Results 1 to 13 of 13
Thread: Harness rebuild general consensus
  1. #1
    Registered User
    Member ID
    CZCC-26044
    Join Date
    Jan 2012
    Location
    NYC, NY
    Posts
    22
    Default Harness rebuild general consensus
    Hello everyone, looking to tackle the wiring harness soon. What is the general consensus on "refreshing" the harness? I was going to do the following:
    1. extract the pins from the connector unless its a bullet or single terminal.
    2. remove the terminal without cutting the wire with plier or similar tool.
    3. possibly dip in warm water and baking soda to remove oxidation, then use Emory cloth to sand the wire down, if wire is shot then add a piece of wire and shrink wrap(what is the best solution here)?
    4. clamp in new pins.
    5. clean the connector housing with warm water, a brush and degreaser or electrical cleaner.
    6. install the connecter into the new pins and apply some di-electric grease.
    Then finally check for continuity.
    thx!
  2. #2
    Registered User madkaw's Avatar
    Member ID
    CZCC-7622
    Join Date
    Dec 2004
    Location
    bloomington IN
    Age
    57
    Posts
    2,288
    Default
    Usually the harness is okay except for areas subject to heat or direct weather. I would clean and replace only where necessary . Blades or pins I tried cleaning with sandpaper or mini file to get fresh surface- the dielectric grease after that
    Steve
    71 240z,bw-5sp 2.4-40 over,balanced,e-88,big valves,ported&polished, stage2,header, triple Mikuni's 40's
    3.90 Subaru STI LSD
  3. #3
    Nova Scotia,Canada,Earth Blue's Avatar
    Member ID
    CZCC-7641
    Join Date
    Jan 2005
    Location
    NS
    Posts
    4,085
    Default
    I spliced in connectors from one harness to another where required.
    donor harness 280z
    recipient 240z
    Solder and heat shrink did the trick.
    There is scarcely anything in the world that some man cannot make a little worse, and sell a little more cheaply.
    The person who buys on price alone is this man's lawful prey.
    John Ruskin (1819 - 1900)
    ZCars in Eastern Canada seaport ready for shipment to Europe
    http://ZSportCanada.com
  4. #4
    No more body roll! SteveJ's Avatar
    Member ID
    CZCC-5413
    Join Date
    Dec 2003
    Location
    Gainesville, GA
    Age
    53
    Posts
    3,651
    Default
    I think you'd have more success with vinegar than baking soda. The latter requires scrubbing. Actually, a baking soda solution is good for rinsing after using the vinegar.
    Also, if you need new connectors, OEM-Type Bullet & Spade Electrical Connectors for 1960's through 1970's Japanese Vehicles... Bridgestone, Datsun, Hodaka, Honda, Kawasaki, Landcruiser, Suzuki, Tohatsu, VW, & Yamaha has most of the ones you need.
    73 240Z
    74 260Z
    Blue's collection of tech tips - A great place to look for answers
    XenonS30 -The cheap source for FSMs
    Georgia Z Club
    Fiddling with Z Cars - Z car tips & tricks and pictures of my car-loving life.
    Steve's CARtography - Just car pictures.
  5. #5
    Registered User
    Member ID
    CZCC-24523
    Join Date
    Jun 2011
    Location
    Canada
    Posts
    56
    Default
    You should also consider the dry wiring loom tape with no adhesive. There are brands out there such as Plymouth which can be bought in a 1-1/4" width. The heat of the engine bay will make any adhesive tape very tacky which will in turn, attract dirt and debris. Such grime is an enemy of the wiring harness. Nissan used this same tape that the Corvette and Camaro guys use on their vehicles. Buy the smooth kind and not the fabric type. You can tie off the ends with standard 3M adhesive electrical tape to secure it at the ends. Just my two cents!
  6. #6
    Registered User
    Member ID
    CZCC-26044
    Join Date
    Jan 2012
    Location
    NYC, NY
    Posts
    22
    Default
    Thanks everyone, getting excited about this!!
  7. #7
    Registered User er34gtt2000jp's Avatar
    Member ID
    CZCC-8081
    Join Date
    Mar 2005
    Location
    Sacramento CA
    Age
    44
    Posts
    466
    Default
    Quote Originally Posted by redzedsled View Post
    +1 here!
    I got two rolls of this from Eastwood years ago but I don't know if they sell it any more.
  8. #8
    Member ID
    CZCC-5413
    Join Date
    Dec 2003
    Location
    Gainesville, GA
    Age
    53
    Posts
    3,651
    Default
    You can get thinner rolls of the dry wiring loom tape on ebay. I have a bunch in my garage.
    73 240Z
    74 260Z
    Georgia Z Club
  9. #9
    Registered User Stanley's Avatar
    Member ID
    CZCC-24191
    Join Date
    Apr 2011
    Location
    Redondo beach
    Posts
    641
    Default
    Fabric friction tape no good? Damn, I just bought some to tidy up the coil/distributor harness.
    How well does the insulation on the 40 year old wires hold up in the engine bay? Don't know but I'd guess it gets sort of brittle and could crack, leading to shorts or corrosion of the wire, especially if the harness flexes while driving.
    For my 63 Chevy truck, nice new harnesses are available for the entire vehicle, not too expensive. It has a lot less wires, though.
  10. #10
    Registered User
    Member ID
    CZCC-24523
    Join Date
    Jun 2011
    Location
    Canada
    Posts
    56
    Default
    Quote Originally Posted by Stanley View Post
    I did not mean to suggest that dry fabric tape was not a good product. My intention was to suggest what I found to be most accurate for my restoration, and what Nissan used in the day. The smooth type blends well into the existing loom should you decide to do a partial wiring loom restoration. I am sure that the fabric type would look awesome as well, especially where you have used it on the distributor lead.
  11. #11
    Registered User
    Member ID
    CZCC-26044
    Join Date
    Jan 2012
    Location
    NYC, NY
    Posts
    22
    Default
    I am assuming the dry wire tape, has some adhesive in it?
  12. #12
    Rust Free'ish zKars's Avatar
    Member ID
    CZCC-12190
    Join Date
    Jul 2006
    Location
    Calgary, AB Canada
    Posts
    1,256
    Default
    This is the stuff I bought.
    2 Rolls Factory Electrical Non Adheasive Wiring Harness Friction Tape M | eBay
    Decent price and good seller.
    The tape is made by Elliot tape.
    Michigan Tapes | Adhesive Tapes | Adhesives | Detroit Michigan | Auburn Hills
    This product page will give you a good idea of the various types of tapes that are available and their intended usage
    It does not have adhesive, it sticks to itself once wrapped. Electrical tape and its adhesive turns into a gooy mess after a while, and is definitely not the correct product for harness wrapping.
    The ET stuff feels and works like the stock Datsun harness wrap as far as I can tell.
    Jim
    73 240Z HLS30 149331
    69 510 PL510 77603
    www.zKars.com
    www.calgaryzclub.ca
    Reference materials
    www.xenonS30.com
  13. #13
    Registered User
    Member ID
    CZCC-26044
    Join Date
    Jan 2012
    Location
    NYC, NY
    Posts
    22
    Default
    Great, thanks so much. I just purchased it.
Thread Information
Users Browsing this Thread
There are currently 1 users browsing this thread. (0 members and 1 guests)
Similar Threads
  1. Site CONSENSUS on early Z with V8 transplant
    By Z fan in forum Open Discussions
    Last Post: 07-29-2014, 04:52 AM
  2. A general thank you
    By mjr45 in forum Open S30 Z Discussions
    Last Post: 05-18-2011, 08:09 AM
  3. What is the consensus on air dams?
    By ROOPZ in forum Body and Paint (S30)
    Last Post: 05-30-2005, 12:36 PM
  4. General Help needed
    By Viper_1100 in forum Help Me !!
    Last Post: 08-23-2003, 03:54 AM
  5. General car question
    By XYZ in forum Open Discussions
    Last Post: 09-19-2002, 10:01 AM
Bookmarks
Bookmarks
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
