Results 1 to 13 of 13
Thread: l26 in 240k
  1. #1
    twin su's baby Dat 240K's Avatar
    Member ID
    CZCC-10708
    Join Date
    Feb 2006
    Location
    Sedan, South Aust
    Posts
    40
    Post l26 in 240k
    when i fisrt joined i read something about puting L28's into the k's and how you have to drill new hole for the dip stick dose this apply with the L26 as well because i have a l26 that i am planing on dropping into my k by the look of the sump on the 26/24 they look a hell of alot differant. Then i was also thinkin that if the dip sticks are located in the same spot could i just swap the sumps and the oil pick ups over? also i have no idea what the l26 is out of as it just had a single down draght carby on it.
    another day dreaming
  2. #2
    philo "Z" opher Zedrally's Avatar
    Member ID
    CZCC-2363
    Join Date
    Jun 2002
    Location
    Australia
    Posts
    1,818
    Default
    If it's a down draft, then the motor came from a 260C (Cedric).
    I didn't realise the dipstick are different, isn't the L series block all the same?
    MOM
    Mike of the Mire
    73 240Z Rally
    77 260Z Touring
    Bogged but not beaten
  3. #3
    Hakosuka sakijo's Avatar
    Member ID
    CZCC-7932
    Join Date
    Feb 2005
    Location
    Sunny Hawaii
    Posts
    528
    Default
    L-series blocks supposed to be all the same except for minor differences like sump shape and oil pickup location. Alan?
    Miles
    1971 Skyline "Hakosuka"
    2002 Lexus GS 300
  4. #4
    Datsaholic Mr Camouflage's Avatar
    Member ID
    CZCC-1278
    Join Date
    Oct 2001
    Location
    Perth, Western Australia
    Age
    48
    Posts
    3,460
    Default
    I have an L28 in mine. Dipstick doesnt look like its been moved.
    www.nostalgictrio.com Skyline - Silvia - Fairlady Z
    www.ozdat.com The Australian Datsun site.
    www.cafepress.com/vintagedatsun
  5. #5
    OK! ...I made it up. g72s20's Avatar
    Member ID
    CZCC-6441
    Join Date
    Apr 2004
    Location
    Sydney Australia
    Age
    63
    Posts
    564
    Lightbulb
    Isn't it all about whether the sump or deeper pickup area part of the oil pan is forward or backward of the cross member?. If it's forward then the oil pickup would be to the front of the block, and if rearward the pickup would have to be to the rear of the block. I guess the dipstick would have to follow and be above the deeper part of the sump to accurately gauge the oil depth. The Nissan L series went in quite a variety of body shapes.....just a thought.
    Regards,
    Jim.
    1972 Skyline GT-X (GT-R copy)KGC10
    Prince & Skyline spoken here
  6. #6
    Former frequent poster sblake01's Avatar
    Member ID
    CZCC-3797
    Join Date
    Mar 2003
    Location
    San Bernardino, Ca. U.S.A.
    Age
    70
    Posts
    10,574
    Default
    There are front sump and rear sump L6 engines. The pickups are different in that they mount in different locations on the bottom of the block and would require machine work to change one to the other. The rear sump engines were mainly in the S30/S130 cars while the front sump engines were in the sedans 810/910 etc. This is due to the difference in the steering set ups. I'm speaking from my experience with US cars.
    2004 Ford Ranger EDGE Supercab
    (@Moonpup: This one really is an EDGE!)
    2005 Pontaic GTO
    2010 Mercedes Benz C300 AMG Sportline (Wife's car)
    2014 Kia Rio LX (Wife's daily driver)
    Certified HVAC/MVAC Technician
  7. #7
    Member ID
    CZCC-2363
    Join Date
    Jun 2002
    Location
    Australia
    Posts
    1,818
    Default
    I guess the solution is to change over the sump from the "K".
    Still no definitive answer, which is surprising!
    MOM
    Mike of the Mire
    73 240Z Rally
    77 260Z Touring
  8. #8
    Member ID
    CZCC-10708
    Join Date
    Feb 2006
    Location
    Sedan, South Aust
    Posts
    40
    Default
    Ive checked my other engine the other day and found that not only is the dipstick located behind the oil filter in sted of being in front and the sump is not front or rear but in the midle
    Craig can you tell me if your sump is in front or behind the crossmember
  9. #9
    Registered User JMT240KGTR's Avatar
    Member ID
    CZCC-4029
    Join Date
    Apr 2003
    Location
    Australia
    Posts
    279
    Default
    sblake is spot on; having fitted an L28T block to my 240K, (now I can't recall whether it was forward/rear of xmember) the sump/oil pickup/dipstick all needed re-fitting.
    I think I've posted about this before but it's not that easy; the oil gallery for the pickup on the L28T block is located further rear/forward than the 240K block, therefore mod's to the p/up arm were necessary and had to fit nicely, deep inside the new 240K sump housing. This required some measuring & fabrication.
    Then the dipstick hole through the block needs to be drilled in the correct location; bear in mind the sleave for the dipstick cannot be knocked down too far into the block as this will stop oil flow! Run the car like that and it's bye bye.
    There is a guy on ozdat & who frequents this forum from time - time, I think Lurch is his alias, well his friend has either kept or sold this block, not sure.
    Now if you're sump off an L26/L28 is configured like a 240K, no probs at all, straight fit. But this was an issue for me anyway...cheers
    L Series Sixes; can't beat 'em!
    Chrysler V8's; can't beat 'em either!
    1969 VF Valiant 318 Fireball.
  10. #10
    Registered User
    Member ID
    CZCC-28990
    Join Date
    Feb 2013
    Location
    Brisbane
    Age
    41
    Posts
    186
    Default
    I am about to encounter the same problem and am considering a few options. I don't really want to redrill dipstick holes and replumb oil pickups. Option 1 would be to simply put the twin su's off the L26 on to the L24 and that's it. Option 2 would be to use one of my L24 blocks and fit the L26 crank in it. Would only really be up for main bearings, gaskets and seals?? They do fit don't they? Anyone encountered problems or thinks to watch out for when swapping cranks. Thanks Cam.
  11. #11
    Registered User
    Member ID
    CZCC-28990
    Join Date
    Feb 2013
    Location
    Brisbane
    Age
    41
    Posts
    186
    Default
    I am mid rebuild at the moment. Found the L26 I bought has a Camshaft Engineering Cam (old Bris company) and Ported E88 head. Am using my 240k block, sump, pistons and rods. L26 crank, heads and dome top twin su carbs. 240 pistons shaved down 110 thou to compensate for longer rod length and will almost become flat top pistons. Also have the new extractors and 2.5 inch system.I know it will never be a big power engine but the cost is very minimal and I think it should go a bit better. Going to slide it in with the 5 spd hopefully over Christmas.
  12. #12
    Registered User
    Member ID
    CZCC-28990
    Join Date
    Feb 2013
    Location
    Brisbane
    Age
    41
    Posts
    186
    Default
    I have seen 240's on the net with the red cam cover before but after seeing Simo's I decided I should go that way too. Looks so cool with the wrinkle paint. Just need to source some Ramflo airfilters instead of big std airfilter.
  13. #13
    ケンメリ 240k Style's Avatar
    Member ID
    CZCC-28810
    Join Date
    Dec 2012
    Location
    Melbourne
    Age
    37
    Posts
    533
    Default
    Can't go past the Zed airbox IMO for SU's
    Adam
    1975 HGC110 "YONMERI" Datsun 240K GL Sedan
    1976 KHGC110 "KENMERI" Datsun 240K GL Coupe
    1978 MGC210 "Japan" Datsun 240K sedan (sold)
    http://japanesenostalgiccar.com/foru...hp?f=7&t=24596
    Contact Jason at info@jdmfactory.com.au for all your YJ / JDM needs !!
Thread Information
Users Browsing this Thread
Bookmarks
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
