Results 1 to 4 of 4
Thread: Fuel pump parts interchange?
  1. #1
    Registered User NVZEE's Avatar
    Member ID
    CZCC-30407
    Join Date
    Apr 2014
    Location
    Nevada
    Posts
    24
    Default Fuel pump parts interchange?
    Does anyone know if the internals from 240Z Nikki and Kyosandenki pumps, particularly diaphragms, will swap? It might help expand rebuild options is why I ask. Thanks!
    1972 240Z
  2. #2
    Registered User
    Member ID
    CZCC-24523
    Join Date
    Jun 2011
    Location
    Canada
    Posts
    56
    Default
    Quote Originally Posted by NVZEE View Post
    You might want to include the Ampco fuel pump which was part number 17010-N3625 as well. As a rule, interchangeability is by the brand, but this is a great question. I have all three kinds on the shelf, but have never replaced the diaphragm. The fiche suggests that the part number for the diaphragm changed after 7/73 and does not fit to the former fuel pump. The later fuel pump, part number 17010-N3625 shows fitting an L26 from 11/73 on. It could be possible that the 260Z fuel pump would be the Ampco brand and not the Nikki brand of earlier Z cars. The Ampco pump I have could also be an aftermarket pump of the era, long before the Kyosan model.
  3. #3
    Member ID
    CZCC-30407
    Join Date
    Apr 2014
    Location
    Nevada
    Posts
    24
    Default
    Answering my own question here - in a word, no. The OEM replacement diaphragm I got from Courtesy fits the Nikki but not the Kyosan because of a design difference in the rod that connects to the pump lever. I also was able to compare the new diaphragm with a 510 Nikki and it looks like the innards could be swapped, as some ebay listings for new 510 pumps suggest. The first photo compares Nikki 510 (L), Nikki replacement, and Kyosan. The difference in rod style between the 2 Nikkis doesn't seem to matter. The second pic shows why the thicker Nikki rod design doesn't fit the Kyosan pump.
    Click image for larger version.
ID:	74837Click image for larger version.
    Reason for all this in the first place is I was hoping to rebuild my non-op Kyosan on the car rather than replacing it. The massive, non-dealer AC compressor bracket blocks getting the pump out without removing all the AC trappings first, including the refrigerant. PITA. Yes, an electric pump is an option being considered.
    1972 240Z
  4. #4
    Registered User siteunseen's Avatar
    Member ID
    CZCC-24724
    Join Date
    Jul 2011
    Location
    Alabama
    Posts
    1,967
    Default
    That was a huge PAIN for me! I just had bought the car and got one from O'reilly's. The stamped together one without screws. I had to take that front bracket loose, take off the fan, the bottom radiator hose and the bottom bracket to the alternator. I may have even pulled the alternator altogether! Can't remember, I got a little tipsy doing that job.
    1972 240Z #918 New Sight Orange
    1977 280Z #305 Light Blue Metallic
    1972 240Z #110 Persimmons Red
Thread Information
Users Browsing this Thread
Similar Threads
  1. Need help with fuel pump on a 1973 240z (electrical pump)
    By DRIFT10 in forum Open S30 Z Discussions
    Last Post: 09-22-2014, 10:48 PM
  2. Parts interchange. 240 to 260z?
    By rubrbulits in forum Open S30 Z Discussions
    Last Post: 02-19-2010, 10:58 PM
  3. I have a aftermarket fuel pump. Do I need the stock electric pump?
    By Bobby_Lee in forum Engine and Drivetrain (S30)
    Last Post: 03-23-2006, 01:10 PM
  4. Fuel pump interchange
    By 78 280zcar in forum Help Me !!
    Last Post: 12-17-2005, 02:51 PM
  5. weber and Mikuni--do any parts interchange?
    By datfreak in forum Carburetors (S30)
    Last Post: 07-03-2004, 12:57 AM
Bookmarks
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
