Results 1 to 24 of 24
Thread: Ramp recommendation?
  1. #1
    '75 280z tamo3's Avatar
    Member ID
    CZCC-25433
    Join Date
    Oct 2011
    Location
    San Jose, CA
    Posts
    259
    Default Ramp recommendation?
    Hi,
    A lot of folks lower your car. In order to lift up, you might need some low profile ramp.
    I notice that low profile ramp is quite expensive. This race ramp cost more than $200.
    Click image for larger version.
    Those ramp are around $40, but it's not low profile.
ID:	74241Click image for larger version.
    I googled and find a lot of people DIY ramp.
ID:	74244Click image for larger version.
ID:	74245Click image for larger version.
ID:	74246Click image for larger version.
    some metal version.
ID:	74248Click image for larger version.
ID:	74249Click image for larger version.
ID:	74250Click image for larger version.
    Those looks professional build.
    I might end up with....
    Once finish using it....
    What low profile ramp do you use???
    '75/280z
  2. #2
    No more body roll! SteveJ's Avatar
    Member ID
    CZCC-5413
    Join Date
    Dec 2003
    Location
    Gainesville, GA
    Age
    54
    Posts
    3,651
    Default
    I went with the two piece Race Ramps. Amazon.com: Race Ramps RR-XT-2 67-Inch XT 2-Piece Race Ramp: Race Ramps: Automotive
    No they aren't the cheapest, but they don't slide, even on my epoxy painted garage floor.
    73 240Z
    74 260Z
    Blue's collection of tech tips - A great place to look for answers
    XenonS30 -The cheap source for FSMs
    Georgia Z Club
    Fiddling with Z Cars - Z car tips & tricks and pictures of my car-loving life.
    Steve's CARtography - Just car pictures.
  3. #3
    Registered User siteunseen's Avatar
    Member ID
    CZCC-24724
    Join Date
    Jul 2011
    Location
    Alabama
    Posts
    1,967
    Default
    I have those Rhino Gear Ramps for $40 from local parts store. My 240's lowered an inch and has a front spoiler, no problem but I kick them under the tires before I drive up, they slide on my garage floor if I don't. I've pretty much started raising it up with a floor jack and then putting them under the tires.
    I just measured them and the flat spot at the high end is 6 1/2" off the ground. http://www.amazon.com/RhinoGear-1190...hino+gear+ramp
    1972 240Z #918 New Sight Orange
    1977 280Z #305 Light Blue Metallic
    1972 240Z #110 Persimmons Red
  4. #4
    Registered User LeonV's Avatar
    Member ID
    CZCC-19146
    Join Date
    Apr 2009
    Location
    Bay Area, CA
    Posts
    1,961
    Default
    Some chunks of 2X4.
    2/74 260Z
  5. #5
    Registered User rossiz's Avatar
    Member ID
    CZCC-30163
    Join Date
    Feb 2014
    Location
    Seattle, WA
    Age
    53
    Posts
    323
    Default
    i have the same $40 metal ramps - they work fine on an exterior concrete driveway (brush finish)
    i have the eibach progressive lowering springs, so about 2" lower than stock, no front air dam.
    tricky part is getting up on them when you're alone - i use a mirror to see when i'm up on the flat spot (actually a slight hollow). you can actually feel when the wheels drop in, but the fear of dropping off the back makes me want to watch!!
    '78 280z - Daily driver/work in progress...
  6. #6
    '72 240Z(G) 3.2L
    Member ID
    CZCC-7328
    Join Date
    Nov 2004
    Location
    MA
    Age
    70
    Posts
    1,074
    Default
    I'm confused. Why not just jack the car up and then use jack-stands?
    A whole lot cheaper.
    And I do know all about a lowered Z since both the street and race 240Z have just over 3 inches of clearance at the middle of the engine cradle support assembly and the twin exhaust pipes on the race car might be just at 3 inches if that.
    The race car has a removeable front spoiler as it would never be able to go up a ramp without scrapping.
    if a little knowledge can make you dangerous, I'm a little dangerous
  7. #7
    Registered User Walter Moore's Avatar
    Member ID
    CZCC-3035
    Join Date
    Oct 2002
    Location
    Indianapolis
    Posts
    1,833
    Default
    I haven't used ramps since I bought a house with a garage and concrete floor. We used to use ramps when I lived with my parents on the gravel floor of their carport. Personally, I don't trust them. (ramps)
    However while my imitation BRE spook is high enough off the floor to clear nearly all curbs, and parking lot bumpers, but there is just barely enough room under it to wiggle a floor jack down the center of the car to lift the front end by the cross-member. It seems to me that if the car was lowered even a little I would never be able to lift the car in the "usual" way.
    Maybe that is why people use ramps.
    '71 240Z, Because any fool can drive fast in a straight line.
  8. #8
    Admin Mike's Avatar
    Member ID
    CZCC-4
    Join Date
    Feb 2000
    Location
    Seattle, WA
    Age
    50
    Posts
    6,070
    Default
    I can't jack the front of my car because of my front spoiler. The problem is getting the jack far enough inside so I can use the long handle to pump the jack. I've resorted to using the stock body jack first and then sliding my jack far enough in so I can get to the center mount under the front cross member. If I had ramps it would be a heck of a lot easier. Only problem with ramps is that you cant remove the wheels.
    The race ramps seem pretty sweet.
    Mike
  9. #9
    Member ID
    CZCC-24724
    Join Date
    Jul 2011
    Location
    Alabama
    Posts
    1,967
    Default
    I have to remove that "cup" on my floor jack so there's nothing but a flat square on there, pump it up a few times before shoving it under the car. The rear is even tougher but I've done it so many times it's routine now.
    I use ramps as much as I can because with stands there's no weight on the suspension so the bushings and tie rods don't look too comfortable to me.
    I raise mine up to keep from bending over so much working on the motor, back aches a lot less.
  10. #10
    Boat Anchor Repairman Captain Obvious's Avatar
    Member ID
    CZCC-24608
    Join Date
    Jul 2011
    Location
    Philadelphia, PA
    Posts
    1,845
    Default
    I used to drive my 300ZX up on a pair of 2x12 slabs just so I could get enough room under it to then use a floor jack. The extra inch-n-a-half lift was just enough room to get my floor jack under the center front onto the jack point. The first bunch of pumps were still very short because the handle hit the lower lip of the facia.
    That was a pain in the butt.
  11. #11
    Member ID
    CZCC-19146
    Join Date
    Apr 2009
    Location
    Bay Area, CA
    Posts
    1,961
    Default
    Quote Originally Posted by Captain Obvious View Post
    Exactly! I have to do that with the Z and even my bone-stock S2000. It just adds one step to the process, you get used to it.
    2/74 260Z
  12. #12
    Member ID
    CZCC-30163
    Join Date
    Feb 2014
    Location
    Seattle, WA
    Age
    53
    Posts
    323
    Default
    i have an inexpensive (harbor freight) floor jack with low-clearance lift point - works great for getting the car way up on jack stands. with my stock front valence and the eibach progressive lowering springs it juuuust squeaks under in the front and i need to go in from the diagonal to have handle pump clearance - the first few pumps are tiny, but as the car goes up i gradually move up to full swing of the handle.
    the ramps are super quick/easy to do a quick job like swapping out the pre-pump fuel filter (a regular task for me). the advantage of ramps (and the reason i bought them) is that you can lift the car with the suspension loaded, so things like sway bar, control arm bushings, etc. can be set & torqued correctly under load.
    jack stands enable the opposite - letting the wheels drop to swap suspension/wheels/etc.
    just a different tool for a different job.
    and for me, the ramps are quicker to pull out and roll up onto (i store them under the porch) vs. my jack and stands, which are in the shop, so the lazy factor comes into play...
  13. #13
    Member ID
    CZCC-24608
    Join Date
    Jul 2011
    Location
    Philadelphia, PA
    Posts
    1,845
    Default
    Quote Originally Posted by LeonV View Post
    Nice! I glued non-slip rubber mat to the bottom of mine so I don't chase them around the garage with the car. I'll take a pic if I get a chance. Now that the ZX has been replaced with the Z, the wood "ramps" don't get much use.
  14. #14
    Member ID
    CZCC-19146
    Join Date
    Apr 2009
    Location
    Bay Area, CA
    Posts
    1,961
    Default
    Yet another great idea! As long as I have some momentum before hitting the wood, I typically don't have issues getting up on them. With that said, rossiz makes a good point, and most of the time I work on my cars at the shop anyway where I have access to lifts and whatnot.
    2/74 260Z
  15. #15
    Member ID
    CZCC-5413
    Join Date
    Dec 2003
    Location
    Gainesville, GA
    Age
    54
    Posts
    3,651
    Default
    One more thing I should mention about the Race Ramps is that they are VERY light. My wife has no problems whatsoever in lining up the ramps for me to drive up.
    73 240Z
    74 260Z
    Georgia Z Club
  16. #16
    Member ID
    CZCC-24608
    Join Date
    Jul 2011
    Location
    Philadelphia, PA
    Posts
    1,845
    Default
    Lucky dog! In my next life I'm gonna have a lift.
    That, and all the whatnots I can stuff into my toolbox.
    Here's my nyet-skid ramps:
    Used a very thin coat of that polyurethane based water curing glue. Elmers and Gorilla snot both make the stuff. Best thing I've found for this kind of application. Don't use too much or it foams and expands. Very thin coat.
  17. #17
    Registered User
    Member ID
    CZCC-30732
    Join Date
    Aug 2014
    Location
    Central Ohio
    Posts
    35
    Default
    A friend of mine back in the 70's had the cheap metal ones. Collapsed while he was under the car and killed him. Don't buy cheap metal ramps!
  18. #18
    Member ID
    CZCC-5413
    Join Date
    Dec 2003
    Location
    Gainesville, GA
    Age
    54
    Posts
    3,651
    Default
    Quote Originally Posted by JR Ohio View Post
    That's why I grew tired of rolling the dice on my metal ramps and bought the Race Ramps. Plus the Race Ramps are taller than most any other ramp on the market. An extra inch can make all the difference.
    73 240Z
    74 260Z
    Georgia Z Club
  19. #19
    Admin Mike's Avatar
    Member ID
    CZCC-4
    Join Date
    Feb 2000
    Location
    Seattle, WA
    Age
    50
    Posts
    6,070
    Default
    Quote Originally Posted by SteveJ View Post
    Mike
  20. #20
    Member ID
    CZCC-19146
    Join Date
    Apr 2009
    Location
    Bay Area, CA
    Posts
    1,961
    Default
    Nicely done Captain!
    Damn. That's why I've always used scissor jacks underneath metal ramps if I'm ever working underneath them.
    2/74 260Z
  21. #21
    Member ID
    CZCC-5413
    Join Date
    Dec 2003
    Location
    Gainesville, GA
    Age
    54
    Posts
    3,651
    Default
    Quote Originally Posted by Mike View Post
    Thank you. I hate it when a perfectly good straight line is neglected.
    73 240Z
    74 260Z
    Georgia Z Club
  22. #22
    Member ID
    CZCC-30163
    Join Date
    Feb 2014
    Location
    Seattle, WA
    Age
    53
    Posts
    323
    Default
    that's a sobering post...
    while there are stronger ramps out there, our cars are pretty light and the ramps are only carrying one wheel load (roughly a quarter of the car weight).
    i don't think i'd be rolling my old '69 skylark up on these (loved that car) but i'm feeling pretty far below the limits with a z. also, i believe the structure of a pressed metal ramp is highly dependent on its geometry, so it's critical that the ramps are on a solid, level surface. if they are allowed to distort during loading due to uneven surface or a portion sinking in to softer material (hot asphalt) then yes, once they lose their design geometry they can collapse.
    i've heard of people being crushed when jack stands fell over - again, if not loaded evenly, say perhaps with the frame rail sitting off-center in the stand jaw, or if allowed to sink into a soft surface they will want to tilt and can collapse quite suddenly as well.
    i wouldn't exactly call using a ramp correctly, for the proper weight rating to be "rolling the dice".
  23. #23
    Member ID
    CZCC-24608
    Join Date
    Jul 2011
    Location
    Philadelphia, PA
    Posts
    1,845
    Default
    JR, Sorry to hear about your friend. Agreed. Don't buy cheap metal ramps!
    And SteveJ & Mike, That was awesome.
  24. #24
    Member ID
    CZCC-5413
    Join Date
    Dec 2003
    Location
    Gainesville, GA
    Age
    54
    Posts
    3,651
    Default
    Quote Originally Posted by rossiz View Post
    The stamped steel ones like I used to have did not utilize any cross bracing. They were getting old, and I don't know how much corrosion they could tolerate. Unless I could accurately inspect them, I do believe I was incurring more risk than I would have liked.
    73 240Z
    74 260Z
    Georgia Z Club
Thread Information
Users Browsing this Thread
Similar Threads
  1. Oil recommendation
    By Zu Zu in forum Engine and Drivetrain (S30)
    Last Post: 02-24-2013, 03:43 PM
  2. Silver Paint Recommendation?
    By tlorber in forum Body and Paint (S30)
    Last Post: 09-18-2011, 05:47 AM
  3. Machine shop recommendation
    By mbarjbar in forum Engine and Drivetrain (S30)
    Last Post: 11-15-2010, 08:59 PM
  4. Vendor Recommendation
    By tlorber in forum Suspension and Steering (S30)
    Last Post: 12-16-2009, 01:43 PM
Bookmarks
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
