Results 1 to 14 of 14
Thread: wide wheels again :D
  1. #1
    www.project240k.com khughes's Avatar
    Member ID
    CZCC-6769
    Join Date
    Jun 2004
    Location
    Australia
    Age
    40
    Posts
    1,191
    Default wide wheels again :D
    Just wondering..
    i was planning on trying to get a set of RS Watanabe's in F16x8(0), R16x8.5(-6) as according to watanabe, this is the max for the KPGC110
    now, i figured that since i had the guards, that those would be fine, but now i realise that the KPGC110 had a different rear offset to the KPGC110, so will that through out my idea? the wheels have to be legal as it has to go through engineering
    according to the site, the GC110 has F/R 14x6.5(+14.5) and the KPGC110 has F14x8(-6) R14x8.5(-13) out of the factory (well i assume that is what it is according to the table) http://www.rs-watanabe.co.jp/index2.htm
    Kent
    07/74 Datsun 240K GL Hardtop KHGC110 - #5497 (longest 240k project in history?)
    1970 Datsun 240Z HS30 #212
    www.project240k.com - project details on all my cars
  2. #2
    Deftly daft Alfadog's Avatar
    Member ID
    CZCC-1243
    Join Date
    Sep 2001
    Location
    Melbourne, VIC, Australia.
    Age
    36
    Posts
    4,536
    Default
    Do you know precisely what 'legal' entails? According to what I could find:
    - OVERALL diameter of tyre+rim must not exceed +25mm or -26mm
    - Rims and tyres may not protrude past any bodywork when viewing from above
    - Tyres may not be more than 1.3x wider than vehicles widest optional tyre
    - Track (from centre of wheel to centre of wheel on same axle) may not be increased more than 26mm
    Now, as far as I know for the '74 240K the widest tyre was 175. That means 225 is the widest you could go... You could probably argue 185, and that's still only 235 - which would fit on the 8.5 and according to Yokohama you can fit that onto the 8.5 without too much stretch.
    I've got 14x7.5 front and 14x9 rear and with about zero camber they fit just under the flares. When I lowered it the negative camber brought the top of the wheel in more (and the bottom out more) - I'm guessing you'd install a camber kit too (or do the modification 440k has details on (if engineerable!)).
    I think that is just the maximum-width table there, the difference being the GC110 doesn't have flares, 'course! Out of factory they both came with 5" steel wheels.
    So yeah, did I confuse issues even more?
    Attached Thumbnails Attached Thumbnails Click image for larger version.
  3. #3
    Member ID
    CZCC-6769
    Join Date
    Jun 2004
    Location
    Australia
    Age
    40
    Posts
    1,191
    Default
    no, that is a great help, if 9" fits for you, then 8.5" is good enough for me!, what are your offsets?
    I wasn't aware of the 1.3x rule either! but does the difference in wheel offsets mean that it blows out the track change maximum of 26mm?
    Would love for some more info on 440k's camber mods too ;D
  4. #4
    Now a Mazdabater 440k's Avatar
    Member ID
    CZCC-6607
    Join Date
    May 2004
    Location
    Gold Coast
    Posts
    174
    Default
    Whoa!! it's not my modification - I can't take credit for it.
    It's a fairly common mod done on 1600's, which consists of slotting the holes on the rear crossmember that hold the rear control arms. This has been done on seriously lowered IRS dattos since the 70's.
    Datsport sells exchange X-members with the mod, and an adjusting bolt. See HERE for some pics and details of the Datsport kit.
    Essentially, you slot the outer brackets fore / aft, so that you can adjust the toe. The inner brackets are slotted up and down, so you can adjust camber.
    This can be done at home by a semi skilled handyman with a pencil grinder (or round file). The big trick is to hold it all in place once the adjustment has been done.
    Yes, the track is measured from the centreline of the back tyres, so if you put big offset wheels on, then this increases your track. I Think that we may get around it with the fact that the GTR had a wider track (I think? Did it???).
    Thing is, as long as it's well done, and you have flares to stop the tyres protruding past the guards, you will get away with it (ie not be picked on for it). I don't know the implications re insurance etc though.
  5. #5
    Kenmeri
    Member ID
    CZCC-7451
    Join Date
    Dec 2004
    Age
    43
    Posts
    103
    Default
    i have 15x10 watanabes under my 73 c110 ill post pics later if it helps, i still have another 1/2 inch more to be flush with the flare so i can be safe running 11s or maybe 12s. my buddy in japan saw a pair of 15x12s for about 600USD.
    mikey
  6. #6
    OK! ...I made it up. g72s20's Avatar
    Member ID
    CZCC-6441
    Join Date
    Apr 2004
    Location
    Sydney Australia
    Age
    63
    Posts
    564
    Thumbs up
    Some photos of your wheels and the car would be good Mikey...
    Regards,
    Jim.
    1972 Skyline GT-X (GT-R copy)KGC10
    Prince & Skyline spoken here
  7. #7
    Kenmeri
    Member ID
    CZCC-7451
    Join Date
    Dec 2004
    Age
    43
    Posts
    103
    Default
    heres pics of the wheels
ID:	8798   Click image for larger version.
ID:	8799   Click image for larger version.
ID:	8800   Click image for larger version.
  8. #8
    Kenmeri
    Member ID
    CZCC-7451
    Join Date
    Dec 2004
    Age
    43
    Posts
    103
    Default
    heres a couple pics of the car
ID:	8802   Click image for larger version.
ID:	8803   Click image for larger version.
  9. #9
    Being random IS a skill cam's Avatar
    Member ID
    CZCC-9971
    Join Date
    Nov 2005
    Location
    AUSTRALIA
    Age
    33
    Posts
    16
    Default
    there sum prity phat wheels how much did u pay for them thows mags are cool to don't reokon i would hav goen with the blak thow mabe steel or cromy tinge on gold but that just me looks good thow
  10. #10
    Registered User s13drifter's Avatar
    Member ID
    CZCC-9844
    Join Date
    Oct 2005
    Age
    38
    Posts
    63
    Default
    english please^^^^
  11. #11
    mmm Z cars.. ohhh bbabyy PrOxLaMuS©'s Avatar
    Member ID
    CZCC-4022
    Join Date
    Apr 2003
    Location
    Colorado
    Age
    34
    Posts
    1,071
    Default
    your from Australia.. and you speak like a less edumacated folk from da dirty south here in America.. LoL
    1978 280Z Boring Mods :
    F54/P90a, Holset HY35W turbo, 3.75" downpipe, 3" exhuast, NPR intercooler, 440cc injectors, Innovate Wideband, Arizona Zcar springs, Tokico 5 ways, MSA sway bars
    www.putfile.com/proxlamus
    SEE my 280Z in ACTION! VIDEO!
  12. #12
    Registered User
    Member ID
    CZCC-8671
    Join Date
    Jul 2005
    Location
    Tallahassee, FL
    Posts
    44
    Default
    As a Southerner, I resent that.
    HLS30 42549
  13. #13
    Hakosuka sakijo's Avatar
    Member ID
    CZCC-7932
    Join Date
    Feb 2005
    Location
    Sunny Hawaii
    Posts
    528
    Default
    Looks like you could get more tire on those rims, Mikey. The stretch/bulge looks a bit scary to me.
    Miles
    1971 Skyline "Hakosuka"
    2002 Lexus GS 300
  14. #14
    Kenmeri
    Member ID
    CZCC-7451
    Join Date
    Dec 2004
    Age
    43
    Posts
    103
    Default
    cam
    i bought the wheels few years ago for about $575 for the set. there are just painted flat black w/polish lip for now but will be powder coating them all black later when tires are gone out.
    sakijo
    yea i can get more tire but theres not much to choose from here in the states for 15" rims either 275-50s which i had before and i couldnt even set the car all the way down because the car was lowered so much that the flares would rest on the tire before i let it all the way down. but another choice wuld be some 245-50 tires. im ok with the 225 right now but will get other tires when needed not in a hurry to get some tires at the moment,
Thread Information
Users Browsing this Thread
Bookmarks
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
