Results 1 to 3 of 3
Thread: Speedometer jumping
  1. #1
    Registered User
    Member ID
    CZCC-20445
    Join Date
    Nov 2009
    Location
    long island NY
    Age
    64
    Posts
    125
    Default Speedometer jumping
    At low speed my speedometer jumps. I think its the speedometer cable. Any thoughts?
  2. #2
    Registered User
    Member ID
    CZCC-20445
    Join Date
    Nov 2009
    Location
    long island NY
    Age
    64
    Posts
    125
    Default
    I did a few searches and found :speedometer bounce" could be the cable or the gear. I think its the cable. I had cleaned it out and lubed it with cable lube when I was putting it back together. Cable lube is very thin. The car sat for 25 or so years before I put it back on the road. The bounce post said to use heavy gear oil. I'll give it a try and report back.
  3. #3
    Registered User moelk's Avatar
    Member ID
    CZCC-23183
    Join Date
    Dec 2010
    Location
    Sweden
    Posts
    72
    Default
    I had the same problem. I just took the cable out of the speedo and then put it carefully back in again and it no longer bounce. I have taken my speedo out many times and it seems like you sometimes can get the cable in a little bit wrong and then it bounces around.
    Andreas C
Thread Information
Users Browsing this Thread
Similar Threads
  1. Transmission jumping out of 4th gear
    By grannyknot in forum Engine and Drivetrain (S30)
    Last Post: 07-06-2014, 10:08 PM
  2. ammeter jumping around or at +45....
    By kenmataya in forum Electrical (S30)
    Last Post: 04-17-2013, 03:44 AM
  3. Datsun Jumping in 72 Fla
    By Blue in forum Open Discussions
    Last Post: 12-18-2012, 01:48 PM
  4. Jumping in with 2
    By ArnieTX in forum Open S30 Z Discussions
    Last Post: 10-11-2012, 11:47 AM
  5. Advice on Jumping Tach
    By Gibby in forum Help Me !!
    Last Post: 12-21-2009, 08:47 AM
Bookmarks
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
