Results 1 to 20 of 20
Thread: MSA fiberglass bumpers
  1. #1
    Registered User siteunseen's Avatar
    Member ID
    CZCC-24724
    Join Date
    Jul 2011
    Location
    Alabama
    Posts
    1,967
    Default MSA fiberglass bumpers
    If someone who has purchased the 240 ones recently could tell me of the fit and finish of what they have now, I'd appreciate it. I can only find comments, which weren't too good, from 5 years ago. Hopefully they have improved.
    I've found some at ztrix.com but they don't have the bracket landings glassed in, you have to run bolts through them to attach. He makes them for racers. I want the smooth finish like MSA's.
    Thank you for any response,
    Cliff
    1972 240Z #918 New Sight Orange
    1977 280Z #305 Light Blue Metallic
    1972 240Z #110 Persimmons Red
  2. #2
    Registered User madkaw's Avatar
    Member ID
    CZCC-7622
    Join Date
    Dec 2004
    Location
    bloomington IN
    Age
    57
    Posts
    2,288
    Default
    Cliff,
    Recently discovered DatsunZfiberglass . The guy makes it all it seems, but the website kin of sucks. I did e-mail him and he did respond. Might be worth a look
    Steve
    71 240z,bw-5sp 2.4-40 over,balanced,e-88,big valves,ported&polished, stage2,header, triple Mikuni's 40's
    3.90 Subaru STI LSD
  3. #3
    Member ID
    CZCC-24724
    Join Date
    Jul 2011
    Location
    Alabama
    Posts
    1,967
    Default
    Quote Originally Posted by madkaw View Post
    Cliff,
    Wow! Just sent him pictures of what I have. I found his phone number googling "fiberglassfabrication" off an ebay listing. Parkway something or another in New Jersey. He said he sales through distributors but they're out of stock so he's selling direct?
    Thank you Steve. I wanted to ask you about my E88 head I recently bought, valves and what not. When I get these bumpers off my mind I'll send you a PM.
    Ramsey, NJ
  4. #4
    Member ID
    CZCC-7622
    Join Date
    Dec 2004
    Location
    bloomington IN
    Age
    57
    Posts
    2,288
    Default
    Just the fact that he e-mailed me back right away was a plus in my book .
    I've been waiting a week or so for Schneider to call me.
    PM me for a cell number, I hate the messenger on this site.
    Steve
    3.90 Subaru STI LSD
  5. #5
    Member ID
    CZCC-24724
    Join Date
    Jul 2011
    Location
    Alabama
    Posts
    1,967
    Default
    Well that wasn't what I wanted. Bumpers only, no landings. He suggested I use 3M adhesive to hold the bumper to the bracket, not too keen on that.
    So I'm back to ask about MSA's bumpers. Appreciate any input.
  6. #6
    Registered User kacrow76's Avatar
    Member ID
    CZCC-25334
    Join Date
    Oct 2011
    Location
    Kansas
    Age
    51
    Posts
    97
    Default
    I have them on a 76 280. they did take a little work to get them paint ready but not to bad and they bolted right up. hope that helps.
  7. #7
    Frogsquisher Zup's Avatar
    Member ID
    CZCC-8151
    Join Date
    Apr 2005
    Location
    Bentonville, AR.(not Arizona)
    Age
    70
    Posts
    265
    Question
    Not sure why you want fiberglass, but if it is for the black check out---
    FUTOFAB
    Seems the black powdercoat costs will be hard to beat!
    HTH
    Jim D.
    "Zup"
  8. #8
    Registered User EuroDat's Avatar
    Member ID
    CZCC-26512
    Join Date
    Feb 2012
    Location
    The Netherlands
    Posts
    1,420
    Default
    I have one on the fornt of my 280Z. I bought it in Feb 2014.
    Positive:
    Fitted well. Did need a little sanding on the inside line to match passenger side valance.
    Mounting brackets are slotted which allows room for adjustment.
    No pitting in fibreglass surface. I have seen others with a lot of pits in the surface.
    Cheap. Im using it for testing. Plan to buy a harrington SS bumper (much) later when car is resprayed.
    Negative
    It will need some work to look really neat. The end "Caps" are not finished very well.
    Storage scuffs. Will need painting to fix it. Nothing serious, but its visable.
    See photos.
    Click image for larger version.
    Chas
    Chas
    5/77 280Z HLS30 403100 with some modifications
    Original colour: 305 Light Blue. The PO changed it to Red
  9. #9
    Member ID
    CZCC-24724
    Join Date
    Jul 2011
    Location
    Alabama
    Posts
    1,967
    Default
    Those are great prices on chroming but I need to get the holes welded up and a couple of dings out first. I'm wanting to drive this car for a few years then get it painted and the bumpers chromed so this is temporary. I carried my front to a local powder coater yesterday and he told me that it's permanent, no chroming after the powder coating.
    Kacrow76 and Chas, you've pretty much made my decision. I needed to know that they bolted up, all the others are naked bumpers without any mounts built in.
    Thanks for everybodies replies,
    Cliff
  10. #10
    Member ID
    CZCC-26512
    Join Date
    Feb 2012
    Location
    The Netherlands
    Posts
    1,420
    Default
    Hi Cliff,
    Ill try to take a threw photos from behind the bumper later tonight and post them. Give you a bit of an idea what the brackets look like.
    Chas
    Chas
  11. #11
    Member ID
    CZCC-26512
    Join Date
    Feb 2012
    Location
    The Netherlands
    Posts
    1,420
    Default
    I managed to take a couple of snaps of the bumper mounts. Mind you its on a 280Z, so I imagine it will be a little different on a 240Z.
    The slotted mount for the front two mounts should be centered better on the 240Z. Mine are at the inner limit of the slot because I using the old shock mounting points for now.
    I also used bolts with a lock nut in the bumper so I could adjust it easier. You can see them in the side ear photos. The photo also shows the poor finish of the left side end compared to the right which is clean.
    It was a quick and easy mod and I am pretty happy with the end result. Ill fit the air-dam this winter.
    Cheers
    Chas
    Attached Thumbnails Attached Thumbnails Click image for larger version.
ID:	74810   Click image for larger version.
    Chas
  12. #12
    Member ID
    CZCC-24724
    Join Date
    Jul 2011
    Location
    Alabama
    Posts
    1,967
    Default
    Thank you, thank you! I really wanted to see how the wedge shaped landing was made into the fiberglass, your 2nd picture is perfect. That left end looks like an additional piece of fiberglass, hopefully my painter can sand it down enough it won't be too noticeable.
    I will order 1 today. Thanks again.
  13. #13
    Datsun-aholic Dave Patten's Avatar
    Member ID
    CZCC-7498
    Join Date
    Dec 2004
    Location
    New Hampshire
    Age
    63
    Posts
    44
    Default
    Quote Originally Posted by Zup View Post
    FUTOFAB
    HTH
    Jim D.
    "Zup"
    Zup,
    FutoFab has '70-'72 240Z steel F&R bumpers coming November 14th. Available in both chrome ($360/ea) and black powder coat ($240/ea). Ordering is now open.
    These are JDM style w/o holes for rubber face strips.
    Pics of a '70-'72 240Z chrome front (black powder coat is made the same).
Name:	70-72 Datsun 240Z Front Bumper, 1-1000W.jpg
Name:	70-72 Datsun 240Z Front Bumper, 2-1000W.jpg
Name:	70-72 Datsun 240Z Front Bumper, 5-1000W.jpg
Name:	70-72 Datsun 240Z Front Bumper, 3-1000W.jpg
Name:	70-72 Datsun 240Z Front Bumper, 4-1000W.jpg
    Dave Patten, Owner
    Dunbarton, NH 03046
    603-774-6964
    www.FutoFab.com
    Dave@FutoFab.com
  14. #14
    Member ID
    CZCC-24724
    Join Date
    Jul 2011
    Location
    Alabama
    Posts
    1,967
    Default
    Is that price for the rechroming only or is that the for whole bumper? Those look great!
    What sheen would the black powder coated bumpers be? Glossy or not so much? I'm very excited about these, you've made my day.
  15. #15
    Member ID
    CZCC-7498
    Join Date
    Dec 2004
    Location
    New Hampshire
    Age
    63
    Posts
    44
    Default
    Quote Originally Posted by siteunseen View Post
    Prices are for new bumpers, not for plating cost or a rechromed OE piece. They are 100% brand new parts. The quality is exceptional. The prep and chrome work is better that OE.
    I am not sure on the powder coat sheen. I have not seen a sample of the bumper in black. I'll post as soon as they arrive.
    Dave Patten, Owner
    Dunbarton, NH 03046
    603-774-6964
    www.FutoFab.com
    Dave@FutoFab.com
  16. #16
    Registered User Kurbycar32's Avatar
    Member ID
    CZCC-23586
    Join Date
    Feb 2011
    Location
    Manteca, CA
    Posts
    337
    Default
    Any pictures of those on an actual Z? I'm extremely interested
    Early 1974 260z
    https://sites.google.com/a/thecomputerrehab.com/260z/
  17. #17
    Registered User S30Driver's Avatar
    Member ID
    CZCC-21075
    Join Date
    Mar 2010
    Location
    Seattle Washington
    Posts
    163
    Default
    Great looking chrome front bumper.
    May have to rethink my re-chrome of the rear bumper this winter & just buy a new one.
    1977 280z 06/77
  18. #18
    Registered User Jeff G 78's Avatar
    Member ID
    CZCC-7975
    Join Date
    Mar 2005
    Location
    Northville, Michigan
    Age
    54
    Posts
    1,895
    Default
    Hmmm, those Futofab bumpers look really nice and I'm very intrigued by the powdercoated ones. The price isn't bad at all depending on the shipping costs from NH to MI.
    I've been contemplating swapping my park bench '78 bumpers for 240 bumpers for a long time. I've been looking at the MSA fiberglass 240Z bumpers, but here in Michigan, the truck shipping for fiberglass parts from LA makes them cost prohibitive so I've never pulled the trigger. In a few weeks though, I will be in LA for work and I'm seriously considering buying a set. I can ship them back in a truck we'll have out in LA, so shipping would be free. I like the idea of painting the fiberglass bumpers and rear spoiler the same gunmetal gray color as my Panasports, but fiberglass bumpers seem like they would be super fragile and the quality is suspect. Good used 240 steel bumpers are hard to find and I don't really want chrome anyways.
    Dave Patten, any chance of getting custom powdercoat colors? I'm not sure how black bumpers would look with gray wheels.
    Jeff
    IZCC #1285
    '78 280 10:1 CR, Arizona Z Car header, urethane bushings, Tokico springs, Illumina struts, Panasports w/Hankook R-S2 225/50R16 tires, Maxima 105 amp alternator
    http://www.classiczcars.com/photopos...00&ppuser=7975
    '74 260Z BRE look-alike crap can for Optima Batteries ChumpCar World Series Racing racing
    https://www.facebook.com/Jeff.Grauer
  19. #19
    Member ID
    CZCC-7498
    Join Date
    Dec 2004
    Location
    New Hampshire
    Age
    63
    Posts
    44
    Default
    Quote Originally Posted by Jeff G 78 View Post
    We use FedEx on our larger parts. We have a decent rate schedule so shipping doesn't get crazy. Without doing an actual look-up I'd say around $30/ea S&H.
    If anyone wants actual shipping costs, the bumpers are on-line for ordering. Set up your account, put the parts in your cart and head for check-out. The actual shipping charges will calculate before you pay.
    Custom colors could be arranged, but it would be done with my local powder coater. He would have to strip the part first and then recoat it. Likely less than a chrome bumper, but not by very much.
    Dave Patten, Owner
    Dunbarton, NH 03046
    603-774-6964
    www.FutoFab.com
    Dave@FutoFab.com
  20. #20
    Member ID
    CZCC-7975
    Join Date
    Mar 2005
    Location
    Age
    54
    Posts
    1,895
    Default
    Thanks for the reply Dave. I will take a look at the MSA bumpers while in LA, but not get them. I really like your bumpers and will likely hold off until your powder coated ones are available.
    Jeff
    IZCC #1285
Thread Information
Users Browsing this Thread
Similar Threads
  1. Fiberglass bumpers
    By siteunseen in forum Body and Paint (S30)
    Last Post: 09-25-2014, 05:28 PM
  2. Z Store Fiberglass Bumpers
    By Ben's Z in forum Body and Paint (S30)
    Last Post: 03-08-2012, 02:29 PM
  3. How easy is converting 280z bumpers, to a set of 240z bumpers ?
    By 240Z Man in forum Open S30 Z Discussions
    Last Post: 05-29-2010, 05:56 PM
  4. No Bumpers..I need bumpers? Body Kit?
    By Minkee in forum Body and Paint (S30)
    Last Post: 03-24-2006, 07:15 AM
  5. Fiberglass bumpers
    By 62vette in forum Body and Paint (S30)
    Last Post: 01-14-2006, 03:29 AM
Bookmarks
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
