Results 1 to 6 of 6
Thread: That annoying alarm buzzer
  1. #1
    Registered User
    Member ID
    CZCC-25511
    Join Date
    Oct 2011
    Location
    michigan
    Age
    64
    Posts
    127
    Default That annoying alarm buzzer
    Its behind the speedo. I tried getting to it to pull the electrical plug to disable it but couldn't get to it. The FSM saying I need to remove the speedo to get to it but I can't even find the lower screw for removing the speedo (I kind of hate the thought of pulling the speedo any way incase I have trouble getting it seated back in again). I don't see a separate fuse for the buzzer which I could pull. Does anyone else have a suggestion for disabling it? This is on my 76. I don't mind it so much for example when I open the door with the key still in it, but mine also alarms while I'm cranking the engine over to start it, and I'd rather beable to better hear the engine while cranking instead of that annoying buzzer.
    Thanks
    Gary
  2. #2
    Registered User siteunseen's Avatar
    Member ID
    CZCC-24724
    Join Date
    Jul 2011
    Location
    Alabama
    Posts
    1,967
    Default
    No help here just my buzz. My '77 buzzes 6 times when I turn the ignition to ON, I wait until it stops then crank it. My '72 buzzes when I put it in gear without the lap belt fastened, that's annoying when I'm just moving it around my garage.
    1972 240Z #918 New Sight Orange
    1977 280Z #305 Light Blue Metallic
    1972 240Z #110 Persimmons Red
  3. #3
    1978 280Z (stock) TomoHawk's Avatar
    Member ID
    CZCC-2169
    Join Date
    May 2002
    Location
    NorthCoast, Ohio
    Age
    59
    Posts
    6,497
    Default
    The buzzer is an important safety feature. It's supposed to remind you to fasten the seatbelt. It also buzzes if you leave the key in and open the driver's door. If you feel it is not to your liking, you should consider changing it to a buzzer or dinger with a sound that you like, but it should not be disabled or removed.
    Siteunseen-
    You can still start the engine without waiting for the buzzer to stop. I usually do that, and by the time the engine starts and idles down the buzzing is done.
    BTW- if you find a dinger wit has nice sound, please let us know, there are many uses for those.
    Drive Responsibly.
    enjoy classic Rock music.
  4. #4
    '72 240Z(G) 3.2L
    Member ID
    CZCC-7328
    Join Date
    Nov 2004
    Location
    MA
    Age
    69
    Posts
    1,074
    Default
    Both those buzzers can easily be taken care of by pulling a wire connector off.
    As to the statement that these are needed is based more on the thought that you as an individual need a nanny to remind you to do something. Grow a pair, disconnect two wires and click your seat belt into position before you turn the ignition key.
    Real Men don't need buzzers.....
    if a little knowledge can make you dangerous, I'm a little dangerous
  5. #5
    Registered User rossiz's Avatar
    Member ID
    CZCC-30163
    Join Date
    Feb 2014
    Location
    Seattle, WA
    Age
    53
    Posts
    323
    Default
    on my '78 i was able to simply pull one the wire connector off the buzzer. got on my back upside down, head under the dash and turned the key several times to listen to the buzzer and feel around with my hand to locate it (and hearing it all those times in a row fully cemented my decision and resolve) and then just pulled off the plug.
    best free mod - i don't miss it at all.
    the "fasten seat belts" warning light still lights up in the console, giving that old-school look/feel as well as to remind me of this important safety feature
    '78 280z - Daily driver/work in progress...
  6. #6
    Registered User
    Member ID
    CZCC-25511
    Join Date
    Oct 2011
    Location
    michigan
    Age
    64
    Posts
    127
    Default
    I tried doing exactly what rossiz did and was able to get my fingers on the buzzer, but I couldn't find and grasp the darn connector for it whereever they have that tucked into. I even moved the hood latch handle out of the way and some other hardware. As mentioned above, I hate to take out the tach to get the speedo out as the FSM describes. I'll try going up-side-down-backwards one more time this weekend. And as rossiz noted, my seat belt warning light does also work. Gary
Thread Information
Users Browsing this Thread
There are currently 1 users browsing this thread. (0 members and 1 guests)
Similar Threads
  1. 71 240Z. Door buzzer "key alarm" question.
    By glassguy in forum Electrical (S30)
    Last Post: 02-01-2014, 09:00 AM
  2. Help buzzer
    By Pomorza in forum Interior (S30)
    Last Post: 09-10-2013, 04:37 AM
  3. Speed Limit Buzzer - Question
    By Norcal510 in forum Electrical (240K)
    Last Post: 04-25-2011, 02:57 PM
  4. Now THIS is annoying!
    By ALConfederate in forum Electrical (S30)
    Last Post: 05-06-2008, 09:27 AM
  5. Buzzer
    By Ramses in forum Electrical (S30)
    Last Post: 02-08-2007, 06:37 AM
Bookmarks
Bookmarks
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
