Results 1 to 5 of 5
Thread: Dash lights cause fuse to blow.
  1. #1
    Registered User
    Member ID
    CZCC-30908
    Join Date
    Oct 2014
    Location
    Havelock
    Age
    32
    Posts
    2
    Default Dash lights cause fuse to blow.
    Good evening all,
    I've searched through the forum, but can't find a similar issue to mine, so here it goes.
    I've got a 1975 280z, and I'm trying to hunt down an issue that's keeping me from having dash lights. I can turn the headlights on, including the brights, but as soon as I turn the dial for the dash dimmer the wire in the rheostat burns up. If I turn it to the brightest setting (doesn't use rheostat wires, just straight contacts) a few dash lights come on, then the fuse glows red-hot and blows. The wires to the rheostat get pretty hot too, as does the combo switch. The car is all stock electrically, and I've hooked up a test light and there aren't any shorts I can see.
    I've started testing the combination switch, since it's getting warm even with the dash lights off, and found that the green/white wire has continuity to the white/red and solid red wires, and all also have continuity to the metal body of the combo switch. I disconnected the switch and tested it, and no continuity on those points, it's just in the wiring harness itself. White/red and red have continuity prior to the switch, something along the lines of 4-5Kohms. Should these wires have continuity, and what might be my issue? I've checked the car's schematic in a manual I have, and ensured all bulbs are the correct wattage as well. This issue is driving me mad!
    On a side note, my passenger front combination turn/marker light has a corroded socket, but that wouldn't be enough to cause such an issue, could it? Any help is greatly appreciated, I've posted on Ratsun, but no one has responded yet with a solid answer.
  2. #2
    Boat Anchor Repairman Captain Obvious's Avatar
    Member ID
    CZCC-24608
    Join Date
    Jul 2011
    Location
    Philadelphia, PA
    Posts
    1,845
    Default
    Recent discussion on the same issue. Maybe some help in here?
    http://www.classiczcars.com/forums/e...e-melting.html
  3. #3
    No more body roll! SteveJ's Avatar
    Member ID
    CZCC-5413
    Join Date
    Dec 2003
    Location
    Gainesville, GA
    Age
    53
    Posts
    3,651
    Default
    Yep, I thing post #12 might work.
    73 240Z
    74 260Z
    Blue's collection of tech tips - A great place to look for answers
    XenonS30 -The cheap source for FSMs
    Georgia Z Club
    Fiddling with Z Cars - Z car tips & tricks and pictures of my car-loving life.
    Steve's CARtography - Just car pictures.
  4. #4
    Registered User
    Member ID
    CZCC-30908
    Join Date
    Oct 2014
    Location
    Havelock
    Age
    32
    Posts
    2
    Default
    So I've started testing the car per post #12, and the only gauge I have left to pull is the speedometer, I've got a dash-cap so it's causing some difficulty in removing the gauge. I'm hoping to have it out by tomorrow morning, and crossing my fingers that this issue is one of the lights in the speedo. Thanks again for the advice!
  5. #5
    Member ID
    CZCC-24608
    Join Date
    Jul 2011
    Location
    Philadelphia, PA
    Posts
    1,845
    Default
    Good luck and keep us posted!
Thread Information
Users Browsing this Thread
Similar Threads
  1. What would cause a fuse to blow?
    By arts.zccm in forum Electrical (S30)
    Last Post: 10-19-2014, 05:16 PM
  2. Replies: 9
    Last Post: 08-29-2014, 03:48 AM
  3. Parking lights and dash lights out blew fuse
    By Frankensteinz2 in forum Help Me !!
    Last Post: 08-17-2010, 08:24 AM
  4. No Parking Lights/Running Lights/Dash Lights
    By KDMatt in forum Help Me !!
    Last Post: 09-24-2009, 03:32 AM
  5. Fan won't blow, lights wont glow
    By TraeZ in forum Electrical (S30)
    Last Post: 04-26-2006, 02:57 PM
Bookmarks
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
