Results 1 to 14 of 14
Thread: Steel wheels for OEM hubcaps.
  1. #1
    Registered User
    Member ID
    CZCC-30894
    Join Date
    Oct 2014
    Location
    Philadelphia
    Age
    52
    Posts
    9
    Default Steel wheels for OEM hubcaps.
    Good morning- new member, first post.
    After a long search I finally came across my Z project- a low rust, relatively unmolested 71 240z.
    It came wi horrible mags, and I'd like to install the original factory hubcaps (already have a set). Are there any aftermarket steel wheels with proper bolt pattern and offset? I don't need OEM wheels- but I definitely want OEM fit.
    Any thoughts?
    Andy
  2. #2
    Registered User Z fan's Avatar
    Member ID
    CZCC-30562
    Join Date
    Jun 2014
    Location
    Maple Lawn MD
    Posts
    92
    Default
    Go with period style Libra replicas , better choice since you are not after a 100% original car.
  3. #3
    Registered User
    Member ID
    CZCC-30894
    Join Date
    Oct 2014
    Location
    Philadelphia
    Age
    52
    Posts
    9
    Default
    Are these rims? Where would I find them?
  4. #4
    Registered User
    Member ID
    CZCC-30894
    Join Date
    Oct 2014
    Location
    Philadelphia
    Age
    52
    Posts
    9
    Default
    Ok- just found them. This isn't what I'm looking for. I'm trying to find a straight forward pressed steel wheel that will take the original Z hubcaps.
    Thanks!
  5. #5
    Registered User siteunseen's Avatar
    Member ID
    CZCC-24724
    Join Date
    Jul 2011
    Location
    Alabama
    Posts
    1,967
    Default
    The bolt pattern is 4-114.30 with 195/70-14 tire size. You might could find some on e-bay? or call Direct Tire or Tire Rack.
    Seems like I've read an older Altima's spare fits our cars.
    1972 240Z #918 New Sight Orange
    1977 280Z #305 Light Blue Metallic
    1972 240Z #110 Persimmons Red
  6. #6
    Registered User
    Member ID
    CZCC-29189
    Join Date
    Apr 2013
    Location
    Farmington, MI
    Age
    35
    Posts
    131
    Default
    Aside from bolt pattern and wheel size, what the OP needs is the diameter of the part of the wheel that the hubcap clips into. I can measure this later today, although I have 1973 wheels which are 4x114.3mm, 14x5" (yours are probably 4.5" wide) and I have the orange-centered, "Z" hubcaps. Do you have the hubcaps with the large chrome D in the center? Here are a couple pics:
    70-71 style:
    Click image for larger version.
    72-75 style:
    (sorry, don't know why those are posting as different sizes - here's the link to the site with both pics: Details About 240Z Hubcaps)
    It may just be more correct/easier to source original wheels that have the correct size, width and offset.. unless they're prohibitively expensive.
    PS, OEM steel wheels have an offset of +15mm (at least for the 1973) so I believe you'd need a 14x4.5 et15
    PPS - welcome to the forums, and we'd love to see pics! Sounds like you found a great car.
    Brian
    73 240Z HLS30-151534
  7. #7
    Registered User buysell's Avatar
    Member ID
    CZCC-20564
    Join Date
    Dec 2009
    Location
    Iowa
    Posts
    45
    Default
    I think I have 4 steel wheels from an early 260z. I'm not sure of the offsets, but I can check if you are interested.
    -Justin
  8. #8
    Her Majesty the 26th 26th-Z's Avatar
    Member ID
    CZCC-4148
    Join Date
    May 2003
    Location
    Sarasota, Florida
    Age
    66
    Posts
    3,854
    Default
    Osteopath,
    Try the search function on the site and you may find more information. An original steel wheel for your car is part number 40300-E4400 which is a 5-J x 14 size. 40300-E4600 is a 5-1/2 J x 14 optional wheel originally offered. They look like the pictures I have attached - black exterior / silver interior. Originally, the tire offered was a 175 SR-14 tubeless radial or a 175 HR-14. I'm currently not aware that this size is manufactured anymore, however 185 and 195 sizes are available and they fit fine. Wheels were encoded with a date of manufacture. If you are particularly nit-picky, you would want a wheel set date stamped prior to your month and year of manufacture, but once the hubcap is on, no one will be able to discern. I seriously doubt that Nissan has these wheels available so your search is probably going to include eBay and junk yards. Look out for rust. I had my sets refurbished several years ago for about $75 / wheel.
    Attached Thumbnails Attached Thumbnails Click image for larger version.
ID:	74656   Click image for larger version.
ID:	74657   Click image for larger version.
    Enjoy the Ride
    HLS30-00026
    HLS30-00027
    http://home.earthlink.net/~cwenzel/index.html
    Go Gators
    Go Butler Bulldogs
  9. #9
    Registered User
    Member ID
    CZCC-29189
    Join Date
    Apr 2013
    Location
    Farmington, MI
    Age
    35
    Posts
    131
    Default
    ^I believe the 5J wheels became available in 1972. The OP's 1971 car would have been built with 4- J x 14. Although if your very early cars have 5" wide wheels, I could be convinced I'm wrong! My info comes from Arne and he's pretty good with wheel/tire topics. That being said, I don't think the OP is overly concerned about originality, he just wants the OE hubcaps to fit the car.
    Brian
  10. #10
    Member ID
    CZCC-4148
    Join Date
    May 2003
    Location
    Sarasota, Florida
    Age
    66
    Posts
    3,854
    Default
    Yep, I agree. The 4-1/2" wheel is 40300-E4100. My US parts book shows just the 5" and 5-1/2" and my Japanese parts book lists the 4-1/2" wheel for the L20 series cars. It shows the 5" wheel for the L24 series and the 5-1/2" wheel for the PZ series. In terms of fit for the wheel cover, I have never heard of a successful fit for anything other than the stock steel wheel.
    Enjoy the Ride
    HLS30-00026
    HLS30-00027
    Go Gators
    Go Butler Bulldogs
  11. #11
    Registered User
    Member ID
    CZCC-7061
    Join Date
    Aug 2004
    Location
    moreno valley,ca
    Age
    64
    Posts
    4
    Default Re: steel wheels
    I have a set of libre wheels 4sale.....contact me@ chuckster_1254@yahoo.com
Name:	2013-10-23 16.01.58.jpg
  12. #12
    Registered User
    Member ID
    CZCC-29189
    Join Date
    Apr 2013
    Location
    Farmington, MI
    Age
    35
    Posts
    131
    Default
    Quote Originally Posted by The osteopath View Post
    Thanks!
    Just sayin.
    Brian
  13. #13
    Registered User
    Member ID
    CZCC-4680
    Join Date
    Aug 2003
    Location
    Portland, Oregon USA
    Posts
    135
    Default
    What wheels tires and hubcaps came on the 1971 FairladyZ-L car in Japan? Same as 26th-Z posted above?
  14. #14
    Registered User
    Member ID
    CZCC-1812
    Join Date
    Mar 2002
    Location
    Ohio/USA
    Age
    71
    Posts
    169
    Default
    I'll check my 10/69 Fairlady Z-L later on today, when I get time.
    10/69 Fairlady ZL 5-speed
    '72 240Z
    '09 Nissan Altima Coupe
Thread Information
Users Browsing this Thread
Similar Threads
  1. Steel Wheels
    By csp311 in forum Wheels, Tires and Brakes (S30)
    Last Post: 10-07-2010, 03:25 AM
  2. I need a set of steel wheels for 73z
    By manny1973 in forum Open S30 Z Discussions
    Last Post: 11-25-2008, 10:54 AM
  3. 72 Z wheels and hubcaps on Ebay
    By Mat M in forum Open S30 Z Discussions
    Last Post: 07-21-2006, 09:14 AM
  4. Steel Wheels?
    By bobbovine in forum Wheels, Tires and Brakes (S30)
    Last Post: 03-20-2004, 11:19 AM
Bookmarks
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
