Results 1 to 6 of 6
Thread: Early '72 wheel cylinder problem
  1. #1
    Registered User siteunseen's Avatar
    Member ID
    CZCC-24724
    Join Date
    Jul 2011
    Location
    Alabama
    Posts
    1,967
    Default Early '72 wheel cylinder problem
    I've bought 2 new ones from rockauto.com but the hardline position is off from the OE ones. I'm going to try and figure a way of making mine screw in by bending the ends that go in the wheel cylinders. If someone had a picture of the routing they used I would appreciate being able to see how it's best done. Hopefully it's an easy job but I've never bent a brake line on purpose so I need help on this.
    Thanks,
    Cliff
    1972 240Z #918 New Sight Orange
    1977 280Z #305 Light Blue Metallic
    1972 240Z #110 Persimmons Red
  2. #2
    Rust Free'ish zKars's Avatar
    Member ID
    CZCC-12190
    Join Date
    Jul 2006
    Location
    Calgary, AB Canada
    Posts
    1,256
    Default
    This threaed has some help for you I hope that shows the changes in the slave cylinders.
    http://www.classiczcars.com/forums/w...eft-right.html
    You are faced with bending your current lines or creating new ones.
    Jim
    73 240Z HLS30 149331
    69 510 PL510 77603
    www.zKars.com
    www.calgaryzclub.ca
    Reference materials
    www.xenonS30.com
  3. #3
    Member ID
    CZCC-24724
    Join Date
    Jul 2011
    Location
    Alabama
    Posts
    1,967
    Default
    Kinda hits on my problem and maybe offers an idea. Maybe I could combine the new cylinders with the older housing and not have to bend my lines????
    I originally was wondering if I do bend them, should I go behind the strut towards the rear of the car or bend them around towards the front? I really don't like the idea of going anywhere around the square 4 bolt hub? which would happen if I went towards the front of the car. Also there'd be a sharp bend at the housing where the line screws in if I went forward.
    I could shape a piece of clothes hanger and have 2 made I guess. Decisions, decisions, but these are MY lifes worst at the moment.
  4. #4
    Nova Scotia,Canada,Earth Blue's Avatar
    Member ID
    CZCC-7641
    Join Date
    Jan 2005
    Location
    NS
    Posts
    4,085
    Default
    I'd make new ones. Use that more pliable line from FedHill. I think 1 foot lengths pre terminated do the trick.
    There is scarcely anything in the world that some man cannot make a little worse, and sell a little more cheaply.
    The person who buys on price alone is this man's lawful prey.
    John Ruskin (1819 - 1900)
    ZCars in Eastern Canada seaport ready for shipment to Europe
    http://ZSportCanada.com
  5. #5
    Member ID
    CZCC-24724
    Join Date
    Jul 2011
    Location
    Alabama
    Posts
    1,967
    Default
    Thank you zKars & Blue, that's my back up plan.
    After a few beers and a better attitude I went back and swapped the driver's side to the passenger's side brake lines. I only have to straighten out a "c" bend to an "r" and it'll run behind the strut. Lucky idea but too many beers to fool with it tonight. I'll put up some pictures tomorrow.
    Thanks Guys!
    I googled Happy Lemon. They have a "Lemon Honey with Jelly Balls", my bulldog's name is Jelly.
  6. #6
    Member ID
    CZCC-24724
    Join Date
    Jul 2011
    Location
    Alabama
    Posts
    1,967
    Default
    Success! Swapping the hard lines from one side to the other really did help. Very little bending, I promise.
    Attached Thumbnails Attached Thumbnails Click image for larger version.
ID:	74223   Click image for larger version.
Thread Information
Users Browsing this Thread
There are currently 1 users browsing this thread. (0 members and 1 guests)
Similar Threads
  1. Issue with early Tokico brake master cylinder
    By larryw in forum Wheels, Tires and Brakes (S30)
    Last Post: 09-11-2011, 11:44 AM
  2. wheel cylinder
    By zhead240 in forum Wheels, Tires and Brakes (S30)
    Last Post: 06-12-2011, 10:17 AM
  3. Wheel cylinder
    By Pomorza in forum Help Me !!
    Last Post: 10-21-2009, 02:52 PM
  4. early 240z brake master cylinder
    By DRBall in forum Wheels, Tires and Brakes (S30)
    Last Post: 05-03-2008, 09:35 AM
  5. Early Brake Master Cylinder
    By psdenno in forum Wheels, Tires and Brakes (S30)
    Last Post: 08-16-2007, 05:03 AM
Bookmarks
Bookmarks
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
