Results 1 to 11 of 11
Thread: Help Needed Identifying This Tool Kit
  1. #1
    Registered User
    Member ID
    CZCC-17425
    Join Date
    Jul 2008
    Location
    Rochester, NY
    Posts
    47
    Default Help Needed Identifying This Tool Kit
    Hoping someone on the forum can match this Nissan Tool kit with the appropriate car! I have been through the forums regarding the various tools and kits available for the S30 but could not find any reference to an "assembled kit" available from Nissan. Also looked through my parts manual and microfiche I have for various other older Nissan and Datsun models but could not find any picture or reference to the kit I have posted in the pictures below. Can anyone shed some light on this?
    Kit looks to never have been used and contains the following:
    (1) Philips head screwdriver (stamped Nissan)
    (1) Slot head screwdriver (stamped Rabit)
    (1) feeler gauge - (stamped SD - contains a single feeler gauge marked .35mm)
    (1) Crescent wrench - 250mm (stamped Nissan Motor)
    (1) Pliers - (Stamped Nissan)
    (1) 5Pc Set wrenches - (Stamped SANKI)
    (1) Canvas bag - Measures about 6.5" x 13" (Stamped Nissan Motor)
    Thanks!
    Sam
    Click image for larger version.
ID:	74158Click image for larger version.
ID:	74159Click image for larger version.
ID:	74160Click image for larger version.
  2. #2
    Jim Arnett jfa.series1's Avatar
    Member ID
    CZCC-22303
    Join Date
    Aug 2010
    Location
    Richardson TX
    Posts
    764
    Default
    I'd suggest that this is something that was sold in the parts dept. and not ever associated with a specific vehicle.
    Jim Arnett
    HLS30-15320 12/1970, original owner
    L24-020208 (original)
    IZCC Original Owner Registry #53
  3. #3
    Registered User
    Member ID
    CZCC-17425
    Join Date
    Jul 2008
    Location
    Rochester, NY
    Posts
    47
    Default
    Quote Originally Posted by jfa.series1 View Post
    jfa
    That's what I suspected. The fiche on all of the vehicles I researched only showed individual tools. No kits. I also took a look at the recomended spark plug gaps on the various Datsun/Nissan engines to determine if the .35mm was specific to any particular model. Then I realized that .35mm is way to small a gap for ANY engine. It's also to tight for points. Not sure what this feeler gauge could have been used for.
  4. #4
    Registered User CanTechZ's Avatar
    Member ID
    CZCC-8626
    Join Date
    Jun 2005
    Location
    Chilliwack, BC
    Age
    59
    Posts
    101
    Default
    Quote Originally Posted by wavemux View Post
    jfa
    ... I also took a look at the recomended spark plug gaps on the various Datsun/Nissan engines to determine if the .35mm was specific to any particular model. Then I realized that .35mm is way to small a gap for ANY engine. It's also to tight for points. Not sure what this feeler gauge could have been used for.
    Valve adjust? I don't remember the exact spec.
    Mike
    '70 240Z - (HLS30-06521) restoring stock, owned since '78
    http://www.classiczcars.com/photopos...r=8626&cat=500
    '13 Audi A5 S-Line
    '04 GMC Sierra SLT Quad Cab
    '88 Suzuki Samurai - SPOA, 1.6L EFI, 31" Mud Kings, 5:13's, Custom Bush Bar, CRX Seats.
    '91 Suzuki Samurai - 2" Body Lift, Smittybilt Bumper, Warn 6000, Prelude Seats. - Sold
    '80 Suzuki LJ80 project - Sold
  5. #5
    Registered User
    Member ID
    CZCC-17425
    Join Date
    Jul 2008
    Location
    Rochester, NY
    Posts
    47
    Default
    Correction, the feeler gauge is actually .35 Inches not mm. Makes more sense as a spark plug gap now!
  6. #6
    Registered User Bonzi Lon's Avatar
    Member ID
    CZCC-11300
    Join Date
    Apr 2006
    Location
    Kingman, Kansas
    Age
    64
    Posts
    1,155
    Default
    My 68 Roadster came with that bag & a (lime) green sheet stating the contents.
    Datsun Fairlady Tool Kit
    1 Spark Plug Wrench / For removing spark plugs
    2 Wheel Nut Wrench / For tightening wheel nuts
    3 Body Jack with Lever / For lifting vehicle
    4 Tool Bag / For Containing above Tools
    Nissan Motor CO., LTD
    Bonzi Lon
    1973 HLS30-168500
    1968 SPL311-18100
    1969 HLS30-000110 SOLD Shipped to Dubai UAE
    CZCC#11300
    Ones and Zeros
    "We drive only blue cars." Dishwalla
  7. #7
    Rust Free'ish zKars's Avatar
    Member ID
    CZCC-12190
    Join Date
    Jul 2006
    Location
    Calgary, AB Canada
    Posts
    1,256
    Default
    jfa
    Its the dizzy point gap feeler gauge. I know that's pretty old technology, but come on gang!
    I knew I was destined to be a Datsun mechanic when I discovered by thumbnail was 0.35 mm thick about a 100 years ago...
    Blue likes this.
    Jim
    73 240Z HLS30 149331
    69 510 PL510 77603
    www.zKars.com
    www.calgaryzclub.ca
    Reference materials
    www.xenonS30.com
  8. #8
    Her Majesty the 26th 26th-Z's Avatar
    Member ID
    CZCC-4148
    Join Date
    May 2003
    Location
    Sarasota, Florida
    Age
    66
    Posts
    3,854
    Default
    Nobody referenced this old thread: http://www.classiczcars.com/forums/m...early-car.html
    Enjoy the Ride
    HLS30-00026
    HLS30-00027
    http://home.earthlink.net/~cwenzel/index.html
    Go Gators
    Go Butler Bulldogs
  9. #9
    Nova Scotia,Canada,Earth Blue's Avatar
    Member ID
    CZCC-7641
    Join Date
    Jan 2005
    Location
    NS
    Posts
    4,085
    Default
    Wavemux.... are you in telecomms with a handle like that?
    There is scarcely anything in the world that some man cannot make a little worse, and sell a little more cheaply.
    The person who buys on price alone is this man's lawful prey.
    John Ruskin (1819 - 1900)
    ZCars in Eastern Canada seaport ready for shipment to Europe
    http://ZSportCanada.com
  10. #10
    Registered User
    Member ID
    CZCC-17425
    Join Date
    Jul 2008
    Location
    Rochester, NY
    Posts
    47
    Default
    Quote Originally Posted by Blue View Post
    Blue:
    Absolutely! I've had "wavemux" as a handle since 1998 and you are the ONLY person who has ever made the connection! wavemux was actually the name of a line of telecom equipment manufactured by Pirelli (same company that makes tires) back in the 90's.
  11. #11
    1978 280Z (stock) TomoHawk's Avatar
    Member ID
    CZCC-2169
    Join Date
    May 2002
    Location
    NorthCoast, Ohio
    Age
    58
    Posts
    6,497
    Default
    I remember Wavemux now...
    Remind me to add a spark plug gapping gauge to my tool roll.
    BTW- are those cheapie ROUND gap tools accurate? The ones with the increasing thickness...
    Drive Responsibly.
    enjoy classic Rock music.
Thread Information
Users Browsing this Thread
Similar Threads
  1. Help needed identifying front brake calipers
    By mikemerkury in forum Wheels, Tires and Brakes (S30)
    Last Post: 05-25-2009, 04:37 PM
  2. I need help identifying this oil pan.
    By Twentysixouncer in forum Open Discussions
    Last Post: 03-13-2009, 08:17 AM
  3. Replies: 5
    Last Post: 04-08-2008, 07:20 PM
  4. Help Needed Identifying Mileage!
    By Schev in forum 1st Generation Z (S30)
    Last Post: 08-17-2004, 05:40 PM
Bookmarks
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
