Results 1 to 4 of 4
Thread: alternator pic needed
  1. #1
    Registered User
    Member ID
    CZCC-8975
    Join Date
    Aug 2005
    Location
    SoCal
    Posts
    220
    Default alternator pic needed
    can somebody take a quick digital pic of the back of their alternator?
    mine needs replacing, and i want to use the proper external regulator type (cheap)
    problem is that somebody rewired things so that they could use a lucas (internal regulator?)
    so i'd really like to get a visual
    tia!
  2. #2
    DeesZ (John) DeesZ's Avatar
    Member ID
    CZCC-9676
    Join Date
    Oct 2005
    Location
    Pennsylvania - Millersburg
    Age
    69
    Posts
    745
    Default
    Here are a few pictures of an old externally regulated alternator on my '72 (prior to making an upgrade to an internally regulated unit). You'll note that the external regulator has been removed, but the pictures were taken prior to removing the old alternator.
    Attached Thumbnails Attached Thumbnails Click image for larger version.
ID:	14264   Click image for larger version.
    See my Gallery .....
    http://www.classiczcars.com/photopos...00&ppuser=9676
    John
    CZCC #9676 - IZCC #14985
    1972 - HLS30-84646 - My driver - matching #'s - Nice ride
    1973 - HLS30-132236 - RIP - Reduced to boxes of spare parts in the garage
  3. #3
    Registered User
    Member ID
    CZCC-8975
    Join Date
    Aug 2005
    Location
    SoCal
    Posts
    220
    Default
    thx deesz!
    lachlan also emailed me a pic, and it looks like his car doesn't have an "E" wire either
    i guess they figured the alternator could ground on the engine bracket
  4. #4
    Registered User aarc240's Avatar
    Member ID
    CZCC-10015
    Join Date
    Nov 2005
    Location
    Mid North South Australia
    Posts
    299
    Default
    Didn't much more than glance at this before but ....
    That 'condenser' or 'noise suppressor' (really a capacitor) should have its pigtail connected to the B+ terminal and its body attached to the E terminal. Installed as in the photos it is at earth potential both sides and won't do diddly squat!
    There should NOT be a wire from E to the car body. That should be done at the battery -ve terminal direct to the body AND to the top starter mount bolt.
    You are right that the alternator earths through the mount bracket.
Thread Information
Users Browsing this Thread
Bookmarks
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
