Results 1 to 26 of 26
Thread: Miata (Mx5) Seats
  1. #1
    Registered User
    Member ID
    CZCC-1106
    Join Date
    Mar 2001
    Location
    Adelaide, South Australia, Australia
    Age
    53
    Posts
    4
    Default Miata (Mx5) Seats
    Greetings,
    Someone asked me to post some pictures of the Miata seats I recently wacked into my '71, so here goes....
    They're very similar in shape to the OEM seats, comfortable, have speakers in the headrests, and are *way* less likely to fry your thighs after a day parked in the Australian sun.
    I used the Miata rails, drilling a hole in the front section to match up with the front mount on the floor pan. Then simply drilled 4 holes in the mounts (2 to match the new holes in the rails, 2 to match the existing rear holes), wriggled things about, and bolted them in. I've still got some overhang (the Miata rails are longer than is required) and will cut it off in due course.
    Relatively simple exercise and a useful alternative for a DD.
    Attached Thumbnails Attached Thumbnails Click image for larger version.
    Damian Percy
    '71 Donor Car Will Live Again
  2. #2
    Registered User Saint's Avatar
    Member ID
    CZCC-1652
    Join Date
    Feb 2002
    Location
    London, UK
    Posts
    49
    Default Miata Seats
    Excellent. I've been wanting to compare these seats for a awhile. I'm in the process of doing up a 1971 myself and am after similar seats. Have you done any research into other types. The Porsche seats look quite similar especially the Posche Boxster. As I'm Europe based boxsters are a little more common in the scrap yards. Any thoughts.
  3. #3
    Registered User Rattfink's Avatar
    Member ID
    CZCC-1670
    Join Date
    Feb 2002
    Location
    California
    Age
    56
    Posts
    27
    Default
    I've heard that the seats from a Jetta Wolfsburg edition are a direct bolt in. Recarro's I believe. Nice seats and could pic 'em up fairly cheap.
    L8-r
    'Fink
  4. #4
    Member ID
    CZCC-1652
    Join Date
    Feb 2002
    Location
    London, UK
    Posts
    49
    Default
    Good call, I'll give them a shot. Cheers
    The longer your head remains in the sand the more likely it is that something will bite you in the ass.
  5. #5
    Registered User
    Member ID
    CZCC-2400
    Join Date
    Jun 2002
    Posts
    2
    Default
    Rattfink, is there a specific year on the Wolfsburg seats? I can not remember if they made them more then one year. Thanks.
    John
    Newbie with 72 240z.
  6. #6
    Registered User
    Member ID
    CZCC-2274
    Join Date
    Jun 2002
    Location
    Sacramento CA area
    Age
    65
    Posts
    303
    Question Maita Seats
    Does anyone have information on what year(s) fit the 240?
    Owen K
    71 240Z Sold
    78 620 Sold, then it was rewrecked
    99 Volvo C70 Convertable
    96 Volvo 850
    97 Volvo 850
    Home page
  7. #7
    Registered User Jarvo2's Avatar
    Member ID
    CZCC-26781
    Join Date
    Mar 2012
    Location
    Plainfield, IL
    Age
    42
    Posts
    238
    Default
    Just wanted to provide a brief update on my experience with installing Miata Seats in my '72 240z. I ended up fabricating custom mounts and did not use the slider rails. Check my blog out for pictures:
    Dave's 1972 Datsun 240z: Miata Seats Installed
    Dave
    Windy City Z Club (Chicago)
    1972 240z, restoration in progress
    http://jarvas240z.blogspot.com
  8. #8
    Registered User HermanM's Avatar
    Member ID
    CZCC-23912
    Join Date
    Mar 2011
    Location
    Sacramento, Ca
    Age
    36
    Posts
    164
    Default
    Thanks to this post, I just purchased 2 miata seats to bolt into my early 260. Im going to try to modify the bolt location like PerZee did to minimize any body work. I'll let y'all know how it works out later with some pics
  9. #9
    Registered User Sean240Z's Avatar
    Member ID
    CZCC-6478
    Join Date
    Apr 2004
    Location
    McLean, VA, USA
    Age
    48
    Posts
    232
    Default
    I decided on seats from the Honda S2000 and I love them. My install details are here:
    http://www.classiczcars.com/forums/i...swap-240z.html
  10. #10
    Registered User tlorber's Avatar
    Member ID
    CZCC-20299
    Join Date
    Oct 2009
    Location
    Los Angeles
    Age
    55
    Posts
    1,190
    Default
    I have Miata seats in my 240. They hold you in WAY better than stock and the cloth is much more comfortable.
    I paid $40.00 at the wrecking yard for them , and around $12.00 for 2 cans of spray dye. I used stock 240 sliders and put a 1" tall aluminum shim under the rear of the seats since they sit a bit lower. I did not have to drill new holes into the seat base on the driver's side. On the passenger's side had to drill 2 new holes.
    Tlorber
    '73 240 +/- done
    '73 240 survivor
    '69 SRL 311
    '54 GMC Going onto S10 frame w/LS motor
    '99 Lexus GS Driver
  11. #11
    Registered User
    Member ID
    CZCC-22416
    Join Date
    Sep 2010
    Location
    richmond, va
    Age
    53
    Posts
    67
    Default
    i would opt for these: Corbeau: Sport Seat
    plus a set of their brackets:
    240 Z 69-74 C22011 C22011
    260Z 74-75 D212T D212T
    260Z 76-78 D214T D214T
    but then i would have to find somewhere to store the original seats.
    not cheap, but they're new, wouldn't look too out of place, and should be drop-in replacements.
  12. #12
    Registered User
    Member ID
    CZCC-10869
    Join Date
    Feb 2006
    Location
    Irvine, California
    Age
    49
    Posts
    755
    Default
    Forget the early Miata seats. I ran with a pair for about 3 years until I got a screaming deal on a pair of 2008 MX-5 seats. They are just as easy to install as the early Miata seats though they do require a little bit more work.
    -Bo
    1972 240z - Not original and still not done.
    "Something wicked this way comes...."
  13. #13
    Registered User Travel'n Man's Avatar
    Member ID
    CZCC-14147
    Join Date
    Mar 2007
    Location
    Western North Carolina
    Age
    60
    Posts
    1,486
    Default
    Put these in a few years ago - would highly recommend! I put my original refoamed-reskinned seats in storage. Doubt I will ever put them back in the car.
Name:	Datsun seats 007.jpg
ID:	70709Click image for larger version.
Name:	Datsun seats 006.jpg
ID:	70710Click image for larger version.
Name:	Datsun seats 002.jpg
ID:	70711Click image for larger version.
ID:	70712Click image for larger version.
ID:	70713Click image for larger version.
    Life's a journey; enjoy the ride!
    Mitchell
    L28 - N42 Block w/Flat tops - N42 Rebello Head & Cam - Triple 40 PHH Mikuni's - Headers - Recaro Seats -
    R180 3.9 Diff - Close Ratio 5 Speed - Toyota Vented Brake Upgrade w/ Porterfield High Performance Pads & Shoes
    1972 Datsun 240z
    HLS30-75040
  14. #14
    Registered User
    Member ID
    CZCC-10869
    Join Date
    Feb 2006
    Location
    Irvine, California
    Age
    49
    Posts
    755
    Default
    Seat brackets I fabricated for the Miata seats.
Name:	Seat Bracket 1.jpg
ID:	70729Click image for larger version.
Name:	Seat Bracket 2.jpg
    -Bo
  15. #15
    Member ID
    CZCC-23912
    Join Date
    Mar 2011
    Location
    Sacramento, Ca
    Age
    36
    Posts
    164
    Default
    Quote Originally Posted by ktm View Post
    I did mine in kind of the same manor. I just didn't cut the stock Miata rails and just drilled a third whole to allow for the pin to go into the center. I was hoping for a more rigid seat with all the components secured
  16. #16
    1978 280Z (stock) TomoHawk's Avatar
    Member ID
    CZCC-2169
    Join Date
    May 2002
    Location
    NorthCoast, Ohio
    Age
    60
    Posts
    6,497
    Default
    Are the speakers in the headrest noticeable? Speakers in a headrest are fine for a convertible, but if in a closed-coupe, and there are holes, it would look odd.
    Drive Responsibly.
    enjoy classic Rock music.
  17. #17
    Marooned Fish cygnusx1's Avatar
    Member ID
    CZCC-4964
    Join Date
    Sep 2003
    Location
    Putnam Valley, New York, United States
    Age
    52
    Posts
    845
    Default
    I have been looking at all these seat installs with custom plates and brackets but I find that, although they work, many seem too weak to hold the seat firmly fixed in an accident. As a back of the napkin suggestion, I would try to use at least 3/8" x 3" wide steel plates, and instead of flat bar, try to incorporate angle iron. Of course material size depends on the design of the mount... but whatever the case, you don't want that seat to move; the forces involved in a collision, can be enormous. The seat can't hold you in place if it's going to bend the mounting adapters. They should be strong enough to be able to yank the seat bolts right through the Datsun floor seat frames. They should not be the weakest link. Just my 2c.
    Dave C, Putnam, NY
    NYZCC - Membership Director
    __________________________
    1976 280Z Turbo
    1972 240Z RESTOmod
    2006 330xi 6-sp/winter/sport
  18. #18
    Member ID
    CZCC-6478
    Join Date
    Apr 2004
    Location
    McLean, VA, USA
    Age
    48
    Posts
    232
    Default
    Dave,
    I'm an engineer and I've studied crash survival investigation and ensuring integrity during an accident was of prime concern when designing my seat installation. I'm confident that my S2000 seats are more securely mounted than the original 240z seats. In my case, the adapter plates are made from 11 gauge steel (~1/8" thick) plates, bolted to the vehicle seat mounts in three locations per side where the stock seats are only bolted in two. The 11 gauge steel is much thicker than the Z's seat mounts. Additionally, the inboard fwd seat bolt is actually bolted through the fwd vehicle seat mount cross bar.
    Though the S2000 seats include a seat belt receiver on the inboard sides of the seats, I removed these. I decided to use the original vehicle seat belt mount locations as I know that the vehicle structure there is designed to withstand the seat belt crash loads. I wasn't comfortable that the vehicle seat mounts would withstand crash loads if they also had to withstand seat belt loads.
    During any aftermarket seat install, I would definitely not recommend moving the seat belt mounting locations to the seats.
  19. #19
    Registered User
    Member ID
    CZCC-10869
    Join Date
    Feb 2006
    Location
    Irvine, California
    Age
    49
    Posts
    755
    Default
    Quote Originally Posted by cygnusx1 View Post
    John Coffey inspected my setup when he welded in the Bad Dog frame rails. I wanted him to make any modification necessary if he thought there were unsafe. John took a look at them and told me that they were fine.
    The forces you mention are large, but you are assuming that the ensuing momentum of the individual is being imparted into the seat. That's assumption is not entirely correct. The individual will be "thrown" forward until the seat belts lock. It is the seat belts that take most of the force, not the seats, unless it is a rear collision.
    Also keep in mind that the stock seats are mounted the same way. The flat bar just extends the mounting point for the front seats. The weakest link, just like the stock seats, would be where the bar bolts to the front mounting location.
    -Bo
  20. #20
    Registered User grannyknot's Avatar
    Member ID
    CZCC-26437
    Join Date
    Feb 2012
    Location
    Toronto
    Posts
    698
    Default
    I'd like to know how you guys delt with that big hump on the bottom of the Miata seat pan that hits the seat mounting bar as you bring the seat forward? Did you just raise the seat enough to clear it? I tried that but found my head hitting the roof.
    1970 240Z HLS30 01955 March/70
  21. #21
    Member ID
    CZCC-2169
    Join Date
    May 2002
    Location
    NorthCoast, Ohio
    Age
    60
    Posts
    6,497
    Default
    What's the hump for? If there is nothing there, you could hammer it flat. Hopefully it's not a motor. Real sportscars "don't need no stinkin' power seats."
    Drive Responsibly.
  22. #22
    Member ID
    CZCC-23912
    Join Date
    Mar 2011
    Location
    Sacramento, Ca
    Age
    36
    Posts
    164
    Default
    Quote Originally Posted by grannyknot View Post
    I had no issue with the bump in the bottom of the seat. I lined up the back bolts into the factory holes on the factory brackets and then made an extended bracket to attach the front mounts to. The seat is able to slide fully forward, well at least as far as needed for anyone small enough to have to be that close, with no issue(s).
  23. #23
    Member ID
    CZCC-26437
    Join Date
    Feb 2012
    Location
    Toronto
    Posts
    698
    Default
    OK, that sounds like you just raised the front of the seat and left the back of the seat low, that would keep the height down and the knees a little higher like modern car seats do. That's a better idea then what I did and that's why it didn't work for me.
    I have the Integra seats now and really like them but would love to try the s2000 honda seats, don't know how comfy they are but they sure look the part.
  24. #24
    Member ID
    CZCC-26781
    Join Date
    Mar 2012
    Location
    Plainfield, IL
    Age
    42
    Posts
    238
    Default
    For anyone who's installed the miata seats, I'd strongly recommend adding some headrest speakers. The cutouts are there & I ended up just using a cheapo set of speakers that I was going to throw away. Much better audio than the stock speakers.
    Dave's 1972 Datsun 240z: Miata seat speakers
    Dave
  25. #25
    Registered User
    Member ID
    CZCC-7862
    Join Date
    Feb 2005
    Age
    45
    Posts
    1
    Default
    Quote Originally Posted by Jarvo2 View Post
    What model year Miata are your seats from? Mid 90's?
  26. #26
    Member ID
    CZCC-26781
    Join Date
    Mar 2012
    Location
    Plainfield, IL
    Age
    42
    Posts
    238
    Default
    They call them "NA", which is the first body style fro the early to mid 90's. Any should work, but these early ones, in my opinion, are the most comfortable!
    Dave
Thread Information
Users Browsing this Thread
Bookmarks
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
