Results 1 to 12 of 12
Thread: What would cause a fuse to blow?
  1. #1
    Registered User
    Member ID
    CZCC-29788
    Join Date
    Oct 2013
    Location
    new mexico
    Posts
    26
    Default What would cause a fuse to blow?
    I have a 1978 280Z. Tail lights (driving) and side marker lights work fine until car is warmed up (about 20 minutes). After that the fuse blows. Before I start chasing wires I figured I'd ask incase someone has had this problem and can tell me the fix. All other lights (headlights, brakes) are fine. The turn signals don't work either (I've tried using different combo switches with the same results) but they are less of a problem then the back lights going out at night. Thanks
  2. #2
    Registered User rossiz's Avatar
    Member ID
    CZCC-30163
    Join Date
    Feb 2014
    Location
    Seattle, WA
    Age
    53
    Posts
    323
    Default
    on my 78 280 i discovered that all the sockets for the tail lights, markers and directionals were a bit corroded and allowed them to short. take 'em apart, use some sandpaper, some deoxit, some dielectric grease and it'll do wonders. also, while you're in there check that the little center contact (the one on the spring plate) is seated correctly and not shorting to the outside cylinder - i had one of those as well.
    '78 280z - Daily driver/work in progress...
  3. #3
    Registered User
    Member ID
    CZCC-29788
    Join Date
    Oct 2013
    Location
    new mexico
    Posts
    26
    Default
    sounds simple enough to start with. Thanks
  4. #4
    Low Budget/High Value
    Member ID
    CZCC-20342
    Join Date
    Oct 2009
    Location
    Washington County, OR
    Posts
    3,629
    Default
    Seems odd that the fuse blows when the engine warms up. Might just be coincidence. And you didn't say if the lights are on when the engine is warming up. You might leave everything on that would normally be on when the engine is running, except leave the engine dead. That will load the electrical circuit but take out any engine related functions. Although I can only think of one that might cause that. Maybe the floor temperature warning lamp, or its relay. If you have a catalytic converter.
    I assume that the gauge lights go out also? On my 76 they're on the same circuit as the tails.
    1976 280Z, with some minor modifications
  5. #5
    1978 280Z (stock) TomoHawk's Avatar
    Member ID
    CZCC-2169
    Join Date
    May 2002
    Location
    NorthCoast, Ohio
    Age
    59
    Posts
    6,497
    Default
    DeOxit seemed to work wonders on my car. I went through all the connectors behind the glove box, and the whole electrical system just got happier- the lights were brighter, the engine was smoother, etc.
    I had a peculiar problem with one turn signal lately though. the bulb's contact point is rounded, and the socket's contact pad is sort of flat, and after hitting so many bumps, the turn signal would stop- or the two contact points would miss. So I just sanded the contact on the bulb to make it slightly flattened, and I had no problems since.
    This probably isn't related, but the point is that the contact pads in the sockets can move around or 'grow' with corrosion, so it's possible that the vibrations from the engine could be causing a short to develop.
    Could you try the procedure you mentioned with the rear lamp harness disconnected?
    Drive Responsibly.
    enjoy classic Rock music.
  6. #6
    Registered User beermanpete's Avatar
    Member ID
    CZCC-21519
    Join Date
    Apr 2010
    Location
    Northridge, California, U.S.A.
    Age
    56
    Posts
    631
    Default
    Check the wattage ratings on the bulbs while you have them out to clean the sockets. If they are over-sized they will draw more current than the original/specified bulbs and could overload the fuse.
  7. #7
    Registered User
    Member ID
    CZCC-30294
    Join Date
    Mar 2014
    Location
    Vancouver
    Age
    34
    Posts
    125
    Default
    As others have stated. A few horrible connections will increase the resistance in the circuit. The engine probably has nothing to do with it. It is just takes a while for the resistance to build enough heat to blow the fuse. Start at the back and move forward.
  8. #8
    No more body roll! SteveJ's Avatar
    Member ID
    CZCC-5413
    Join Date
    Dec 2003
    Location
    Gainesville, GA
    Age
    54
    Posts
    3,651
    Default
    Quote Originally Posted by HuD 91gt View Post
    No. Increased resistance will not cause a fuse to blow.
    Ohm's Law
    V - Voltage
    I - Current
    R - Resistance
    P - Power
    Any way you cut it, increasing resistance will not increase current. Poor connections, such as the clamps holding the fuse, will cause hot spots. A prolonged hot spot in the fuse box will cause a fuse to fail and possibly cause the fuse box to melt.
    A common problem with the Z cars is that corrosion can form on the sockets for the side markers (and front markers if the gasket is bad or the lens is cracked. As was mentioned, it can drop the resistance in that branch and possibly short out the fuse. The worst case scenario is that you have dropped the resistance, but not enough to be above the curve for the fuse. That, combined with the hot spot scenario described above can really heat things up.
    I agree with Zed Head. The engine running is most likely a red herring. You probably won't have the parking lights on for very long if the engine isn't running. The first recommendation is probably the best. It might also be good to remove the fuse box and soak it in vinegar or a mild rust removing solution such as Evapo-Rust. After that, gently squeeze the clips together so they have better contact with the fuses.
    73 240Z
    74 260Z
    Blue's collection of tech tips - A great place to look for answers
    XenonS30 -The cheap source for FSMs
    Georgia Z Club
    Fiddling with Z Cars - Z car tips & tricks and pictures of my car-loving life.
    Steve's CARtography - Just car pictures.
  9. #9
    Registered User
    Member ID
    CZCC-30294
    Join Date
    Mar 2014
    Location
    Vancouver
    Age
    34
    Posts
    125
    Default
    My physics mind, and my world knowledge are competing and battling for the right answer.
    Corrosion definitely increases resistance… Which combined with the equation completely contradicts why the current would increase. I'm just confused now.
    Using the equation, corrosion would increase the resistance, decrease the current and the only reason the fuse would blow would be a short circuit caused by said corrosion.
  10. #10
    Member ID
    CZCC-5413
    Join Date
    Dec 2003
    Location
    Gainesville, GA
    Age
    54
    Posts
    3,651
    Default
    Corrosion at a connector increases resistance. Corrosion that bridges between the positive and negative terminals in a socket provides a lower resistance path than the bulb does.
    73 240Z
    74 260Z
    Georgia Z Club
  11. #11
    Registered User
    Member ID
    CZCC-23125
    Join Date
    Dec 2010
    Location
    Spartanburg, SC
    Age
    51
    Posts
    468
    Default
    Ah, now that makes sense...
    C
  12. #12
    Registered User
    Member ID
    CZCC-29788
    Join Date
    Oct 2013
    Location
    new mexico
    Posts
    26
    Default
    Ok, so I checked the connectors and bulb plugs. I also checked the fuse box. Nothing looked out of place. All were very clean. I cleaned them anyways. Figured I didn't do much but I decided to let the car idle for about 35 minutes with the lights on. Went back outside after 35 and all the lights were still on.
    Next test will be to drive at night and see if the fuse blows while driving since that is the only time I have had it happen.
Thread Information
Users Browsing this Thread
Similar Threads
  1. Did I blow up the Z Car Registry?
    By djwarner in forum Open S30 Z Discussions
    Last Post: 08-19-2013, 06:17 PM
  2. A question on blow-by
    By Z-Luke in forum Engine and Drivetrain (S30)
    Last Post: 04-21-2010, 03:03 AM
  3. blow through SU carbs?
    By whamo in forum SU Carb Discussions
    Last Post: 12-11-2008, 12:42 PM
  4. Blow-torch and my 240Z.
    By Phacade in forum Introductions and Z Stories
    Last Post: 08-29-2001, 11:18 AM
Bookmarks
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
