Results 1 to 13 of 13
Thread: Weak 240Z U-joint resolutions?
  1. #1
    Registered User
    Member ID
    CZCC-30470
    Join Date
    May 2014
    Location
    Meridian, Idaho, United States
    Age
    34
    Posts
    12
    Default Weak 240Z U-joint resolutions?
    Hey guys. I've got a series 1 240Z that I'm slowly restoring as I drive it. I've developed an intermittent grinding noise from the rear that I'm fairly certain is the U-joint... possibly wheel bearings. Either way, I know the early Z's have u-joint issues due to the drive shaft length and a popular fix is changing to a 280z drive shaft. What other parts need to be replaced in addition? Are the u-joints on the Z's overly difficult?
  2. #2
    Low Budget/High Value
    Member ID
    CZCC-20342
    Join Date
    Oct 2009
    Location
    Washington County, OR
    Posts
    3,629
    Default
    Quote Originally Posted by Nismo37 View Post
    I've never heard this at all. Can you give a source for that information?
    Wheel bearings and u-joints don't really make the same noise when they fail. U-joints get clunky during gear shifts, and can cause a vibration. Wheel bearings, at least the rear ones with big ball bearings, tend to get loose before making lots of noise, allowing the wheel to move side-to-side and up and down and clunk a little bit, I believe. You can jack the back up and lift and tug on the wheel to test the wheel bearings. Crawl underneath and visually examine and pry on the u-joints. There should be zero play.
    1976 280Z, with some minor modifications
  3. #3
    Registered User
    Member ID
    CZCC-30470
    Join Date
    May 2014
    Location
    Age
    34
    Posts
    12
    Default
    Quote Originally Posted by Zed Head View Post
    There is a local Z guru near my home that has hundreds of old Z cars and a couple barns full of parts. He's the one that pointed out the difference. If you google "240Z drive shaft lenght" you'll see some information on it as well. My u-joints do clunk a little going into gear but there is an annoying growling noise coming from the rear at 30 mph and above.
  4. #4
    Member ID
    CZCC-20342
    Join Date
    Oct 2009
    Location
    Posts
    3,629
    Default
    Actually, I've done a lot of driveshaft (propeller shaft) Googling and not seen that. There is an early short propeller shaft, used with the forward mounted diff. Then the longer 240Z shaft, same length as the 280Z shaft, with replaceable u-joints. Then the 280Z shaft with staked in, non-replaceable u-joints.
    There is a problem with the side "drive shafts" (not the center propeller shaft) being too long on one side, if you convert to an R200 diff. That problem is described here and there.
    And the diffs themselves have an annoying growling noise, independent of u-joints or wheel bearings. Could be the bearings though, but they can be checked. How long have you had the car and what have you done to it?
    BUT, back to your direct question - if you have the forward mounted rear diff, then you have to use the short propeller shaft or remount the diff to the later rearward position to use the 280Z length shaft. Do you have the early diff position? You did not give the year of your car.
  5. #5
    Rust Free'ish zKars's Avatar
    Member ID
    CZCC-12190
    Join Date
    Jul 2006
    Location
    Calgary, AB Canada
    Posts
    1,256
    Default
    I remember a very old thread about some character near Boise that had a rather large stash of Z's and parts, but never did pin him or the exact location down. I think 'mystery solved" is appropriate. He should make himself known and get some action on that pile of apparently un-loved and un-wanted Z-bits.
    Now on topic, I believe you have a slight mix up on the drive shaft verses the half shafts to each wheel. The issue revolves around the early and late diff location, which would change the required drive shaft length. Half shafts are all the same on all S30's.
    Jim
    73 240Z HLS30 149331
    69 510 PL510 77603
    www.zKars.com
    www.calgaryzclub.ca
    Reference materials
    www.xenonS30.com
  6. #6
    Registered User
    Member ID
    CZCC-30470
    Join Date
    May 2014
    Location
    Age
    34
    Posts
    12
    Default
    My car was built in 1970, the original owner whom I bought it from stated it has the R180 differential so I'm assuming it's the forward mounted diff. The original L24 w/E31 head gave out on me a few months back. I've had the car since May. A loose cam bolt walked a pin loose and bent my valves. I had the clutch replaced and got a used L26 from the guy with all the Z stuff that I'm running until I can get the original engine rebuilt.
  7. #7
    Registered User
    Member ID
    CZCC-30470
    Join Date
    May 2014
    Location
    Age
    34
    Posts
    12
    Default
    Quote Originally Posted by zKars View Post
    Yes he exists. I've been there personally and have bought several items from him including an engine. I upgraded my cooling system to that of a 280z, mine still had the old metal fan shroud and fan. I have pictures too. Probably 250 z's of various models and years, mostly 240's - 300zx. Lots of 280's. He also has a couple of barns full of parts from body panels to drive train stuff. He doesn't appear to have a website but his name is Kim Blough (208)466-0004. Located in Nampa Idaho. He's mostly retired but if you can pin him down he's a wealth of knowledge. His business is called Idaho Z Car.
  8. #8
    Registered User rossiz's Avatar
    Member ID
    CZCC-30163
    Join Date
    Feb 2014
    Location
    Seattle, WA
    Age
    54
    Posts
    323
    Default
    interesting... any of those z's in running condition or good restoration projects?
    are they stored under cover or rusting away out in a field?
    map says he's less than 500 miles from me...
    '78 280z - Daily driver/work in progress...
  9. #9
    Walmart greeter Mikes Z car's Avatar
    Member ID
    CZCC-18366
    Join Date
    Dec 2008
    Location
    Idaho
    Posts
    1,041
    Default
    I have been inside one of the barns, I think there is just one. The barn is packed with Zs and there were many Zs outside as I recall from being there 5 years ago. The barn roof appeared to have a few holes but the cars seemed to be holding up well from what I saw. Most of them had some kind of damage from a wreck if I remember right but not sure that is true for all of them.
  10. #10
    Registered User
    Member ID
    CZCC-23125
    Join Date
    Dec 2010
    Location
    Spartanburg, SC
    Age
    51
    Posts
    468
    Default
    From the aerial pictures on Google he appears to 100-125 cars outside and 3-5 buildings. three are quite large
    C
  11. #11
    Member ID
    CZCC-12190
    Join Date
    Jul 2006
    Location
    Calgary, AB Canada
    Posts
    1,256
    Default
    Oh my...
    Click image for larger version.
    I might have a new best friend!
    Jim
    69 510 PL510 77603
    www.zKars.com
    www.calgaryzclub.ca
    Reference materials
    www.xenonS30.com
  12. #12
    Registered User EuroDat's Avatar
    Member ID
    CZCC-26512
    Join Date
    Feb 2012
    Location
    The Netherlands
    Posts
    1,420
    Default
    Apart from the very interesting Z guru. Dam thats a lot of Zeds.
    Your noises sound more like diff related. I would look at changing the oil and checking for metal depsoits in the oil. A bit more difficult would be checking the back lash in the diff. Excessive backlash can cause clunking noises during gear change and poor toe/heel paterns which cause whine and sometimes growling noises.
    Chas
    Chas
    5/77 280Z HLS30 403100 with some modifications
    Original colour: 305 Light Blue. The PO changed it to Red
  13. #13
    Registered User grannyknot's Avatar
    Member ID
    CZCC-26437
    Join Date
    Feb 2012
    Location
    Toronto
    Posts
    698
    Default
    Anyone in Idaho have a camera? We would all love to see some pics.
    If only I was retired, had a trailer and a pocket full of cash.
    Chris
    1970 240Z HLS30 01955 March/70
Thread Information
Users Browsing this Thread
There are currently 1 users browsing this thread. (0 members and 1 guests)
Similar Threads
  1. weak brakes
    By Stovepipe in forum Wheels, Tires and Brakes (S30)
    Last Post: 08-11-2011, 06:21 PM
  2. Datsun Z related New Years resolutions/goals
    By Earthcruiser in forum Open S30 Z Discussions
    Last Post: 01-01-2011, 01:49 PM
  3. 240z horn is weak. Should I replace?
    By MarkDixon in forum Open S30 Z Discussions
    Last Post: 08-03-2005, 04:54 PM
  4. Where to locate 240Z tierod and ball joint boots?
    By ezzzzzzz in forum Suspension and Steering (S30)
    Last Post: 07-06-2005, 06:52 PM
  5. Z Car new year resolutions
    By datfreak in forum Australia and New Zealand
    Last Post: 01-08-2004, 03:47 AM
Bookmarks
Bookmarks
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
