Results 1 to 15 of 15
Thread: Autoloc keyless entry
  1. #1
    HLS30165540
    Member ID
    CZCC-1052
    Join Date
    Jan 2001
    Location
    Houma, Louisiana
    Age
    55
    Posts
    2,297
    Default Autoloc keyless entry
    I installed a keyless entry system in my car. Autoloc model KL 550. Does anyone have any experience installing these or a similar system? Everything went really good. Power door locks work great. Parking lights flash when system is activated and deactivated. My question is on the starter/ignition kill. I don't know if I have some wires crossed or backwards or what but, I unlock the doors, get in the car, sit down, then when I turn the key, nothing. Then when I activate the system and lock the doors, turn the key and she fires right up. Is this supposed to work like this? I was hoping it would be the opposite where the system (doors) are unlocked for the engine to turn over. The way it is now the system (doors) are locked for the engine to turn over.
    Also the system has a valet switch, how does this work???
    Their tech support desk doesn't open until Monday. I hope someone can help me before then.
    Thanks
    Ed
    The 1973 240Z 165540 Slightly modified. L28, 5sp, cam, headers, MSD 6AL, power windows, power door locks, leather seats, custom this and custom that.
  2. #2
    Known Zitus carrier! hls30.com's Avatar
    Member ID
    CZCC-4106
    Join Date
    May 2003
    Location
    Savannah, Georgia
    Posts
    6,702
    Default
    Ed,
    I have not seen the system you have, but it sounds like moving the contacts from a NO to a NC on the relay would probably take care of it in short order-email me their wiring diagram, and I'll take a look.
    Will
    A Z is beautiful from any angle, I just happen to prefer to view from the drivers' seat!
  3. #3
    Registered User jmanz6's Avatar
    Member ID
    CZCC-8321
    Join Date
    May 2005
    Location
    Metro Detroit
    Age
    43
    Posts
    101
    Default
    I used to install car alarms, and hls30 is right. It sounds like you have the relay hooked up wrong. You have it set to NO (normally open), that means when you disarm the alarm, it opens the relay and make the starter not work. You want to use it as NC (normally closed), this makes the relay close when the alarm is disarmed. It should be in the instructions how to hook the wires up. You should not have to lock the doors to make it work. I did do a kill switch once where we put a momentary button in the lighter (filament removed), so you had to hold the lighter in while turning the key in order for the car to start. The woman had an alcoholic husband who used to steal her car all the time. I guess she thought this would stop him.
    72 240Z, SU, header, Tokico Blue Struts, Suspension Tech Springs, All new Poly bushings, 280Z Tach, Crane XR-3000 ingition, 4-speed, "poop brown" Work in progress. Website
  4. #4
    HLS30165540
    Member ID
    CZCC-1052
    Join Date
    Jan 2001
    Location
    Houma, Louisiana
    Age
    55
    Posts
    2,297
    Default
    Here is a picture of the wiring diagram. It's connected just like it shows.
    Attached Thumbnails Attached Thumbnails Click image for larger version.
  5. #5
    Member ID
    CZCC-8321
    Join Date
    May 2005
    Location
    Metro Detroit
    Age
    43
    Posts
    101
    Default
    It looks like the relay is set to open if the ignition switch is put in the ON or START position. The grey wire from the brain, is probably a GND. It looks to get the +12V from the yellow wire that is attached to the ignition +12V. Can you move the wire from 87a to 87 and see if it works correctly? Make sure with it like this, that is will not start with the doors locked by the remote. This may take care of the problem. let me know how it turns out.
  6. #6
    HLS30165540
    Member ID
    CZCC-1052
    Join Date
    Jan 2001
    Location
    Houma, Louisiana
    Age
    55
    Posts
    2,297
    Default
    I moved the wire from 87a to 87 and it still does the same thing.
  7. #7
    Registered User
    Member ID
    CZCC-6670
    Join Date
    May 2004
    Location
    maryland
    Posts
    93
    Default
    Damn moving the wire from 87a to 87 should have worked. Did u move the correct one?
    1974 260z One Rusty Z
  8. #8
    HLS30165540
    Member ID
    CZCC-1052
    Join Date
    Jan 2001
    Location
    Houma, Louisiana
    Age
    55
    Posts
    2,297
    Default
    Well, I talked to the service tech and we went through a system test and the result was that the module is working correctly. He said it is probably the relay. I tried a different relay (same brand) and it did the same thing. So I took the relay off the car to do some testing. With power to 85 & 86 the relay was closed at both positions 87a, 87 & 30. With no power to 85 & 86 the relay was open at both 87a, 87 and 30. I take it it's not supposed to work like this?? Should the relay alternate, open-closed, 87a-87? And vice versa?
    Thanks for the help.
  9. #9
    Registered User
    Member ID
    CZCC-6670
    Join Date
    May 2004
    Location
    maryland
    Posts
    93
    Default
    87a shoudl always be connected to 30. When the relay activates 30 should connect with 87
  10. #10
    HLS30165540
    Member ID
    CZCC-1052
    Join Date
    Jan 2001
    Location
    Houma, Louisiana
    Age
    55
    Posts
    2,297
    Default
    Well, better late than never but I solved the earlier problem. It was a cheap relay that was not working properly. New relay and she's working fine.
    On another note if anyone is doing the power door lock upgrade I've attached a templete of the bracket I made along with a picture. To do the other side you just reverse it. That's why the picture doesn't match the templet. Cut the templete and flip it to do the other side.
    I started with some aluminum sheet metal I can't remember the guage but it measures .030. I cut it with tin snips.
    After it's bent remove the two screws on the back side of the door that hold the window frame, above the latch. Loosten the other two. And remove the door handle.
    The bracket slides behind the window frame. Mark the holes for the two screws and drill with a 1/2 bit.
    Hope it helps. If somone has a different set up, share it.
    Here is a link to pictures of the actuator installed.
    Attached Images Attached Images
  11. #11
    Z Newb PRSgodzilla's Avatar
    Member ID
    CZCC-7305
    Join Date
    Nov 2004
    Location
    Kent & Pullman, WA
    Age
    33
    Posts
    44
    Default
    Ed
    How much was the kit and where did you get it?
    1971 240z 5-speed Canary Yellow
    HLS30-15159
    Build Date: 11/70
  12. #12
    HS130-150591 4/79 zbane's Avatar
    Member ID
    CZCC-11908
    Join Date
    Jun 2006
    Location
    Cashiers, NC
    Age
    48
    Posts
    1,671
    Default
    summit racing has them-
    http://store.summitracing.com/egnsea...115+4294842152
    $38-not a bad deal, IMO.
    David
    _____________________________________
    HS130-150591, April, 1979-280zx
    2001 Infiniti I 30
  13. #13
    Member ID
    CZCC-7305
    Join Date
    Nov 2004
    Location
    Kent & Pullman, WA
    Age
    33
    Posts
    44
    Default
    Not a bad deal at all, thanks. That template looks good Ed I am thinking about installing these soon so I will probably make use of it
    HLS30-15159
    Build Date: 11/70
  14. #14
    HLS30165540
    Member ID
    CZCC-1052
    Join Date
    Jan 2001
    Location
    Houma, Louisiana
    Age
    55
    Posts
    2,297
    Default
    Hey, I forgot about this post. Hope it works out for you. Remember to create a mirror image of the templete for the opposite side.
  15. #15
    Registered User
    Member ID
    CZCC-17718
    Join Date
    Sep 2008
    Location
    California
    Posts
    5
    Default
    So i tried laying out this template in AutoCad and the Dimensions dont agree with the final shape / layout of this bracket. Has anybody else had this problem?? Should i just print out the template full scale and cut out the part regardless of the dimensions??
Thread Information
Users Browsing this Thread
Bookmarks
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
