Results 1 to 5 of 5
Thread: Could my brake noise be because front pad shims are in upside down.
  1. #1
    Registered User sdyck's Avatar
    Member ID
    CZCC-30672
    Join Date
    Jul 2014
    Location
    Calgary Alberta
    Age
    56
    Posts
    32
    Default Could my brake noise be because front pad shims are in upside down.
    I've been addressing my new toe '72's issues one at a time, starting with brakes.
    First job was a new reman brake booster from MSA which made a huge difference.
    Second was to address break noise that occurred with slight pressure. Took off the wheels, pulled pads and shims, cleaned them up applied grase between the pad and shim, put them back the way I found them ( lots of pad left). Theth were much better but they still would "sing" a little with light pressure. Did a search and stumbled across a diagram that shows y shims are upside down.
    The were and are in in an "L" shaped position with the arrow on the shim pointing down. Could this be causing my continued noise?
  2. #2
    Low Budget/High Value
    Member ID
    CZCC-20342
    Join Date
    Oct 2009
    Location
    Washington County, OR
    Posts
    3,629
    Default
    I do know the shims make a difference. I thought the arrow pointed in the direction of rotation. Which appears to be up.
    Datsun 240Z/260Z/280Z Front Brake (Disc Brake)
    1976 280Z, with some minor modifications
  3. #3
    Boat Anchor Repairman Captain Obvious's Avatar
    Member ID
    CZCC-24608
    Join Date
    Jul 2011
    Location
    Philadelphia, PA
    Posts
    1,845
    Default
    The arrows should be pointing in the direction of forward wheel rotation, and I've also found from experience that they do matter.
    I had an intermittend brake squeal and when I pulled my pads, I found my PO had installed those shims backwards. I flipped them around and my squeal hasn't come back since. I was thrilled it was that simple.
  4. #4
    Member ID
    CZCC-30672
    Join Date
    Jul 2014
    Location
    Calgary Alberta
    Age
    56
    Posts
    32
    Default
    Took half an our this evening to jack up the car, place the jack stands, wheels off, shims switched and flipped with the arrow pointed the right directions.
    Half hour test drive with lots of stop and go with no noise! Very pleased with easy fixes. Much more confident with my brakes.
    thanks!
  5. #5
    Member ID
    CZCC-24608
    Join Date
    Jul 2011
    Location
    Philadelphia, PA
    Posts
    1,845
    Default
    Excellent. Sounds like you an I had the same issue...
    We needed to turn our squeal shims into anti-squeal shims.
Thread Information
Users Browsing this Thread
There are currently 1 users browsing this thread. (0 members and 1 guests)
Similar Threads
  1. 240 Z Front and Rear Bumper "Shims"
    By David Jacks in forum Body and Paint (S30)
    Last Post: 04-12-2011, 06:26 PM
  2. Front brake rotors
    By Pomorza in forum Wheels, Tires and Brakes (S30)
    Last Post: 05-29-2010, 01:47 AM
  3. Front Brake Clips
    By Mike Abild in forum Help Me !!
    Last Post: 12-27-2006, 04:35 PM
  4. Front brake hardware 71
    By rtaylor in forum Wheels, Tires and Brakes (S30)
    Last Post: 07-22-2006, 07:05 AM
  5. Brake Shims
    By Aussie Zed in forum Wheels, Tires and Brakes (S30)
    Last Post: 07-05-2006, 06:00 PM
Bookmarks
Bookmarks
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
