Results 1 to 4 of 4
Thread: HELP! Cant find electrical problem.
  1. #1
    Registered User glassguy's Avatar
    Member ID
    CZCC-19076
    Join Date
    Apr 2009
    Location
    Iowa
    Age
    51
    Posts
    17
    Default HELP! Cant find electrical problem.
    71 240Z. My running lights stopped working the other day. I checked the fuse and it was ok. When I pulled one of the bulbs out I noticed it was burned out. It turns out every single running light, and all of the dash lights are not only burned out, but on some the glass is even cracked. I replaced all four of the running lights and they worked fine again, until I started the car and gave it some gas. They got bright and poof. No more lights. The first thing I checked was the voltage regulator. It's only 3 months old. With the car idleing it shows 12.6 volts. The volts dont go up at all if i rev it up. It shows 12.4 to 12.6 at the battery while running. I also just lost my stereo. It went up in smoke the same day the lights started acting up. Also, after all of this, the annoying door buzzer now only comes on when the car is running. And just today after really getting a chance to look thing over, the only thing I can find is that the negative wire that goes from the battery to the firewall is slightly melted. AND, during all of this not one single fuse has blown. And I have the upgraded fuse block with blade fuses last year. I disconnected the entire stereo system and no burned wires or blown fuses. I'm lost. Any ideas ?
    And now, I just replaced one of the running lights and it only come on while the engine is running. at idle the bulbs brightness fluctuates. I know if I reved it up it would burn out.
  2. #2
    No more body roll! SteveJ's Avatar
    Member ID
    CZCC-5413
    Join Date
    Dec 2003
    Location
    Gainesville, GA
    Age
    54
    Posts
    3,651
    Default
    1. Do you have a fusible link coming off of the starter and going into the main harness?
    2. How long have you owned the car?
    3. Did you or a previous owner make any other changes to the electrical system such as replacing the alternator? (I saw the "new" regulator was installed.)
    4. Why did you change the voltage regulator 3 months ago?
    5. Have you tested your alternator?
    The multiple system failures (lights, stereo, buzzer, etc.) lend belief that the voltage may have been too high. Corrosion in cables, mixed with higher voltage can create hot-spots, as well.
    Having an external regulator with an internally regulated alternator can cause problems with voltage regulation.
    73 240Z
    74 260Z
    Blue's collection of tech tips - A great place to look for answers
    XenonS30 -The cheap source for FSMs
    Georgia Z Club
    Fiddling with Z Cars - Z car tips & tricks and pictures of my car-loving life.
    Steve's CARtography - Just car pictures.
  3. #3
    Member ID
    CZCC-19076
    Join Date
    Apr 2009
    Location
    Iowa
    Age
    51
    Posts
    17
    Default
    1. No fusible link that I can see.
    2. 6 years. Restoration finished 2 years ago.
    3. I replaced the alternator a few months ago because the one that came with the car did die.
    4. I replaced the voltage regulator only because I replaced the alternator. Both are "cheap" Oreilly's parts.
    5. Tomorrow morning I will be getting the alternator tested.
    What has me confused is, Why do the running lights ONLY work with the car running. I removed the alternator belt and started the car. No running lights. And with the alternator connected the running lights will work, and will blow if i give it gas. Obviously they are getting too much power. But why wont the damn things work with the motor off! I know I burned a wire somewhere, but I just cant find it. I cant stand tearing apart this car. It's painful.
  4. #4
    Low Budget/High Value
    Member ID
    CZCC-20342
    Join Date
    Oct 2009
    Location
    Washington County, OR
    Posts
    3,629
    Default
    I kind of remember reading some recent posts about new external regulators that had problems. Incorrect wiring, I believe. And you didn't confirm that you don't have an internally regulated alternator combined with the external regulator. I seem to recall that you get either no regulation or no charging when you do that.
    The fact that your lights blow if you give it gas can really only be too much voltage. Each light bulb is just a small resistor that can handle 12-14 volts all day long. But will overheat if the voltage gets too high. You need to have the VR checked, not the alternator, or both. Confirm that they're both good and that the alternator is for external regulator usage.
    Or just go ahead and convert to the internal regulator. Since the external VR's appear to be iffy, that would be the safest route.
    No use fixing the lights problem until you get voltage under control.
    1976 280Z, with some minor modifications
Thread Information
Users Browsing this Thread
There are currently 1 users browsing this thread. (0 members and 1 guests)
Similar Threads
  1. can find the problem!!!!!! help
    By anthony280z2+2 in forum Electrical (S30)
    Last Post: 12-12-2007, 02:30 PM
  2. electrical problem
    By Papasmurf in forum Electrical (S30)
    Last Post: 02-17-2007, 04:13 PM
  3. Electrical problem - please help
    By venom42 in forum Help Me !!
    Last Post: 11-11-2005, 11:26 PM
  4. Electrical problem, please help!!
    By eat-pez in forum Electrical (S30)
    Last Post: 03-12-2005, 12:49 PM
  5. Electrical problem...I think
    By SavannahZ in forum Electrical (S30)
    Last Post: 10-19-2004, 06:55 PM
Bookmarks
Bookmarks
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
