Results 1 to 12 of 12
Thread: Crankshaft Pulley Removal
  1. #1
    Registered User
    Member ID
    CZCC-30294
    Join Date
    Mar 2014
    Location
    Vancouver
    Age
    34
    Posts
    125
    Default Crankshaft Pulley Removal
    Hello,
    Trying to install a stock cooling fan to replace the flex lite fan that was in the car when I bought it.
    Once I got the stock fan installed I noticed it is rubbing the A/C portion (3rd row) of the crankshaft pulley. It looks like this third row is actually an add on to the 2 row pulley that is on there. The manual says to use a puller. Just curious if it is the same process with an "add on" pulley?
    I'll try and post a picture later when I'm on my computer.
  2. #2
    Registered User
    Member ID
    CZCC-20445
    Join Date
    Nov 2009
    Location
    long island NY
    Age
    64
    Posts
    125
    Default
    I think there should be a spacer between the fan and water pump. I'm not positive but that would give you a little more clearance if I'm correct. I've worked on a lot of cars so I could be mistaken. You may already have a spacer there.
  3. #3
    Low Budget/High Value
    Member ID
    CZCC-20342
    Join Date
    Oct 2009
    Location
    Washington County, OR
    Posts
    3,629
    Default
    philbar73 might be thinking of the fan clutch. Which you would probably be using if you're going back to stock, since the stock fan won't work without it.
    You didn't mention any details about the car or engine, like year, stock engine, etc.
    I have a ZX motor in the garage with the third pulley. It is attached with 6 bolts to bosses in the second pulley. Nothing to press on to so I'm sure it would fall right off if I removed the six bolts.
    1976 280Z, with some minor modifications
  4. #4
    Registered User
    Member ID
    CZCC-30294
    Join Date
    Mar 2014
    Location
    Vancouver
    Age
    34
    Posts
    125
    Default
    Sorry, 1971 240z. Stock with aftermarket A/C(I think. York unit). The spacer is in there and it still doesn't clear. This pulled looks like ts held on by two bolts. I removed them and gave it a slight tap with a rubber mallet but no movement. Really don't want to be hitting the harmonic balancer. I'll try and get the pictures up soon.
    I guess the AC is coming out (never worked anyhow), or I'll go the electric fan route.
  5. #5
    Registered User Z dreams's Avatar
    Member ID
    CZCC-23169
    Join Date
    Dec 2010
    Location
    Lawton Mich.
    Posts
    82
    Default
    Crank shaft bolt must be removed to remove 3rd pulley.
  6. #6
    Registered User
    Member ID
    CZCC-30294
    Join Date
    Mar 2014
    Location
    Vancouver
    Age
    34
    Posts
    125
    Default
    Click image for larger version.
ID:	74668Click image for larger version.
ID:	74669Click image for larger version.
  7. #7
    Registered User
    Member ID
    CZCC-30294
    Join Date
    Mar 2014
    Location
    Vancouver
    Age
    34
    Posts
    125
    Default
    Z dreams, if that's the case I guess i'm going the electric fan route. I don't think I have a chance of removing that bolt without an impact gun. Using the starter bump method i've seen online seems dangerous for me and my car. Silly question, but it is a standard thread bolt is it not (Counterclockwise to loosen).
  8. #8
    Registered User
    Member ID
    CZCC-21286
    Join Date
    Mar 2010
    Location
    Ontario, Canada
    Posts
    55
    Default
    I recently went through this process (crank bolt removal, followed by pulley removal) with my '72. I considered all of the alternatives and decided to start with my electric impact wrench (1/2" drive, nothing special). Radiator was out of the car, so I had good access to the crank bolt. The cylinder head was off the engine, so no hope of relying on compression to resist torque applied to the bolt. I just put the car in gear and crossed my fingers. The bolt gave way very easily. Despite the high torque used to install this bolt, its threads live in a very clean environment and are unlikely to have rusted (even though the bolt head will probably be very rusty). Mine had clesan threads from top to bottom.
    I used a 26mm, 6-point, non-impact type socket (impact type socket's walls may be too thick to fit into the pulley recess).
    I expect that using a breaker bar instead of an impact wrench will probably require a lot more effort towards keeping the crank from rotating. The 'high-torque chatter' generated by the impact wrench seems to be the key.
    The next 'non-challenge' turned out to be getting the pulley off the crank. Here, too, I was afraid that the pulley would be rust-seized onto the crank snout. Instead, it actually offered very little resistance and slid off quite smoothly. I used a steering wheel puller, with long-ish bolts (M8, IIRC) threaded into the two threaded holes in the pulley hub. Had to use a tap to clean out the pulley hole threads first.
    The engine I was working on was high-mileage and I doubt whether the pulley had ever been removed previously.
    Rossiz posted a nice review of his pulley/timing cover removal process about a month ago, with lots of pictures.
    Your results may vary, of course, but I think you may find it's not so problematic as you're expecting.
  9. #9
    Registered User
    Member ID
    CZCC-21286
    Join Date
    Mar 2010
    Location
    Ontario, Canada
    Posts
    55
    Default
    p.s. The big crank bolt uses regular threads, so you turn CCW to remove.
  10. #10
    Registered User Bonzi Lon's Avatar
    Member ID
    CZCC-11300
    Join Date
    Apr 2006
    Location
    Kingman, Kansas
    Age
    65
    Posts
    1,155
    Default
    The crank bolt is 27mm or 1 1/16th inch. I use the latter, tight fit.
    Bonzi Lon
    1973 HLS30-168500
    1968 SPL311-18100
    1969 HLS30-000110 SOLD Shipped to Dubai UAE
    CZCC#11300
    Ones and Zeros
    "We drive only blue cars." Dishwalla
  11. #11
    Registered User rossiz's Avatar
    Member ID
    CZCC-30163
    Join Date
    Feb 2014
    Location
    Seattle, WA
    Age
    53
    Posts
    323
    Default
    fwiw - i pulled mine with a breaker bar, without any real drama. 148K on the car, pulley was rusty on the outside, bolt was clean on the inside. i had the oil pan off and put a piece of wood between the block skirt and the crank to lock things in place. wasn't a big deal. getting the pulley off took some creativity, as the two threaded holes in the pulley for a pair of puller bolts were mucked up so i had to rig up a makeshift setup with 3 long bolts and some bailing wire wrapped around the outside of the pulley, but it came off with very little resistance.
    don't pry - pull straight off.
    '78 280z - Daily driver/work in progress...
  12. #12
    Registered User
    Member ID
    CZCC-30294
    Join Date
    Mar 2014
    Location
    Vancouver
    Age
    34
    Posts
    125
    Default
    Thanks for the reply guys! I might try and get it off this afternoon. I ended up purchasing a new rad, water pump and some electric fans yesterday so having to remove it is now not needed. I think the A/C is still coming out though.
Thread Information
Users Browsing this Thread
Similar Threads
  1. Crankshaft Pulley
    By barth4567 in forum Open S30 Z Discussions
    Last Post: 10-31-2011, 07:23 AM
  2. Crankshaft pulley nut size?
    By argniest in forum Engine and Drivetrain (S30)
    Last Post: 02-08-2011, 12:45 AM
  3. 82 280zx crankshaft pulley for 78 280z
    By Shade133 in forum Engine and Drivetrain (S30)
    Last Post: 07-20-2010, 01:24 PM
  4. crankshaft pulley
    By moogrr in forum Engine and Drivetrain (S30)
    Last Post: 09-13-2008, 10:05 PM
  5. Replies: 17
    Last Post: 07-11-2007, 03:19 AM
Bookmarks
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
