Results 1 to 16 of 16
Thread: Offset Question
  1. #1
    Registered User texasz's Avatar
    Member ID
    CZCC-3356
    Join Date
    Jan 2003
    Location
    Austin, Tx
    Posts
    1,926
    Default Offset Question
    On a wheel that has a +42 offset as I understand it you need a spacer for this wheel to fit on a 240Z. Question is would the spacer need to be a -42?
    A + offset means the wheel where it attaches to the car is further from the car where as a - offset it is closer. Right?
    '70 240Z - HLS30-08215 - Production Date 8/70
    '70 240Z - HLS30-06293 - Rusty and has Identity Crisis (must have been wrecked and the back 1/2 sectioned in from a later car maybe even a 280Z)...PARTS CAR!
    '71 240Z - HLS30-018482 - Production Date 1/71,Corvette Yellow, driven under a 4Runner, bought for parts, hit lotto with parts on car, may fix and put back on road
    My Photo Gallery
  2. #2
    Supporting Member ChrisA's Avatar
    Member ID
    CZCC-5906
    Join Date
    Feb 2004
    Location
    Lincoln, NE
    Age
    53
    Posts
    1,471
    Default
    I think my spacers are 40 mm thick to mount my 40mm offset wheels.
    1973 240Z HLS30-156693
  3. #3
    the QuackWacker GunnerRob's Avatar
    Member ID
    CZCC-2803
    Join Date
    Sep 2002
    Location
    Ventura, Ca. USA
    Age
    67
    Posts
    694
    Default
    Hi texasz,
    Here's a page from TireRacks web site that'll explain what an offset is.
    http://www.tirerack.com/wheels/tech/offset.htm
  4. #4
    Registered User alien-e's Avatar
    Member ID
    CZCC-4429
    Join Date
    Jun 2003
    Location
    Houston
    Posts
    47
    Default
    Then my quesiton is, where is the stock mounting point on my 240Z? Is it at zero offset inside the wheel housing, or (+) some milimeters?
    I'm buying the adapters from Modern Motorsports, but they are very vague about how thick the adapter is. When I asked, I got this response:
    "The adaptors suitable for wheels ranging from 36 to 40mm offset as described (range of 0.15", not much) are of one geometry only. So if your's fit the recommended offsets and widths you'll be just fine with our typical adaptors. Custom adaptors we can do separately but sounds like you're fine with our typical adaptors."
    When I pressed the issue they admited that the adapters are 1.1", which converts to 27.94 millimeters. How is this going to fit a 40mm offset rim?
    Alien-E : 1973 240Z
  5. #5
    Member ID
    CZCC-4429
    Join Date
    Jun 2003
    Location
    Houston
    Posts
    47
    Default
    On a side note, why are they using standard measurements when offset is traditionally in metric? Especially for a Japanese built car. I'm pretty sure these guys are Canadian, and their whole country standardized on the metric system. I'm boggled.
    Alien-E : 1973 240Z
  6. #6
    Member ID
    CZCC-4429
    Join Date
    Jun 2003
    Location
    Houston
    Posts
    47
    Default Modern Motorsports link
    Thougt it would be helpful to add a link to the product I'm talking about. Z to Honda Wheel Adaptors
    Alien-E : 1973 240Z
  7. #7
    Registered User Victor Laury's Avatar
    Member ID
    CZCC-1303
    Join Date
    Oct 2001
    Location
    Los Angeles
    Age
    61
    Posts
    1,814
    Default
    For 14 and 15 by 7 inch wide wheel on a 240Z, offset of 0 to +15mm is best fitment. that means the mounting plane (that rests against the hub surface) is dead center in the middle of the wheel (for a 0 offset) or 15mm outboard (moving the wheel center inboard). The Hondas, and most FWD cars, use a 35~40 offset. If you tried to use this wheel on the Z, the back of the tire would be hard against the strut tower. To change a +35mm wheel to 0 offset, you would need a spacer 35mm thick. If you put a 35mm spacer on a +40 wheel, it would be effectivly a +15 wheel when you finished.
    By the way, on 16 and over wheels, a +15 offset is optimal as a 0 will rub the outer fenders on bumps. So if you bought some 17X7 +40 4X100 SSR's, the spacer offered by Modern Motorsports would be just about perfect.
    DatsunVic CZC1303
    ダットサンビク
    72 HLS30 94071
    72 510
    70 SRL311 13136
    71 PL521
    Los Angeles
    Visit My Other Photo Site
  8. #8
    Member
    Member ID
    CZCC-791
    Join Date
    Mar 2000
    Location
    Pleasanton, CA USA
    Posts
    7,093
    Default
    Originally posted by Victor Laury
    ........ If you put a 35mm spacer or a +40 wheel, it would be effectivly a +15 wheel when you finished.
    ? ? ? I'm lost here.
  9. #9
    Member ID
    CZCC-4429
    Join Date
    Jun 2003
    Location
    Houston
    Posts
    47
    Default
    I think I understand. I was planning on on a set of 15 x 6.5 +40 4X100 Nippon Racing F2's (12 pound alloy wheel). So, if I follow the logic, the offest would be +12.06MM with the adaptor. I might consider getting a 7" rim, to fill out the wheel wells with a slightly wider tire.
    Thanks for the help Victor.
    Alien-E : 1973 240Z
  10. #10
    Member ID
    CZCC-1303
    Join Date
    Oct 2001
    Location
    Los Angeles
    Age
    61
    Posts
    1,814
    Default
    I misspelt. My bad. it was suppose to read
    "If you put a 35mm spacer on a +40 wheel, it would be effectivly a +15 wheel when you finished."
    Instead of "or"
    DatsunVic CZC1303
    ダットサンビク
    72 HLS30 94071
    72 510
    70 SRL311 13136
    71 PL521
    Los Angeles
  11. #11
    Member
    Member ID
    CZCC-791
    Join Date
    Mar 2000
    Location
    Pleasanton, CA USA
    Posts
    7,093
    Default
    Instead of "or"
    Yes, I figured that part out. What confuses me is :
    "To change a +35mm wheel to 0 offset, you would need a spacer 35mm thick." I think I understand it this far. 35mm offset wheel, 35mm spacer to put back in ZERO offset place.
    BUT Then, "If you put a 35mm spacer on a +40 wheel, it would be effectivly a +15 wheel when you finished."
    Following the first example, I'd have thought the wheel would be effectively a +5 wheel. 40 - 35 = 5 ? This is where I get lost.
  12. #12
    Member ID
    CZCC-1303
    Join Date
    Oct 2001
    Location
    Los Angeles
    Age
    61
    Posts
    1,814
    Default
    Well you Can't expect me to actually do rithmatic, do you? You know I aint got 40 fingers and toes! I know some. The adds and the takes-a-ways and even some of the gizindas (4 gizinda 8, 2 times). I'd know more but, in school, Elle-May Clampet was always wisperin in my ear bout the swimin hole. Makes it hard fer a man to think bout anything except multiplication.
    DatsunVic CZC1303
    ダットサンビク
    72 HLS30 94071
    72 510
    70 SRL311 13136
    71 PL521
    Los Angeles
  13. #13
    Member
    Member ID
    CZCC-791
    Join Date
    Mar 2000
    Location
    Pleasanton, CA USA
    Posts
    7,093
    Default
    Gazintas, I remember those thangs! I understand about Elle-May Clampett. There was an Elle-May in my math class also. Thank goodness for calculators!
    Though maybe it had to do with the +15 offset mentioned in the 2nd paragraph (about 16" wheels) or something. I get really lost on this offset stuff (all on my own) then different people explain it different ways, and some folks get + offset and - offset confused when they discuss. John Coffey had me spinning in circles one day.
  14. #14
    Registered User tanny's Avatar
    Member ID
    CZCC-2692
    Join Date
    Aug 2002
    Location
    Tucson, AZ
    Age
    70
    Posts
    649
    Default
    I have been looking at wheels on Ebay and was also a bit confused about offset for a bit. Apparently, the more positive offset you have, the more the rim moves toward the inside of the wheel well. Unless I'm still confused. Also, I think I saw somewhere that most fwd cars are in the +40 range, and rwd cars are around 0 to +15. Please correct if my memory has failed as usual. Victor.
    73 Z, 06 Honda civic
  15. #15
    Member ID
    CZCC-1303
    Join Date
    Oct 2001
    Location
    Los Angeles
    Age
    61
    Posts
    1,814
    Default
    No correction needed Tanny. You got it right the first time.
    DatsunVic CZC1303
    ダットサンビク
    72 HLS30 94071
    72 510
    70 SRL311 13136
    71 PL521
    Los Angeles
  16. #16
    Registered User 75BlackZ's Avatar
    Member ID
    CZCC-7893
    Join Date
    Feb 2005
    Age
    34
    Posts
    19
    Default
    OKAY.. OLD thread.. but why start a new one?
    I want to put 42 offset wheels on my car.... so i needa put in a 42 spacer in??
    If I can only find a 40 offset spacer... will the +2 be a big deal? How much offset left over can can be considered "okay"?
Thread Information
Users Browsing this Thread
Bookmarks
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
