Results 1 to 6 of 6
Thread: Heater Control Valve
  1. #1
    Registered User
    Member ID
    CZCC-24101
    Join Date
    Apr 2011
    Location
    KY
    Posts
    393
    Default Heater Control Valve
    I am doing a lot of work on my 76 280Z to begin driving daily.
    I just realized that the previous owner bypassed the heater control valve and the heat is on continuously.
    Does anyone have a heater control valve they may want to part with reasonable priced or know where I might find one.
    May be needing other heat/air related parts as I move forward.
    Thanks.
  2. #2
    Registered User Hunter260Z's Avatar
    Member ID
    CZCC-24528
    Join Date
    Jun 2011
    Location
    Timberlake, NC
    Posts
    207
    Default
    I was going to say Motorsports Auto, but they were out of stock. There price was app $ 260.00. That's crazy.
    Ray
    1974 Datson 260Z
    RLS30-27748 Matching #'s
    L26 Stock w/72 Round Tops
    Interpart Front Spoiler
    Addco Front & Rear Sway Bars
    My Very First Car
    Purchased 5/23/1974
  3. #3
    Jim Arnett jfa.series1's Avatar
    Member ID
    CZCC-22303
    Join Date
    Aug 2010
    Location
    Richardson TX
    Posts
    764
    Default
    The on-line catalog says your P/N is 27116-N4220 for 08/75 and later. I checked Courtesy and it is listed as NLA. For earlier cars the P/N is 27116-N3600, is available at Courtesy for $31.05. Some creative engineering might make an earlier version work for you.
    Datsun 240Z/260Z/280Z Car Heater (From Aug.-'73)
    Jim Arnett
    HLS30-15320 12/1970, original owner
    L24-020208 (original)
    IZCC Original Owner Registry #53
  4. #4
    Low Budget/High Value
    Member ID
    CZCC-20342
    Join Date
    Oct 2009
    Location
    Washington County, OR
    Posts
    3,629
    Default
    Captain Obvious's solution might be an option. It will take some wrecking yard wandering. I did something similar to his, but with a valve with a 90 degree bend. If I had to redo it though, I'd locate in the engine bay like he did. There's just no room under the dash to fit the parts, let alone do the work.
    If you decide to try it, try to find a longer control cable along with the valve. The stock cable might not reach to the engine bay. My 76 280Z cable would have been too short.
    Also, almost all of the Japanese brands around his year range have some variation on the valve. Some close backwards also so you have to do some mental gymnastics about how the stock lever works. Cable retract = open. The valves are easy to get to, they're all on the firewall behind the engine.
    http://www.classiczcars.com/forums/i...n-project.html
    1976 280Z, with some minor modifications
  5. #5
    Member ID
    CZCC-20342
    Join Date
    Oct 2009
    Location
    Posts
    3,629
    Default
    AND, just realized that you didn't specify which valve. One is just a straight vacuum controlled shutoff valve, the other is the flow control valve sometimes with the capillary tube.. The shutoff valve is probably the cheaper one.
    ZSpecialties (aka Oliver) has a selection of parts that you might need when you're under there.
    240Z, 260Z, & 280Z #'s 1,2,&3 - 75-78 280 Z=3 - AC, Heating, Dash Venting 3 - Z Specialties Online Store - If we don't have it in stock, we can get it!
  6. #6
    Registered User siteunseen's Avatar
    Member ID
    CZCC-24724
    Join Date
    Jul 2011
    Location
    Alabama
    Posts
    1,967
    Default
    I got one from my Nissan dealer about a month ago, $45 I think. Took 2 days to come in from Irving, Texas distribution center.
    Nissan part #27116-E4400. Now I have to gather up the hoses, Black Dragon and MSA have the 3 preformed ones for around $50.
    1972 240Z #918 New Sight Orange
    1977 280Z #305 Light Blue Metallic
    1972 240Z #110 Persimmons Red
Thread Information
Users Browsing this Thread
Similar Threads
  1. Heater Control Valve and Engine Side Heater Hoses
    By marvelous240Z in forum Engine and Drivetrain (S30)
    Last Post: 02-12-2013, 08:36 PM
  2. heater control valve?
    By scotts pearl in forum Help Me !!
    Last Post: 04-19-2009, 08:04 PM
  3. heater control valve
    By silver bullet z in forum Help Me !!
    Last Post: 10-13-2008, 08:10 PM
  4. heater control valve 77 280
    By gator in forum Engine and Drivetrain (S30)
    Last Post: 03-23-2007, 11:24 AM
  5. Heater control valve
    By Jon, the BIG boy in forum Help Me !!
    Last Post: 12-11-2000, 01:10 AM
Bookmarks
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
