Results 1 to 6 of 6
Thread: Ring fitment question
  1. #1
    Registered User siteunseen's Avatar
    Member ID
    CZCC-24724
    Join Date
    Jul 2011
    Location
    Alabama
    Posts
    1,967
    Default Ring fitment question
    I have an F54 87mm overbore block with some new 87mm dished pistons. I know that 1mm is .040" but the ring set that came with all this is .030" oversize. Is that what I need or should I get .040" oversize rings?
    Thanks for any help,
    Cliff
    1972 240Z #918 New Sight Orange
    1977 280Z #305 Light Blue Metallic
    1972 240Z #110 Persimmons Red
  2. #2
    Registered User cbuczesk's Avatar
    Member ID
    CZCC-4368
    Join Date
    Jun 2003
    Location
    Chambersburg, PA
    Age
    53
    Posts
    488
    Default
    You can put them in the bore and see if they fit. Maybe someone put the correct rings in the wrong box. But odds are that you'll have to get 40 over rings.
    Chuck
    East Coast Z Nationals held at the Carlisle Import & Kit Nationals - May 16-18, 2014 Carlisle, PA
    www.carlisleevents.com/events/import
    1969 240Z #390
    1971 Fairlady Z
    1971 240Z parts car
    1972 240Z ITS race car
    1972 240Z turbo
    1974 260Z turbo
    1975 280Z my first car
    1978 620 King Cab
  3. #3
    Member ID
    CZCC-24724
    Join Date
    Jul 2011
    Location
    Alabama
    Posts
    1,967
    Default
    Turns out I was dead WRONG. Bought a 240 that came with these parts to build another motor, 2.8 with an E31 head and some triple Webers. I was so excited to get the car I wasn't paying much attention to the parts that were part of the deal, car ran great as it was.
    So now I've measured and am pretty sure he bought .750mm over sized cast piston cups. The block was bored .030".
    Here's the numbers as best I could get, block bore is 3.410". Pistons measure 3.390". Top ring in the hole has a gap of .026" with a feeler gauge. Piston with top ring, in the bore looks pretty darn close, very little wiggle.
    I'm going to put it together with an E88 head that will have the bigger valves put in. It's an early E88 so it should have good enough compression with the dished pistons.
    Sound OK?
    Attached Thumbnails Attached Thumbnails Click image for larger version.
  4. #4
    Low Budget/High Value
    Member ID
    CZCC-20342
    Join Date
    Oct 2009
    Location
    Washington County, OR
    Posts
    3,629
    Default
    Never been that far in to an engine myself, but all of those numbers are in the Engine Mechanical chapter. Nissan was very thorough, they even have the .50 and 1.0 mm oversize numbers. Bores, pistons, ring gaps, the works. No 0.750 though, you'll have to split the difference.
    Looks pretty good from a words and numbers perspective.
    1976 280Z, with some minor modifications
  5. #5
    Member ID
    CZCC-24724
    Join Date
    Jul 2011
    Location
    Alabama
    Posts
    1,967
    Default
    It probably is an 86.5mm but there's a "0.75" stamped on the piston tops and I can't figure what else that could be???
    I know I could load it all up and got to a machine shop and know for sure but that'll be later. I'm trying, with the help of the members like you, to know as much as I can about this motor. I like the dished pistons for pump gas and it's going to be temporary until I get the original 2.4 built up nice and shiny with the E31 head I'm gonna sink some dough ray me into, $$$. Just getting ready for the cold weather projects I've been putting off until it cools off, and it finally has down here.
  6. #6
    Member ID
    CZCC-20342
    Join Date
    Oct 2009
    Location
    Posts
    3,629
    Default
    Isn't actual measured clearance what matters? Actually I missed a zero and you might be too loose. 10 thousandths versus 1 - 1.8 thousandths spec. My mistake.
    (3.410" - 3.390") /2 = 0.010"
    The ring gap looks okay though.
Name:	1978 piston to bore.PNG
Thread Information
Users Browsing this Thread
There are currently 1 users browsing this thread. (0 members and 1 guests)
Similar Threads
  1. Rota RB Rims Fitment Question
    By galban in forum Wheels, Tires and Brakes (S30)
    Last Post: 01-21-2014, 08:35 PM
  2. wheel fitment ?
    By reintr0ducing in forum Wheels, Tires and Brakes (S30)
    Last Post: 07-30-2008, 04:58 AM
  3. Another Wheel & Tire Fitment question
    By webzlinger in forum Help Me !!
    Last Post: 03-07-2008, 09:23 AM
  4. Quick wheel fitment question - 15x8.5 3-3/8 backspace
    By ktm in forum Wheels, Tires and Brakes (S30)
    Last Post: 02-18-2008, 06:33 PM
  5. Oil Ring Question!
    By JEFF in forum Engine and Drivetrain (S30)
    Last Post: 03-22-2003, 12:39 PM
Bookmarks
Bookmarks
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
