Originally Posted by
EuroDat
Are you using the slave cylinder with the return spring? If so, you probably need to adjust it for the "new" disc.
When the clutch disc wears, it moves the clutch fork towards the slave cylinder and the push rod need the be adjusted accordingly to fully engage the clutch.
The new disc will move the fork away from the slave cylinder, but the spring on the slave cylinder will pull it back. the throw out bearing is probably some distance off the pressure plate fingers. You can check this by removing the spring and checking how far you can move the clutch fork.
Adjustment:
1.5 turns on the adjusting nut is 2mm on the throw out bearing to pressure plate distance.
The correct adjustment is to screw the adjusting nut until the throw out bearing contacts pressure plate and then turn back 1.5 turns which will give you 2mm clearance at the pressure plate.
Chas
Bookmarks
