Results 1 to 8 of 8
Thread: Upgrade electric system, alternator, Fusible Links, remove External Voltage regulator
  1. #1
    '75 280z tamo3's Avatar
    Member ID
    CZCC-25433
    Join Date
    Oct 2011
    Location
    San Jose, CA
    Posts
    259
    Default Upgrade electric system, alternator, Fusible Links, remove External Voltage regulator
    I'm working on upgrading electrical system.
    My car is '75 280z.
    My goal is :
    • Replace Alternator to CS144 with removing external voltage regulator.
    • Remove Shunt.
    • Add extra fuse with install Maxi-fuse box. (75 has only 2 fusible link)
    • Add ignition relay (75 does not have it)
    • Swap Ammeter and Voltmeter
    My '75 280z has only 5 wire for external voltage regulator.
    When I googled, several people encounter issue for the missing #1 wire, which is green/red colored.
    Blues web site is always helpful. There is answer for this.
    HELP 75 Alternator swap
    I just create illustration for this solution.
    Click image for larger version.
    I will keep update the progress.
    '75/280z
  2. #2
    Member ID
    CZCC-25433
    Join Date
    Oct 2011
    Location
    San Jose, CA
    Posts
    259
    Default
    You can grab CS144 alternator from Cadillac DeVille. Try to find 92-94 in the junkyard.
ID:	74895Click image for larger version.
    The hardest part is to remove pulley. There is taper collar that prevent from removing the pulley.
    CS144 pulley removal - tapered collar type - International Full Size Jeep Association
ID:	74897Click image for larger version.
ID:	74898Click image for larger version.
ID:	74899Click image for larger version.
    I could not remove the the taper collar, so I grinded to remove the pulley.
    Just follow instruction video to rebuild alternator.
    Part 1
    Part 2
    Paint the cover too.
    completed.
    '75/280z
  3. #3
    Registered User EuroDat's Avatar
    Member ID
    CZCC-26512
    Join Date
    Feb 2012
    Location
    The Netherlands
    Posts
    1,420
    Default
    Hi Tamo,
    Nice mod and good clear instruction. Looking forward to seeing finished/installed pics.
    Do you have the specs for the CS144?
    Cheers Chas
    Chas
    5/77 280Z HLS30 403100 with some modifications
    Original colour: 305 Light Blue. The PO changed it to Red
  4. #4
    Member ID
    CZCC-25433
    Join Date
    Oct 2011
    Location
    San Jose, CA
    Posts
    259
    '75/280z
  5. #5
    Member ID
    CZCC-25433
    Join Date
    Oct 2011
    Location
    San Jose, CA
    Posts
    259
    Default
    Shunt!
    I searched on web, but I could not find any good information about '75 280z shunt.
    I learn some earlier model has shunt inside of the car (maybe 240z, 260z?) later model is in the engine bay.
    This is the shunt!
ID:	74912Click image for larger version.
ID:	74913Click image for larger version.
ID:	74914Click image for larger version.
ID:	74915Click image for larger version.
ID:	74916Click image for larger version.
    '75/280z
  6. #6
    Member ID
    CZCC-25433
    Join Date
    Oct 2011
    Location
    San Jose, CA
    Posts
    259
    Default
    Voltmeter, Ammeter wiring comparison
    75 Ammeter
    76 Voltmeter
    77 Voltmeter
    78 Voltmeter
    '75/280z
  7. #7
    Member ID
    CZCC-25433
    Join Date
    Oct 2011
    Location
    San Jose, CA
    Posts
    259
    Default
    ammeter
    voltmeter
    connection comparison
    '75/280z
  8. #8
    Registered User rossiz's Avatar
    Member ID
    CZCC-30163
    Join Date
    Feb 2014
    Location
    Seattle, WA
    Age
    53
    Posts
    323
    Default
    interesting post - but i'm still a little fuzzy on why the switch to this particular CS144 model.
    the "performance curves" graph seems to start at about 1,200 rpm, and i don't know what the pulley ratio is in relation to the crankshaft, so i'm not sure if this alternator kicks in sooner or provides an overall greater output or what...
    interested in finding out though!
    '78 280z - Daily driver/work in progress...
Thread Information
Users Browsing this Thread
Similar Threads
  1. 1979 280ZX 2+2 Alternator with External Regulator
    By Candice in forum Electrical (280ZX)
    Last Post: 10-29-2011, 09:19 AM
  2. Alternator, Voltage regulator, or???
    By dbcjmc in forum Electrical (S30)
    Last Post: 01-22-2011, 12:57 AM
  3. Upgrade from fusible links to circuit breakers
    By FastWoman in forum Electrical (S30)
    Last Post: 08-09-2010, 10:59 AM
  4. Blown fusible link...voltage regulator...battery?
    By gogriz91 in forum Help Me !!
    Last Post: 01-13-2010, 04:57 AM
  5. Alternator vs Voltage Regulator
    By jszarecki in forum Electrical (S30)
    Last Post: 11-01-2005, 11:29 PM
Bookmarks
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
