Results 1 to 17 of 17
Thread: voltmeter jumps to 16 with RPMs, CHG light flashes
  1. #1
    Rust Inhibitor jeremy93ls's Avatar
    Member ID
    CZCC-29970
    Join Date
    Dec 2013
    Location
    Canton, GA
    Age
    43
    Posts
    19
    Default voltmeter jumps to 16 with RPMs, CHG light flashes
    I took my car out yesterday for a short drive and the first thing I noticed was the BRAKE light inside the speedometer on. I fiddled with the e-brake switch to no avail and checked to make sure the fluids were OK. I stopped at a store a few miles down the road when I got back in and started it, the light went out when the e-brake was disengaged, like normal.
    Later on, the voltmeter gauge caught my eye as it was bouncing from 14v-16+v while driving, causing the CHG light to flash. Returning to neutral or easing along at low RPMs kept the needle about 14 but every time I gave it gas, it would max out and bounce back and forth.
    I crept home watching it bounce around until at one point it just settled down and stayed about 14-15 where it usually sits for the last few miles home.
    I'm on my 2nd rebuilt Hitachi alternator since acquiring the car a year ago and haven't had a bit of trouble out of this one until yesterday. The only thing that might have affected it was that I tightened the alt/fan belt the day before because it was a bit looser than I like. The battery is good and also a year old.
    I took it out for a drive around the block this evening and it acted normal. I was getting a little over 14v at idle straight off the alternator. I then turned my headlights on bright and got a reading of 13.1v at the alternator. A minute or two later, I was getting 12.8 and slowly dropping. By this time the battery was reading 12.5.
    Do I have yet another failing alternator? My 78 has the internal voltage regulator and I'm guessing this is failing. Do you think tightening the belt caused this, somehow? I should have gotten a reading from the alternator when it was surging yesterday but I was more concerned with getting home.
    78 280Z, 4-speed
  2. #2
    Low Budget/High Value
    Member ID
    CZCC-20342
    Join Date
    Oct 2009
    Location
    Washington County, OR
    Posts
    3,629
    Default
    Check the T plug, specifically the S wire. Maybe it has lost contact at the alternator. While you're there, make sure it reads battery voltage with the engine off. Use your meter.
    1976 280Z, with some minor modifications
  3. #3
    No more body roll! SteveJ's Avatar
    Member ID
    CZCC-5413
    Join Date
    Dec 2003
    Location
    Gainesville, GA
    Age
    53
    Posts
    3,651
    Default
    Another possibility is the failure of the internal voltage regulator in your alternator. If you are mechanically inclined, I believe replacements are available. Check the T plug first.
    73 240Z
    74 260Z
    Blue's collection of tech tips - A great place to look for answers
    XenonS30 -The cheap source for FSMs
    Georgia Z Club
    Fiddling with Z Cars - Z car tips & tricks and pictures of my car-loving life.
    Steve's CARtography - Just car pictures.
  4. #4
    Member ID
    CZCC-29970
    Join Date
    Dec 2013
    Location
    Canton, GA
    Age
    43
    Posts
    19
    Default
    The voltage at the S wire in the T plug is identical to the voltage at the battery. The connectors are nice and clean, too. I wiggled the T plug around with the probe inside and the reading never changed so the connection inside there is solid.
    78 280Z, 4-speed
  5. #5
    Member ID
    CZCC-5413
    Join Date
    Dec 2003
    Location
    Gainesville, GA
    Age
    53
    Posts
    3,651
    Default
    Pull the alternator and take it to a shop to be tested. Sometimes their testing equipment will reveal a bad VR.
    73 240Z
    74 260Z
    Georgia Z Club
  6. #6
    Boat Anchor Repairman Captain Obvious's Avatar
    Member ID
    CZCC-24608
    Join Date
    Jul 2011
    Location
    Philadelphia, PA
    Posts
    1,845
    Default
    Quote Originally Posted by jeremy93ls View Post
    I'll put in a third vote for this. The internally regulated system either works, or it doesn't.
    You mentioned your charge lamp flashing yesterday... Does it still work today? The CHG lamp should light up when you turn the key to "ON" before you crank the engine. Does it?
  7. #7
    Member ID
    CZCC-29970
    Join Date
    Dec 2013
    Location
    Canton, GA
    Age
    43
    Posts
    19
    Default
    The charge lamp is working normally now. It lights up just before turning the engine over and then goes out. When you say it either works or it doesn't, I wonder what made it act up temporarily?
    I'll drive around this evening and see if I can get it to fail again.
    78 280Z, 4-speed
  8. #8
    Member ID
    CZCC-24608
    Join Date
    Jul 2011
    Location
    Philadelphia, PA
    Posts
    1,845
    Default
    Wait a minute... Last I heard, you were driving around with your headlights on and your alternator had failed. Your battery voltage was dropping? "A minute or two later, I was getting 12.8 and slowly dropping. By this time the battery was reading 12.5."
    When I said that it either works or it doesn't, I meant that there really isn't much else in the whole design that could be an issue with the internally regulated system. Other than a loose drive belt or a bad connection, about the only thing that can go wrong is inside the alternator itself. The only other thing I could come up with is if your CHG lamp is burned out, there's a chance that your alternator won't get itself up over the hump of producing current. But if your CHG lamp works normal, then that shouldn't be the issue.
    Take it out and have it tested or borrow a known good one if you can and throw it in and see what happens?
  9. #9
    Member ID
    CZCC-29970
    Join Date
    Dec 2013
    Location
    Canton, GA
    Age
    43
    Posts
    19
    Default
    I only turned the headlights on to see if I could get the gauge to jump around again so I could get a voltage reading at the alternator, but it never did. That's when I noticed the battery was slowly dropping voltage.
    I'll get it tested tomorrow and see what happens. Thanks for the troubleshooting advice.
    78 280Z, 4-speed
  10. #10
    Member ID
    CZCC-5413
    Join Date
    Dec 2003
    Location
    Gainesville, GA
    Age
    53
    Posts
    3,651
    Default
    I should be home over the weekend if you need some help. Send me a PM.
    73 240Z
    74 260Z
    Georgia Z Club
  11. #11
    Member ID
    CZCC-24608
    Join Date
    Jul 2011
    Location
    Philadelphia, PA
    Posts
    1,845
    Default
    Glad to (try to) help. My additional advice would be to take it to SteveJ's place and distract him with a Digi-Key catalog. Tell him the centerfold this month is excellent or something.
    Then when he isn't looking, swap your alternator with his.
  12. #12
    Member ID
    CZCC-5413
    Join Date
    Dec 2003
    Location
    Gainesville, GA
    Age
    53
    Posts
    3,651
    Default
    The 74 is still externally regulated. He'd have to dig the one out of the 73, and that one is surrounded by hazards that scare me. It's dodgy at best to attempt that strategy.
    73 240Z
    74 260Z
    Georgia Z Club
  13. #13
    Member ID
    CZCC-29970
    Join Date
    Dec 2013
    Location
    Canton, GA
    Age
    43
    Posts
    19
    Default
    Good idea, Captain. I bet I could swap a 280 alternator in less than 10 minutes.. i've had plenty of practice since getting my Z
    Took it to the local Advance/Autozone/I forget which and it passed. The guy running the test also said the VR either works or doesn't.
    I went ahead and found a cheap rebuilt Hitachi 14185 online and ordered it. I figure for $49, it wouldn't hurt to have an extra one to help with diagnostics.
    78 280Z, 4-speed
  14. #14
    Member ID
    CZCC-24608
    Join Date
    Jul 2011
    Location
    Philadelphia, PA
    Posts
    1,845
    Default
    Well that's sorta too bad that it passed. Makes it harder to find the problem.
    Next thought is that the alternator is doing what is expected of it, but the fusible link connection between the alternator and the battery is shaky. I haven't studied it that closely, but it appears that the alternator will still run certain parts of the car even if that link is gone, but things like the headlights and the FI will run off the battery and not off the alternator. And if that connection is intermittent, you'll get swings on the voltmeter on the dash as the alternator is intermittently presented with the heavy load of the battery. And if that link is making connection, but not a good one, it's likely to heat up right at the connection ends.
    So... You've got four fusible links in the engine compartment on the passenger front wheel well. Three of them are one color and are smaller than the fourth. My 78 FSM is blurry and it's hard to read the wire colors, but I believe the three smaller ones are brown and the fourth larger one I black?
    The one I'm concerned with is the black one. With the engine running and a meter on the alternator output, wiggle that black link around a little and see what the meter does? If that fusible link doesn't make good connection the alternator won't charge the battery correctly.
    If you see anything funky on the meter (heck, even if you don't), pull the link off and make sure everything looks clean and shiny? Not green and crusty. While you're in there pull all the links and make sure they're all nice and clean. Just make sure you don't mix up the colors.
  15. #15
    Member ID
    CZCC-5413
    Join Date
    Dec 2003
    Location
    Gainesville, GA
    Age
    53
    Posts
    3,651
    Default
    I have seen an alternator pass at a parts store, yet I pushed my friend to replace it anyway. Sure enough, his charging problems disappeared.
    I agree with the good Captain. Inspecting the links is a good idea.
    73 240Z
    74 260Z
    Georgia Z Club
  16. #16
    Member ID
    CZCC-29970
    Join Date
    Dec 2013
    Location
    Canton, GA
    Age
    43
    Posts
    19
    Default
    I installed another rebuilt alternator and drove it for about 50 miles today with no problems at all. I hope that's all it needed.
    Yes, 3 brownish and one black in the 78. I've got a spare set of Nissan fusible links in the glove box but haven't used them yet. They're so much smaller in diameter than the original links.. i suppose that wouldn't matter, though.
    78 280Z, 4-speed
  17. #17
    Member ID
    CZCC-24608
    Join Date
    Jul 2011
    Location
    Philadelphia, PA
    Posts
    1,845
    Default
    Cool. I've been continuing to think about this and I'm still thinking you need to take a close look at your fusible links. The more I think about it, the more an intermittent connection to the black link makes sense. Your old alternator tested good. You put in a new one (that's presumably good) and the problem "went away".
    But my concern is that the problem was intermittent all along, right? Sometimes it was fine and sometimes it was screwy?
    I'm worried that the link is currently making a good enough connection that the problem is not bad enough for you to notice, but intermittent connections are like that. Intermittent.
    I guess what I'm saying is that I'm glad you got the car working, but I wouldn't be surprised if in a couple days from now you come back and say it's doing it again. Hoping not, but wouldn't be surprised!
Thread Information
Users Browsing this Thread
Similar Threads
  1. Replies: 4
    Last Post: 06-16-2014, 12:19 PM
  2. 83 280zxt shifter jumps out o f 1st gear
    By Zrod in forum Engine and Drivetrain (280ZX)
    Last Post: 07-01-2009, 10:35 AM
  3. 78 Z jumps out of 1st and 5th
    By MikeZcar in forum Engine and Drivetrain (S30)
    Last Post: 06-09-2006, 09:06 AM
  4. Only one side flashes when hazards are on
    By RWD415 in forum Electrical (S30)
    Last Post: 07-26-2005, 02:05 AM
  5. Engine speed jumps up
    By samwise05 in forum Engine and Drivetrain (S30)
    Last Post: 05-19-2005, 07:22 AM
Bookmarks
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
