Results 1 to 5 of 5
Thread: Center Panel
  1. #1
    Registered User
    Member ID
    CZCC-931
    Join Date
    Sep 2000
    Location
    Williams Bay Wi. U.S.A.
    Posts
    25
    Post
    Vent,heater,def. non-op.Took out 4 screws,and all the knobs.Panel still does not come out, what gives?
  2. #2
    Admin Mike's Avatar
    Member ID
    CZCC-4
    Join Date
    Feb 2000
    Location
    Seattle, WA
    Age
    50
    Posts
    6,070
    Post
    I moved this to the "Emergency Help" forum.
  3. #3
    Admin Mike's Avatar
    Member ID
    CZCC-4
    Join Date
    Feb 2000
    Location
    Seattle, WA
    Age
    50
    Posts
    6,070
    Question
    MikeT. What are you trying to pull out? Are you trying to pull out the flat panel around the vent levers?
    I think there are also screws on the inside of the dash. Pain to get out.
  4. #4
    Senior Z Car Enthusiast billcapp's Avatar
    Member ID
    CZCC-864
    Join Date
    Jun 2000
    Location
    Odessa, FL
    Posts
    298
    Lightbulb
    Mike ...you don't state the year but the early ones have all the cables from the heater controls running to the various flaps and heater controls attached at the opposite end under the dash (at the core area) under the dash. You must disconnect these first to pull out the panel. I think here is also one screw on the bottom portion that attaches just behind the cigarette lighter. It's been awhile since I pulled mine. You will also have to detach the electrical wiring from the light at the top of the panel. Good luck.
  5. #5
    Registered User
    Member ID
    CZCC-931
    Join Date
    Sep 2000
    Location
    Posts
    25
    Post
    Thanks a bunch!!!!!!!! Warmest Regards, MikeT73.
Thread Information
Users Browsing this Thread
Bookmarks
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
