Results 1 to 15 of 15
Thread: ZX Dist in 240Z
  1. #1
    Registered User
    Member ID
    CZCC-30804
    Join Date
    Sep 2014
    Location
    SF,CA
    Posts
    11
    Default ZX Dist in 240Z
    OK, I have everything I need for my ZX Dist swap. The only thing I am not sure of, is what coil I need. I have the ZX tach in place and a wire running to the coil +. What after market coil will work and do I need the resistor?
  2. #2
    Registered User siteunseen's Avatar
    Member ID
    CZCC-24724
    Join Date
    Jul 2011
    Location
    Alabama
    Posts
    1,967
    Default
    That's the best thing I've done to mine so far and after much research and advice from other members the Crane PS20. It has the same OHMS as a ZX stock coil, 1.5, and is American made. Amazon.com: Crane Cams 730-0020 PS20 Performance Coil: Automotive
    You won't need the ballast resistor. Go down about 3/4s of the page and look at the 2nd 240Z schematics. http://atlanticz.ca/zclub/techtips/d...tor/index.html
    1972 240Z #918 New Sight Orange
    1977 280Z #305 Light Blue Metallic
    1972 240Z #110 Persimmons Red
  3. #3
    Registered User madkaw's Avatar
    Member ID
    CZCC-7622
    Join Date
    Dec 2004
    Location
    bloomington IN
    Age
    57
    Posts
    2,288
    Default
    ...or just go to your local parts store and get a coil made for the ZX series
    Steve
    71 240z,bw-5sp 2.4-40 over,balanced,e-88,big valves,ported&polished, stage2,header, triple Mikuni's 40's
    3.90 Subaru STI LSD
  4. #4
    Registered User tlorber's Avatar
    Member ID
    CZCC-20299
    Join Date
    Oct 2009
    Location
    Los Angeles
    Age
    54
    Posts
    1,190
    Default
    When I did the same swap, I had the prior coil in until I bought a flamethrower. The original coil did not adversely affect the way the car ran.
    Tlorber
    '73 240 +/- done
    '73 240 survivor
    '69 SRL 311
    '54 GMC Going onto S10 frame w/LS motor
    '99 Lexus GS Driver
  5. #5
    Nova Scotia,Canada,Earth Blue's Avatar
    Member ID
    CZCC-7641
    Join Date
    Jan 2005
    Location
    NS
    Posts
    4,085
    Default
    The stock coil should be fine.... even the ballast resistor.
    If you go higher compression then maybe you will need high voltage.
    There is scarcely anything in the world that some man cannot make a little worse, and sell a little more cheaply.
    The person who buys on price alone is this man's lawful prey.
    John Ruskin (1819 - 1900)
    ZCars in Eastern Canada seaport ready for shipment to Europe
    http://ZSportCanada.com
  6. #6
    Registered User Walter Moore's Avatar
    Member ID
    CZCC-3035
    Join Date
    Oct 2002
    Location
    Indianapolis
    Posts
    1,833
    Default
    I run a ZX (S130) coil and have my balast resistor by-passed.
    '71 240Z, Because any fool can drive fast in a straight line.
  7. #7
    Low Budget/High Value
    Member ID
    CZCC-20342
    Join Date
    Oct 2009
    Location
    Washington County, OR
    Posts
    3,629
    Default
    The ZX ignition module has current control technology to reduce current flow when the coil gets close to saturation. So it will probably be fine to use any coil except those that have very low primary resistance like the most modern coils used with ECU timing control. They have low low primary resistance and can burn things up, including the module itself. Ideally, especially if you want to take advantage of the technology and run the .040" spark plug gap that the ZX's and 1978 280Z use, you would use a coil that can take the higher current and generate the higher spark energy. I don't know if the low current 240Z coils can do that, someone who's comfortable looking at inductances and windngs ratios and calculating outputs could probably say. So if you stick with stock 240Z you should probably stick to the .034" plug gap to avoid misfires.
    I would just use a coil designed for electronic ignition that has a primary resistance in the ballpark. The Crane PS20 is there, and proven, and you can't go wrong using a coil designed for the system, the parts store stock unit. Basically build the system like Nissan intended, set the plug gaps to the ZX spec. and go.
    Note that I'm not an electronics expert. And that all of my musings led to "set it up like stock".
    1976 280Z, with some minor modifications
  8. #8
    Member ID
    CZCC-7622
    Join Date
    Dec 2004
    Location
    bloomington IN
    Age
    57
    Posts
    2,288
    Default
    .... Or what he said^
    Steve
    3.90 Subaru STI LSD
  9. #9
    Member ID
    CZCC-24724
    Join Date
    Jul 2011
    Location
    Alabama
    Posts
    1,967
    Default
    Quote Originally Posted by Blue View Post
    That'd be like buying a .357 Magnum and firing .38 shells through it.
    Diseazd likes this.
  10. #10
    Registered User Marty Rogan's Avatar
    Member ID
    CZCC-874
    Join Date
    Jun 2000
    Location
    Arlington Heights, IL USA
    Posts
    1,202
    Default
    I use an MSD Blaster 2 coil and it works great.
  11. #11
    Registered User
    Member ID
    CZCC-30804
    Join Date
    Sep 2014
    Location
    SF,CA
    Posts
    11
    Default
    Good info. I'll get a Crane PS20 or the MSD Blaster. Thanks
  12. #12
    Member ID
    CZCC-7641
    Join Date
    Jan 2005
    Location
    NS
    Posts
    4,085
    Default
    ZX distributor upgrade is more for increasing reliability and decreasing wiring complexity. It is not for performance (with respect to non-points distributors from Nissan).
    A hotter coil will produce a spark that will burn through/ignite a tougher charge in the combustion chamber but do you really have that challenging charge to burn?
    Lubricating the distributor and replacing old spark plugs may help more by improving higher rpm spark timing performance, improving mechanical advance and improving wet weather spark.
  13. #13
    Member ID
    CZCC-7622
    Join Date
    Dec 2004
    Location
    bloomington IN
    Age
    57
    Posts
    2,288
    Default
    I don't know Blue, I think I would talk anyone away from points, just for the reason you stated. Reliability - especially high rpm== which can equal performance. Less moving parts is always a good thing .
    Stronger spark helps with lean conditions where the burn rate is slower.
    Electronic ignition to me has always been considered a performance upgrade with respect to points. IMHO
    Steve
    3.90 Subaru STI LSD
  14. #14
    Registered User
    Member ID
    CZCC-30804
    Join Date
    Sep 2014
    Location
    SF,CA
    Posts
    11
    Default
    Worked great except for my 280z tach. I did everything as I was supposed to ,but maybe the tach is shot. It pegs out. I did try the 10K Ohm resistor too. I'll do a search for the autometer tach.
    Thanks
  15. #15
    Registered User
    Member ID
    CZCC-30804
    Join Date
    Sep 2014
    Location
    SF,CA
    Posts
    11
    Default
    Figured out the tach redlining problem. It was a loose resistor in the tach circuit board. All good now.
Thread Information
Users Browsing this Thread
Similar Threads
  1. Tach Question: 280zx dist. in a 240z
    By Hardway in forum Electrical (S30)
    Last Post: 08-10-2012, 03:02 PM
  2. Replies: 305
    Last Post: 03-22-2011, 08:43 PM
  3. Update Alt and Dist.
    By Pablo in forum Open Racing Discussions
    Last Post: 10-21-2006, 04:18 PM
  4. Tach/ECU/Dist swap
    By sideshowbob in forum Electrical (S30)
    Last Post: 07-27-2005, 02:58 PM
  5. Will this dist. work?
    By Seanh in forum Engine and Drivetrain (S30)
    Last Post: 10-12-2002, 03:45 PM
Bookmarks
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
