Results 1 to 5 of 5
Thread: Curved circuit Boards
  1. #1
    1978 280Z (stock) TomoHawk's Avatar
    Member ID
    CZCC-2169
    Join Date
    May 2002
    Location
    NorthCoast, Ohio
    Age
    59
    Posts
    6,497
    Default Curved circuit Boards
    I think I will try to build a high-mount brake lamp with LEDs on a printed circuit board, but I want the circuit board to be curved to fit inside the lamp housing, which has a curved, chrome reflector for the bulb that was there before.
    Is it possible to bend the epoxy circuit board into a permanent curve? After etching the circuit on the back, I would use the heat gun to warm it until it will bend, then let it cool in that shape, then solder the parts to it, add some aluminum foil to reflectorize, and glue it into the housing.
    Drive Responsibly.
    enjoy classic Rock music.
  2. #2
    Registered User Oiluj's Avatar
    Member ID
    CZCC-15388
    Join Date
    Nov 2007
    Location
    SF Bay Area
    Age
    66
    Posts
    1,746
    Default
    I could be wrong, but I don't think heat will soften epoxy/glass fiber PCB's, because the epoxy has been cross-linked. That doesn't mean you can't use other plastic to do the same thing, just hardwire the LED's. In fact, you might be able to use thin, mirrored acrylic sheet.
    Julio
    1972 240Z (in-progress, 95% complete)
    CZC# 15388
  3. #3
    Member ID
    CZCC-2169
    Join Date
    May 2002
    Location
    NorthCoast, Ohio
    Age
    59
    Posts
    6,497
    Default
    I have PC board that is just plain epoxy resin. I will try to bend a sliver of it. I prefer to use a printed-circuit board because it is faster, neater, and more repeatable than point-to-point connections.
    Drive Responsibly.
  4. #4
    Boat Anchor Repairman Captain Obvious's Avatar
    Member ID
    CZCC-24608
    Join Date
    Jul 2011
    Location
    Philadelphia, PA
    Posts
    1,845
    Default
    I've seen plenty of flexible of PCB's but never out of fiberglass/epoxy. Nothing wrong with trying, but I don't think it'll take enough of a set unless it was molded like that originally before the epoxy set.
    The thread reminds me though... I've got a buddy working on a LED third brake light project. Maybe I should poke him and see how that's coming along.
  5. #5
    HLS30A 17574 djwarner's Avatar
    Member ID
    CZCC-27817
    Join Date
    Aug 2012
    Location
    Central FLorida
    Posts
    405
    Default
    Phenolitics are thermoset rather than thermoplastic and won't soften with heat. Might I suggest you form a piece of acrylic plastic to shape and mount LEDs with crazy glue feeding the leads to the back. Use silver paste you can get at Radio Shack to ink your own circuit. Failing that, run jumper wires from LED to LED.
    1971 240Z HLS30A 17574 L24-021025
Thread Information
Users Browsing this Thread
Similar Threads
  1. Floor boards
    By SuDZ in forum Interior (S30)
    Last Post: 01-23-2004, 10:19 AM
  2. Are front bumper brackets curved?
    By Walter Moore in forum Body and Paint (S30)
    Last Post: 04-29-2003, 08:30 PM
  3. rusty floor boards- POR or weld in new ones
    By m240 in forum Body and Paint (S30)
    Last Post: 05-10-2002, 08:25 PM
  4. curved shifter help.
    By greenz in forum Suspension and Steering (S30)
    Last Post: 01-25-2002, 04:54 PM
Bookmarks
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
