Results 1 to 19 of 19
Thread: 2 1/2" shop built exhaust sounds great
  1. #1
    Registered User rossiz's Avatar
    Member ID
    CZCC-30163
    Join Date
    Feb 2014
    Location
    Seattle, WA
    Age
    53
    Posts
    323
    Default 2 1/2" shop built exhaust sounds great
    there are dozens of exhaust posts out there, but i couldn't resist adding to the mix...
    just finished rebuilding a good portion of my motor (n42 head, shaved intake, new injectors, etc. new cam chain/sprockets) and put on an msa 6-2-1 header. after reading up on other peoples experience i decided to have a local shop build a 2 1/2" system for me.
    we put her up on the lift and mapped out the routing - these cars are sooooo simple, just one run back and a couple of bends - but it's the little details that make or break it for me.
    went with alumanized steel piping to an 18" sst ansa resonator in the tunnel and a nice compact can at the back and a polished sst tip with a turndown and a bit of extension to get the fumes out of the vortex. he welded a flare right up to the header adapter flange so we have a nice seal there.
    the only tricky part was getting a hanger support behind the resonator - didn't want to drill into or weld onto the body. so we came up with a slightly unorthodox approach and welded a stud onto the head of the bolt that holds the diff strap and used that as a hanger support. a little goofy, but it's sturdy and doesn't affect the ability to remove/replace the strap since he was careful and didn't weld past the flats of the bolt head.
    the engine breathes so nicely now, and the sound is really intoxicating - makes me want to do bad things, even on a grocery run...
    the sound is low and throaty at idle, almost sbc-ish, but it picks up an awesome growl and really sings out above 4K but it's mellow off the gas so it's still pleasant to drive around as my dd. overall very happy and would highly recommend this approach. the whole thing was just over $400 and i learned a lot listening to his experience and it was fun to be able to lay out every bend for clearances and a perfect fit.
    i will try and get a decent video recording (need a second person) and will post for those who care to listen.
    view from header back
    Click image for larger version.
    looking back towards header
    hanger attachment
ID:	73687 Click image for larger version.
    muffler
    view from rear
    tailpipe extension
    on the ground
    '78 280z - Daily driver/work in progress...
  2. #2
    Nova Scotia,Canada,Earth Blue's Avatar
    Member ID
    CZCC-7641
    Join Date
    Jan 2005
    Location
    NS
    Posts
    4,085
    Default
    very nice workmanship!
    There is scarcely anything in the world that some man cannot make a little worse, and sell a little more cheaply.
    The person who buys on price alone is this man's lawful prey.
    John Ruskin (1819 - 1900)
    ZCars in Eastern Canada seaport ready for shipment to Europe
    http://ZSportCanada.com
  3. #3
    Boat Anchor Repairman Captain Obvious's Avatar
    Member ID
    CZCC-24608
    Join Date
    Jul 2011
    Location
    Philadelphia, PA
    Posts
    1,845
    Default
    Beautiful. I'm going to have to redo mine in the (hopefully) near future as well.
    Hope mine turns out that well!
  4. #4
    Registered User Oiluj's Avatar
    Member ID
    CZCC-15388
    Join Date
    Nov 2007
    Location
    SF Bay Area
    Age
    66
    Posts
    1,746
    Default
    Nice!
    Julio
    1972 240Z (in-progress, 95% complete)
    CZC# 15388
  5. #5
    Z geek at large FastWoman's Avatar
    Member ID
    CZCC-19635
    Join Date
    Jul 2009
    Location
    Hampton Roads, VA
    Posts
    2,787
    Default
    Very nice job! And you got a good deal on the work!
    My last three sports cars while I still owned all three:
    2001 BMW Z3 Roadster 3.0i soft/hard top (sold)
    1966 Ford Mustang Coupe (sold)
    1978 Datsun 280Z (enjoying very much )
  6. #6
    Registered User madkaw's Avatar
    Member ID
    CZCC-7622
    Join Date
    Dec 2004
    Location
    bloomington IN
    Age
    57
    Posts
    2,288
    Default
    Very nicely done. I do think the right exhaust on these motors makes for the best sounding engines out there.
    Steve
    71 240z,bw-5sp 2.4-40 over,balanced,e-88,big valves,ported&polished, stage2,header, triple Mikuni's 40's
    3.90 Subaru STI LSD
  7. #7
    1978 280Z (stock) TomoHawk's Avatar
    Member ID
    CZCC-2169
    Join Date
    May 2002
    Location
    NorthCoast, Ohio
    Age
    59
    Posts
    6,497
    Default
    It looks nice.
    I'm surprised that he installed the muffler flat-ways. None of the exhaust guys I know will do that because they all claim it's too close to the fuel tank, and the heat will boil the fuel.
    Drive Responsibly.
    enjoy classic Rock music.
  8. #8
    Member ID
    CZCC-7641
    Join Date
    Jan 2005
    Location
    NS
    Posts
    4,085
    Default
    Flat is probably good for "quiet", I had one stuffed way up as high as the tail pipe would go and it was loud. Even dropping it a couple of inches made a difference so flat would be even better.
  9. #9
    Member ID
    CZCC-30163
    Join Date
    Feb 2014
    Location
    Seattle, WA
    Age
    53
    Posts
    323
    Default Some decent sound recordings today
    took her out on a small, inclined straight down the street (blue knows this little drag strip) and had my buddy record a couple of runs as well as one revving at the curb.
    i'd love to post but can't seem to figure out how to load mp3 files - anyone know the trick??
  10. #10
    Member ID
    CZCC-7641
    Join Date
    Jan 2005
    Location
    NS
    Posts
    4,085
    Default
    You have to hide the mp3 in a zip file then upload as an attachment (using advanced edit mode). there is also a size limit on the zip.
    It may be better to save as a video on youtube or maybe save in a video format (movie maker built in windows can do this) and use this site to upload the video.
  11. #11
    Member ID
    CZCC-2169
    Join Date
    May 2002
    Location
    NorthCoast, Ohio
    Age
    59
    Posts
    6,497
    Default
    Just don't video your tailpipe, please! Why do people make videos of the tailpipe?
    Drive Responsibly.
  12. #12
    Member ID
    CZCC-30163
    Join Date
    Feb 2014
    Location
    Seattle, WA
    Age
    53
    Posts
    323
    Default
    test links - let me know if this works (best listened to with headphones or good speakers):
    Comparison Control Sample (lexus going by)
    https://drive.google.com/file/d/0B5o...it?usp=sharing
    Revving at the curb
    Flyby #1
    Flyby #2
  13. #13
    Member ID
    CZCC-2169
    Join Date
    May 2002
    Location
    NorthCoast, Ohio
    Age
    59
    Posts
    6,497
    Default
    I was able to hear the files, but I had to save them (using the download control at the top) to the hard drive first.
    It sounds good. I would like mine to sound that way. It sounds more like an outboard engine.
    Drive Responsibly.
  14. #14
    Member ID
    CZCC-7641
    Join Date
    Jan 2005
    Location
    NS
    Posts
    4,085
    Default
    Sounds great! Sure whizzes by fast!
  15. #15
    Member ID
    CZCC-30163
    Join Date
    Feb 2014
    Location
    Seattle, WA
    Age
    53
    Posts
    323
    Default
    all done on a closed course, with professional drivers.
    obey all posted traffic regulations at all time.
    not responsible for accident or injury caused when used for un-intended purposes
    your results may vary..........
  16. #16
    Registered User
    Member ID
    CZCC-23125
    Join Date
    Dec 2010
    Location
    Spartanburg, SC
    Age
    51
    Posts
    468
    Default
    Love it! Sounds great...
    C
  17. #17
    Member ID
    CZCC-2169
    Join Date
    May 2002
    Location
    NorthCoast, Ohio
    Age
    59
    Posts
    6,497
    Default
    How come mine never sounds like that? Are you using a special resonator?
    Drive Responsibly.
  18. #18
    Registered User Sean240Z's Avatar
    Member ID
    CZCC-6478
    Join Date
    Apr 2004
    Location
    McLean, VA, USA
    Age
    48
    Posts
    232
    Default
    Rossiz - I have a similar set-up and I love the sound. If you find that the transmission tunnel gets hot with the resonator close to the driver side, I'd suggest you install a Thermo-Tec Heat Shield as per followng post:
    http://www.classiczcars.com/forums/e...d-exhaust.html
    For me, the heat shield greatly reduced the trans tunnel temps.
  19. #19
    Member ID
    CZCC-30163
    Join Date
    Feb 2014
    Location
    Seattle, WA
    Age
    53
    Posts
    323
    Default
    Thanks Sean - I saw your post a while back and the heat shield looks pretty cool (pun intended).
    I'm actually getting ready to replace the clutch, so I'll have the tranny out and that would be a great time to do a heat shield. The tunnel itself only gets warm on my car, except for the ashtray, which gets HOT inside. I only use it for a cup-holder and to hold my iphone while driving, and melts ice and roasts the phone. I think this is because the ashtray sits metal-to-metal on the tunnel and so transmits the heat. the rest of the tunnel is covered in sound insulation mat, which has a foil component (radiant barrier) and a thick felt under my carpet, which also has a heavy rubber backing. All this helps the tunnel heat from entering the cabin, but I'm not excited about the heat cooking my carpet and sound mat over time... always best to stop the heat BEFORE it gets through the body metal
    I'm actually going to be revising my exhaust system a little - the original design had the muffler in the tunnel lying flat and the resonator at the end, and my home-made trial worked really well with zero drone. The new system reversed that, which necessitated a short muffler and there is some drone between 2K and 2,500 which is starting to bug me. I'm going to get a longer muffler and a shorter resonator and do the swap. The resonator is also polished SST, so it should look good with the tip welded right to it, and it will show a lot less in the rear wheel well.
Thread Information
Users Browsing this Thread
There are currently 1 users browsing this thread. (0 members and 1 guests)
Similar Threads
  1. Smog "tubes" in exhaust ports
    By JohnnyO in forum Exhaust (S30)
    Last Post: 05-19-2011, 02:15 PM
  2. AWESOME SHOP. Great place to have work on your Z!!!
    By studioti in forum Open S30 Z Discussions
    Last Post: 12-30-2009, 10:31 PM
  3. 1 hand built Cobra off to the body shop
    By Travel'n Man in forum Introductions and Z Stories
    Last Post: 10-07-2009, 12:12 PM
  4. "Blasphemy!!", Some say. & You guys are GREAT!!
    By 2many280zzz in forum Open S30 Z Discussions
    Last Post: 01-23-2008, 09:29 PM
  5. Great Body & Paint shop in Denver area
    By beandip in forum Open Discussions
    Last Post: 08-08-2006, 09:02 PM
Bookmarks
Bookmarks
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
