Results 1 to 1 of 1
Thread: Slick way to compress springs for maintenance
  1. #1
    HLS30A 17574 djwarner's Avatar
    Member ID
    CZCC-27817
    Join Date
    Aug 2012
    Location
    Central FLorida
    Posts
    405
    Default Slick way to compress springs for maintenance
    My son was working on his M3 the other day and found he couldn't get his spring compressors in the space allowed in the strut tower. This is similar to the problems in our Z's.
    He found a work around that may also work for our Z's. He bought 36" pull ties at the local Home Depot and found them rated at 175lbs. Jacked the axle up to compress the springs and installed 10 pull ties between the uppermost and lowermost coils. And as in the nursery rhyme, "there he kept them very well."
    If you are simply changing the strut, you are good to go. If you need to remove the springs, install a conventional spring compressor after you clear the strut tower and fender. Pull ties can be cut away with a diagonal cutter. Reverse the procedure to re-install.
    I would suggest using a minimum of pull ties to double (3x is better) the compressed spring load. So for our 2400lb cars that works out to about 600lbs per corner. My son's setup worked out to 2.5 times on his heavier car. Also verify each tie is pulled tight enough to carry its share.
    Just had a follow up discussion with my son. He actually composed the spring to near its maximum rather than to just the normal ride height. This drastically reduced the safety margin I quoted above. Buyer beware.
    1971 240Z HLS30A 17574 L24-021025
Thread Information
Users Browsing this Thread
Similar Threads
  1. Slick HD 240Z video
    By Inf in forum Open S30 Z Discussions
    Last Post: 06-05-2009, 04:38 PM
  2. whats wrong with splitfires and slick 50?
    By ZcarsRock in forum Help Me !!
    Last Post: 05-04-2004, 02:49 PM
  3. Wheels and Grooved Slick Tyres Wanted Brisbane
    By 260DET in forum Australia and New Zealand
    Last Post: 03-07-2004, 05:45 PM
Bookmarks
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
