Results 1 to 8 of 8
Thread: What should be best?
  1. #1
    Registered User
    Member ID
    CZCC-30774
    Join Date
    Aug 2014
    Location
    Sacramento Ca
    Age
    24
    Posts
    3
    Default What should be best?
    Just graduated from high school in June. Took my graduation money and some money that i had saved up and found a '72 240z in Modesto. Ran a little rough, made some calls, determined that it was either timing issues or the carburetors. Fixed those issues before, especially with carburetors on motorcycles. Anyways, right when i began to head up the freeway towards my home, it started to constantly overheat. Had it towed. Solved the overheating issue and the timing. Ran a little bit better everyday that i had it this summer. Ended up doing a pressure test on the cylinders, Major power issues with it driving. Cylinders 2-3 had no pressure at all. (0-20) compared to 195-200. Took the head off, my hunch was correct, blown head gasket. The guy before me ran it with a blown head gasket for so long that the piston in cyl. No. 2 has holes in it and the cylinder wall is going to need boring out. Took it to a shop that rebuilds engines. Quoted me $1,600. Another shop quoted me $1,300. Generally for a rebuild, not that much, but i just started college and i got a new job twenty miles away. Should i hold on to my Z and make it into a project while i save up money for another car? or should i get rid of it? It would hurt so much to get rid of her. Overall, the car is still solid, mostly surface rust. Thanks everyone!
  2. #2
    Registered User Z dreams's Avatar
    Member ID
    CZCC-23169
    Join Date
    Dec 2010
    Location
    Lawton Mich.
    Posts
    82
    Default
    For the short term, I would shop for a good running engine.
  3. #3
    Registered User
    Member ID
    CZCC-29883
    Join Date
    Nov 2013
    Location
    Portland, Or
    Age
    71
    Posts
    283
    Default
    I agree, a good used engine is not that hard to find, Pull the valve cover, spark plugs and give it a compression test. You might even find a club member that has a spare. Mark
  4. #4
    Registered User
    Member ID
    CZCC-30774
    Join Date
    Aug 2014
    Location
    Sacramento Ca
    Age
    24
    Posts
    3
    Default
    Should I keep it original with the L24? ? Or should I take the time to get an L25 or L28?
  5. #5
    Registered User
    Member ID
    CZCC-30774
    Join Date
    Aug 2014
    Location
    Sacramento Ca
    Age
    24
    Posts
    3
    Default
    Sorry, I'm on my phone. I mean L26 not L25 haha. Thanks for replying guys.
  6. #6
    Low Budget/High Value
    Member ID
    CZCC-20342
    Join Date
    Oct 2009
    Location
    Washington County, OR
    Posts
    3,629
    Default
    These engines are pretty durable when well-maintained. Here's one in your area. Wouldn't be surprised if it was fine inside if it was stored correctly. Some oil, a battery and a starter might tell something.
    Datsun 240Z Engine Complete
    An L28 would accept the L24 parts but you'd probably have to retune the carbs. 17% more displacement will add some power though. The EFI system is pretty easy to swap over also if you wanted make the switch.
    DATSUN STRONG RUNNING COMPLETE L28 MOTOR
    1976 280Z, with some minor modifications
  7. #7
    Registered User
    Member ID
    CZCC-29883
    Join Date
    Nov 2013
    Location
    Portland, Or
    Age
    71
    Posts
    283
    Default
    I'd go with an L24. Bolt it up & drive it. No screwing around modifying this & that to get it to run. Being in college, you'll need a reliable car that won't take up your time & money. Mark
  8. #8
    Registered User mjr45's Avatar
    Member ID
    CZCC-21301
    Join Date
    Mar 2010
    Location
    Divide, CO
    Posts
    572
    Default
    I agree with Mark, find a good used L24 drop it in and go, then take your old motor and take your time and a little cash at a time and rebuild it into a better motor, just my 2.
    75 280Z almost done
    49 Chevy 3100 p/u next project
    96 Dodge 2500 4X4 tows my 5th wheel
Thread Information
Users Browsing this Thread
There are currently 1 users browsing this thread. (0 members and 1 guests)
Tags for this Thread
Bookmarks
Bookmarks
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
