Dust seal between the thrust bearing and upper spring seat...
    By Palmer in forum Suspension and Steering (S30)
    Last Post: 04-22-2006, 07:57 AM
  4. Bump stop orientation
    Last Post: 04-16-2006, 10:38 AM
  5. Strut bump stop...
    Last Post: 04-05-2006, 09:16 AM
Bookmarks
Bookmarks
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
