Page 2 of 2 FirstFirst 12
Results 101 to 178 of 178
Thread: Dash Repair Process/Pictures
  1. #101
    Inspiring Z Restorer
    Member ID
    CZCC-16038
    Join Date
    Jan 2008
    Location
    Mesa, Az
    Age
    46
    Posts
    5
    Default
    Wow, excellent work guys! This whole thread is a huge inspiration! I currently have a dash out of my wrecked '81 280zx. That will be the test, for this project. It is sitting outside, as I think of where to start. It looks like I have a lot of different options. I may attempt the Dupli-Color bed liner, since my dash will be black. I am going for an all black interior in my '82 280zx slicktop.
    WildmaN
    '82 280zx N/A T-Tops (daily driver, future turbo swap), '82 280zx N/A Slicktop (project off and on), '83 280zx N/A T-Tops (needs engine), '81 280zx N/A Slicktop (uncertain future), '75 Pontiac Firebird, Looking for a 240z, 260z, 280z, for a future project
    http://www.cardomain.com/id/ZXfreak
    future finished result (hopefully)
  2. #102
    This car is 40 years old?
    Member ID
    CZCC-16464
    Join Date
    Mar 2008
    Location
    Colorado Springs, CO.
    Posts
    91
    Default
    Hi all...
    Well, I too am diving into this repair process head first.
    I had a full dash cap, but decided to try this repair process instead.
    Napa does not stock the bumper repair material any more. They have a few floating around the US, but I decided to go a different route.
    I am using SEM Flexible Polyester Glaze. The SEM part number is 39482. http://semproducts.com/Catalog.asp?prod=122
    It will be interesting to see how this stands up compared to the other materials detailed in this thread.
    Process to date...
    - Beveled all large cracks and filled with Great Stuff foam. Small cracks will be filled with finish material.
    - Cut down the foam using a thin piece of diamond coated cutting wire - worked great and made flush, clean cuts! I happen to work for the company that makes this material.
    - Applied first coat of SEM Polyester glaze. Filled and smoothed out well.
    - Second coat applied. Smoothed out and feathered around the edges very well.
    I have to apply the final filler coat this weekend and finish up the surface prep. There are still a few low spots that I need to finish up and the lines ofer the gauge arcuse are a PITA when you are out of practice doing body work!
    Once this is done, I need to decide which "texture" I will go with. I am doing a COMPLETE interior color change to gray. I will be using the SEM color over the texture finish.
    I hope to have this finished in 2 weeks or so. It all depends on how much time I have left after the spring "Honey-Do" lists are completed...
    A couple of BAD cell phone pics attached. I have taken GOOD photos thrughout the process and will post them once the process is finished.
    I LOVE these car forums!
    Tim
    Attached Thumbnails Attached Thumbnails Click image for larger version.
ID:	41545   Click image for larger version.
ID:	41546   Click image for larger version.
Name:	SEM Glaze.jpg
    Tim Reinhardt - Colorado Springs, CO.
    71' 240Z.
    Build date = 2/71
    VIN# = HLS30-21505
    Rebuilding from the bottom up. Very cool project!
    96' Impala SS - Full custom build from top to bottom. This is my weekend toy!
  3. #103
    240 Z Owner/Nut Case dhoneycutt's Avatar
    Member ID
    CZCC-4557
    Join Date
    Jul 2003
    Location
    Burlington, IA
    Age
    58
    Posts
    269
    Default
    Keep us posted and yes please post pictures. I have two dashes to do!!!
    David A. Honeycutt
    United States Air Force, Retired
    1972 Datsun 240Z HLS3079961
    A Work in Progress
    2004 Mazda 6s
    2009 BMW 535xi
    The Only Difference Between Men & Boys... Is The Price Of Their Toys!
  4. #104
    Registered User 7T1240's Avatar
    Member ID
    CZCC-9354
    Join Date
    Sep 2005
    Location
    Spokane, Washington
    Posts
    275
    Default
    Quote Originally Posted by SSuspect View Post
    Tim
    Tim, hello.
    So I did a quick google search for "diamond cutting wire colorado springs", and came up with a number of listings for Diamond Wire Material Technologies. Is this your employer? Can you provide more info. on what you used specifically, and if it's available to the general public?
    Thanks,
    Gary S.
  5. #105
    Member ID
    CZCC-16464
    Join Date
    Mar 2008
    Location
    Posts
    91
    Default
    Quote Originally Posted by 7T1240 View Post
    Tim, hello.
    Thanks,
    Gary S.
    Hi Gary - Yep - That is me... (don't own it - just work there!) http://www.dmt-inc.com/
    I just used a little bit of our scrapped material to do this. It slices through the foam "like buttah"... NOTE: It will cut through your skin the same way!
    We do sell material to the public. However, it is usually done in volume orders for specific saws and cutting applications. The wire has 6 sizes ranging from 140 microns to 420 microns in thickness depending on the application.
    If you are looking for some "official" uses for this material, I can link you up with the right folks.
    If anybody is looking for this material, please shoot me a PM and I'll be happy to see if I can help.
    Note - Somebody could also use a "wound" steel guitar string (maybe a "D" string) and get nearly the same result.
    Thanks!
    Tim
    71' 240Z.
    Build date = 2/71
    VIN# = HLS30-21505
  6. #106
    Registered User Gary in NJ's Avatar
    Member ID
    CZCC-21253
    Join Date
    Mar 2010
    Location
    Amongst the twisty roads
    Posts
    1,057
    Default
    Yeah but my Martins & Gibsons are not the best cutting tools.
    Gary
    Guardian of HLS30-91415
    Previous Owner of a 10/70 240Z ('83-'85)
  7. #107
    NUTs according to wife ChrisZ's Avatar
    Member ID
    CZCC-14427
    Join Date
    May 2007
    Location
    Denmark - in front of my coffee, behind the laptop
    Age
    55
    Posts
    904
    Default
    And i prefer a G-string
    -73 240Z HLS30-171039
    -66 Roadster SPL311-05204
  8. #108
    Member ID
    CZCC-16464
    Join Date
    Mar 2008
    Location
    Posts
    91
    Default
    Quote Originally Posted by Gary in NJ View Post
    True, but some of the players can shred pretty good!
    Quote Originally Posted by ChrisZ View Post
    ! Me too, but I prefer so see somebody else using one rather than me!
    71' 240Z.
    Build date = 2/71
    VIN# = HLS30-21505
  9. #109
    Member ID
    CZCC-16464
    Join Date
    Mar 2008
    Location
    Posts
    91
    Default Making Progress! Teaser Pics Inside...
    OK... Got to put some good time into the dash this weekend. Here are a couple of teasers. Coming along NICELY! But, it has been a "project" to say the least.
    I will post a full writeup once it is done and back in the car (another week or two). Until then, here is a "work in progress" comparison. Initial ""before and after" pics.
    The white color is a plastic primer. Using it to find highs and lows. Will be sanded off tomorrow night (I am on a mission now!). I still have a couple of small areas to finish (around center gauge and hazard switch). Should get these done this week. I would like to have the new texture finish applied by next weekend if I can.
    Thanks,
    Tim
ID:	41711   Click image for larger version.
    71' 240Z.
    Build date = 2/71
    VIN# = HLS30-21505
  10. #110
    Still plays with cars kenz240z's Avatar
    Member ID
    CZCC-6323
    Join Date
    Apr 2004
    Location
    Berthoud, CO
    Age
    53
    Posts
    738
    Default
    Looking good, Tim. Did you use anything to reinforce the backside of the dash in the areas with the holes (center pod area in your pic)? I fiberglassed the backside of the dash I repaired where it was cracked completely through.
    From your previous pics it looks like the polyester glazing putty works well for the repair. Keep the photos coming!
    Kenny P.
    '73 240Z
    '82 ZX L28
    '82 ZX 5-speed
    Round top SU's
    Tokico HP struts
    Tokico Springs
    Urethane bushings
    my gallery
  11. #111
    Member ID
    CZCC-16464
    Join Date
    Mar 2008
    Location
    Posts
    91
    Default
    Quote Originally Posted by kenz240z View Post
    Thanks Kenny. Great input!
    Since the dash is still out, I should at least throw some resin and a couple of glass strips on the bottom side. I currently have Gorilla Tape under there. It sticks well, but is definitely temporary.
    The polyester is working well and is easy to work with. Longevity? We'll have to wait and see.
    The attached pictures are of the white plastic primer after it was just sprayed and still wet (will be sanded off). But you get the idea. Again, bad cell phone pics, but it is coming out nicely. The "body work" up top is complete. Still need to address a few other issues with the dash before I finish it.
    MY GARAGE (AND EVERYTHING IN IT) IS COVERED WITH SANDING DUST (look at the Z in the background!)! It will take a good weekend to clean all of this stuff up!
    Thanks again!
    Tim
ID:	41765   Click image for larger version.
    71' 240Z.
    Build date = 2/71
    VIN# = HLS30-21505
  12. #112
    Registered User esmit208's Avatar
    Member ID
    CZCC-19498
    Join Date
    Jun 2009
    Location
    308 Palmetto Avenue Melbourne Florida 32901
    Age
    62
    Posts
    464
    Default
    Well here are a few pics of my repair. I actually did two dashes however I haven't put the final coat on the second one. I used metal screws and cut the head off them and then carfeully worked them in. It gave the foam something to attach itself to, or that's the train of thought anyway. NOTE to all who attempt...BE PATIENT! Not difficult
Name:	Gauge prefit.jpg
ID:	41767   Click image for larger version.
ID:	41768   Click image for larger version.
Name:	Dash reinforce.jpg
ID:	41769   Click image for larger version.
    Attached Files Attached Files
    "HAPPINESS"....isn't just around the corner......"HAPPINESS"....is the CORNER"
  13. #113
    Member ID
    CZCC-16464
    Join Date
    Mar 2008
    Location
    Posts
    91
    Default Quick Update
    Well... I went ahead and pulled the harness and everything out of the dash. Tried to avoid it, but I can't help but to dig deeper and get everything done at the same time rather than to re-do it later...
    The dash is ready for final finish and final color. All "body/finish" work is done!
    I painted (almost) all metal surfaces with flat black rust encapsulant. This stuff is thick and does not lay out smoothly, but it is a great coating! It is behind the dash and will not be visible anyway. I will paint the last areas when the dash is installed and all grounds are in place. I also applied 2 layers of fiberglass to the underside of the gauge area. I hope this helps with future cracking issues (thanks for the tip Kenny!). I also need to paint the area on top of the dash where the air vents come through, but will wait to do this after the rest is finished.
    Regardless, I will most likely end up with a carpeted "Dashmat" to help keep the dash safer in the future. Too much work into this to let it get messed up!
    I am hoping to have the dash finished (final color in place and all gauges installed) and back into the car in about 2 weeks.
    I will post an update when there is something worth posting.
    Thanks,
    Tim
ID:	44778   Click image for larger version.
ID:	44779   Click image for larger version.
    71' 240Z.
    Build date = 2/71
    VIN# = HLS30-21505
  14. #114
    Registered User
    Member ID
    CZCC-19261
    Join Date
    May 2009
    Location
    Texas
    Age
    58
    Posts
    1
    Default
    Guys, I've been following this thread for a while. I'm going to be doing this repair soon. Must admit, this is probably THE best thread I've found. I've always hated the fact that I was going to have to use a dash cover since I didn't want to pay the crazy dash restore prices. This fix is something I can do and live with. NICE JOB!!!!
  15. #115
    Member ID
    CZCC-16464
    Join Date
    Mar 2008
    Location
    Posts
    91
    Default Refinishing is DONE!
    Finally got some time to kick this into gear! I just finished the color coat about 2 hours ago.
    Yes - I know that it is not black. Yes, I know that this is not traditional. But, I am not restoring the car to OE anyway. The entire interior is changing to gray. I like "different".
    Finished up the bodywork and sprayed it with the SEM texture coating. It went on fairly dry and had some high spots. I knocked it all down with 400 and then applied 3 coats of SEM "Presidio Gray" Flexible Color Coat.
    I am VERY happy with the results! There is some minor variation in the finish in different areas, but it is not something 98% of the people would notice.
    Speedhut speedometer and tach will be here next week.
    I will post more as it goes into the car.
    Thanks,
    Tim
    One "before" and several "after" shots.
ID:	45111   Click image for larger version.
ID:	45113   Click image for larger version.
ID:	45114   Click image for larger version.
    71' 240Z.
    Build date = 2/71
    VIN# = HLS30-21505
  16. #116
    Member ID
    CZCC-16464
    Join Date
    Mar 2008
    Location
    Posts
    91
    Default
    Quick update...
    Speedhut gauges are installed. Wiring harnesses are in place, but I need to adapt all of the new gauges and sending units. Then I need to install of the air ducts. I am hoping to have the dash back in the car within the next 2 weeks...
    I know that a lot of folks here are not crazy about the interior color change and gauge changes, but it is coming out VERY nice. Can't wait to get everything put back into the car. I do these things for me and really do not follow the crowds too much...
    Tim
Name:	Tach-Speedo Small1.JPG
    71' 240Z.
    Build date = 2/71
    VIN# = HLS30-21505
  17. #117
    Member ID
    CZCC-21253
    Join Date
    Mar 2010
    Location
    Posts
    1,057
    Default
    Indeed it is Tim. It's your car, make sure that YOU are happy with it. Who gives a frack what others think.
    Gary
  18. #118
    Member ID
    CZCC-6323
    Join Date
    Apr 2004
    Location
    Berthoud, CO
    Age
    53
    Posts
    738
    Default
    Hi Tim, the dash is looking great. How did you mount the Speedhut gauges? Did you retain the stock clear plastic lenses? I have a set of Speedhut gauges I need to install in the dash of my V8 Z project.
    Kenny P.
    '73 240Z
    '82 ZX L28
    '82 ZX 5-speed
    Round top SU's
    Tokico HP struts
    Tokico Springs
    Urethane bushings
    my gallery
  19. #119
    Member ID
    CZCC-16464
    Join Date
    Mar 2008
    Location
    Posts
    91
    Default
    Thanks guys. I definitely don't worry too much about what others think. It is all about me!
    Kenny - I have "almost" all of the pics to do a full writeup. Got impatient toward the end and did not take the final pics. I only missed the part where I mount the metal gauge cups back to the rear of the plastic cups. I can talk you through it.
    I am only using the Speedhut speedo and tach. I am not using the stock plastic lens. I did not like the look and had issues fitting everything. I am sure that it can be done and keep the lenses.
    I will take more pics of the rear of the dash and wiring harness later this week.
    Cliff notes...
    - White 4" plastic caps from plumbing section at Home Depot. For sprinkler line - not regular ABS.
    - Cut out solid part of cap to gauge diameter and cut cup to gauge depth
    - Install Speedhut lock TIGHTLY ring into trimmed white cap (Note - ring is tapered - install THIN SIDE IN)
    - Screw gauge into cap and tighten - mark top center for alignment in gauge cup
    - Place into gauge cup and align as needed - hold with tape
    - Mark points on plastic cap that align with the metal tabs on the metal gauge backing cup. These areas will need to be ground down in order to clear tabs
    - Unscrew gauge and paint plastic cap black (keep paint out lock ring of threads)
    - Install gauge back into painted cap
    - Install into plastic gauge cup
    - Install metal backing cup and tighten small factory screws
    - Install into dash
    See attached pics. Definitely trial and error, but they came out nice and they are solid! I will add more later or will start an entire install thread.
    Thanks Tim
ID:	45751   Click image for larger version.
ID:	45752   Click image for larger version.
ID:	45753   Click image for larger version.
ID:	45754   Click image for larger version.
ID:	45756   Click image for larger version.
    71' 240Z.
    Build date = 2/71
    VIN# = HLS30-21505
  20. #120
    Registered User
    Member ID
    CZCC-24627
    Join Date
    Jul 2011
    Location
    anitoch, ca
    Age
    61
    Posts
    3
    Default
    I am glad that i found this site. I will be repairing my own dash now. It cost 2500.00 for a new dash and no way that i want to pay that much for it. I have a 79 280zx and will keep it till my son takes it from my cold dead hands.
  21. #121
    Registered User
    Member ID
    CZCC-8089
    Join Date
    Mar 2005
    Age
    37
    Posts
    1
    Default
    I am redoing mine and i cant get an even texture with the sem, i have sanded it down about 5 times now. i think im going to have to use bedliner or something else, my fingers hurt.
  22. #122
    Registered User
    Member ID
    CZCC-17340
    Join Date
    Jul 2008
    Location
    Pleasanton, CA
    Posts
    2
    Default
    This thread is awesome - I found it years ago and finally got around to doing my 1980 ZX dash. I used the same SEM products mentioned in the original page of this thread and they've worked great. I ended up doing the textture coat twice though, and NOT knocking it down - knocking it down showed too many blemishes and, hey, it's different now
    Tracking down some replacement center gauge bezels right now, as mine's tabs cracked when I removed them - after that, it's in with the dash - I'm really liking it and will post photos once in the car (plus the "before" photos). This took me a long time but with patience anyone can do it!
  23. #123
    Registered User
    Member ID
    CZCC-26031
    Join Date
    Jan 2012
    Location
    Forney, TX
    Age
    77
    Posts
    4
    Default
    I am glad to have found this site, and thread. I don't have a Z car, but am in the process of doing a ground up resto/mod of a 1970 Falcon. My dash pad is huge, and has plenty of damage. Just got off the phone earlier today with Just Dashes, and got an estimate of $950-$1000 plus shipping both ways. After a big gulp, I started to do some searching and found this thread. Sure glad I did, and will try this method in the very near future as well.
    Thanks,
    Otto...
  24. #124
    Registered User
    Member ID
    CZCC-24865
    Join Date
    Aug 2011
    Location
    Shreveport, Louisiana, United States
    Age
    45
    Posts
    3
    Default
    subscribing... Great work from all on this thread. In process on my 71 240 now....
  25. #125
    Registered User
    Member ID
    CZCC-26681
    Join Date
    Mar 2012
    Location
    SGV, California, United States
    Age
    46
    Posts
    4
    Default Duplicoolor torture test
    I'm new to the forum. In fact, this is my first post. My wife and I inherited her grandfather's 1974 260Z several years after he passed away. Unfortunately, in the interim it was parked behind his barn with the windows partially down and the hood up thanks to my wife's cousin. To say it's a mess would be a gross understatement. The dash, in particular, is in very sorry shape. The car had a half dash cap installed on it but the cap had a large crack in it on the driver's side. Upon removing the dash cap I found a badly cracked/worn original dash. This thread has been VERY informative in planning my dashboard's restoration, but like some I had questions as to the suitablility of the Duplicolor truck bed liner material for use in this application. The results posted so far of applying the truck bed coating to dashboards looks good. In fact, it seems to good to be true. Therefore, I have decided to do a little research on this material. I bought a can of Duplicolor truck bed coating and I have already prepared one sample of it on the surface of a cardboard folder. I plan to test the material for: flexibility/resiliency, heat resistance, UV resistance, abrasion resistance, ease of cleaning/detailing, and solvent resistance. I'm attaching pictures of my dash and of the material sample. I'll update everyone and include pictures as I test the material.
ID:	52327Click image for larger version.
  26. #126
    Registered User
    Member ID
    CZCC-27144
    Join Date
    May 2012
    Location
    Germany
    Posts
    1
    Default
    Hi, I'm also a newbie and first want to thank for all of you helping me unknowingly. But with all your help my Lady become as pretty as when she was delivered.
    So after restoring my steering wheel I will start with the dash. My question now is, which is the best structure spray. Which one will match the original structure best. In this thread are just tested the SEM's texture coating and the Duplicolor. Has anyone tested another? Are here quit accidentally some germans who knows an equivalent to the tested one's. I know we can buy the Duplicolor in Germany as well.
    Thanks, Kristian
  27. #127
    Registered User
    Member ID
    CZCC-19940
    Join Date
    Aug 2009
    Location
    Victoria, BC
    Age
    48
    Posts
    53
    Default
    Just an FYI to add to the thread. Great Stuff has a low expansion foam for windows and doors that would probably work better for this particular application.
    "Rachel" - 1972 Datsun 240Z
    "Kayla II" - 1983 Datsun 280ZX
    "Unnamed" - 1983 Datsun 280ZX Turbo
    "Unnamed" - 1993 Nissan 300ZX Convertible
    "Zathina" - 2009 Nissan 370Z 6MT PB Touring Sport
  28. #128
    Newbie ninjazombiemaster's Avatar
    Member ID
    CZCC-27888
    Join Date
    Aug 2012
    Location
    Salt Lake City, Utah
    Age
    27
    Posts
    402
    Default
    This is definitely one of my favorite threads. My dash could definitely use this repair, as I have no interest in a cap. I think I'll look into that low expansion foam for the dash and possibly a similar method with epoxy to repair my center console. Fantastic stuff guys! When I get around to it, I'll give it a try and post pictures.
  29. #129
    HLS30A 17574 djwarner's Avatar
    Member ID
    CZCC-27817
    Join Date
    Aug 2012
    Location
    Central FLorida
    Posts
    405
    Default
    Somebody should make this thread a sticky. I don't know a Z owner that won't face this sooner or later.
  30. #130
    Registered User
    Member ID
    CZCC-24552
    Join Date
    Jun 2011
    Location
    kona hawaii
    Age
    59
    Posts
    481
    Default It's been about 6 years since some of these repairs
    I'm wondering how some of these repairs look 6 years down the road. I've used this sem repair system before on rubber bumpers and
    have had some bubbling problems due to lack of adhesion around the edges where it's feathered and very thin.
    fiberglass over the whole top of the dash seems to me to be the most durable. but... gawd that must stink up the car inside for
    a really long time.
    What's the verdict? anyone around that made their repair 6 yrs ago?
  31. #131
    Registered User EuroDat's Avatar
    Member ID
    CZCC-26512
    Join Date
    Feb 2012
    Location
    The Netherlands
    Posts
    1,420
    Default
    Hi Bruce,
    You did these repairs 6 years ago. We are all wondering how the repairs are holding up after all that time? Would be nice to hear your input. The results you had were amazing.
    Thanks
  32. #132
    Registered User
    Member ID
    CZCC-15087
    Join Date
    Sep 2007
    Location
    Vernal, Utah
    Age
    58
    Posts
    97
    Default '78 Dash Repair
ID:	57857Click image for larger version.
ID:	57858Click image for larger version.
ID:	57859Click image for larger version.
ID:	57860Click image for larger version.
ID:	57861Click image for larger version.
    Well, I finally got around to trying the dash repair process and I couldn't be happier. I followed the proceedure outlined in the thread with the exception of using the SEM Flexible Polyester Glaze. I also substituted the SEM Texture Coating #39853 with SEM Heavy Duty Chip Guard #39793. It had a little better texture I thought. I turned out great.
  33. #133
    Registered User kjohnson2444's Avatar
    Member ID
    CZCC-23233
    Join Date
    Dec 2010
    Location
    Hilliard, Ohio
    Posts
    243
    Default
    Nice work Cajunz. Looks good.
    Keith
    1970 240z - Stock - HLS30-04642
  34. #134
    Supporting Member Diseazd's Avatar
    Member ID
    CZCC-14126
    Join Date
    Mar 2007
    Location
    Richmond
    Posts
    1,852
    Default
    Quote Originally Posted by EuroDat View Post
    Hi Bruce,
    Thanks
    EuroDat........Bruce sold the car to me a couple years ago. The repair is holding up well.......Bruce did a super job. I might add that the car stays in a heated and air conditioned garage.
Name:	BUMPER 005 - Copy.jpg
ID:	57863   Click image for larger version.
    http://www.flickr.com/photos/1404980...7600346077563/
    ______________________________________________
    http://www.flickr.com/photos/1404980...7603350695459/
    70, 71, 2 72's, and a 73 240z....
    90 300zx and a 1996 Acura NSX.....but who's counting?
  35. #135
    Member ID
    CZCC-26512
    Join Date
    Feb 2012
    Location
    The Netherlands
    Posts
    1,420
    Default
    Thanks Diseazd, good to hear its still holding up
    Grats on the top job cajunz. Looks really good.
    I have a cap on mine and now very tempted to try this resto.
    Chas
  36. #136
    Registered User
    Member ID
    CZCC-15087
    Join Date
    Sep 2007
    Location
    Vernal, Utah
    Age
    58
    Posts
    97
    Default
    Eurodat, go for it. Its not that hard. Just take you time and pay attention to the details. If I can do this, anyone can.
  37. #137
    Registered User conedodger's Avatar
    Member ID
    CZCC-16545
    Join Date
    Apr 2008
    Location
    Reno, NV
    Posts
    2,053
    Default
    I'm wondering if this could be done in the car.. I only have one crack and a weird kind of impact like it was hit with a golf ball...
    Rob
    2000 BMW R1100 RT-SE (for sale)
    1999 Toyota 4Runner Supercharged
    1975 Porsche 914 stroker motor autoX car
    1973 Datsun 240Z Restoration project. New paint in original white. E31 head on 2.4 block. Nissan Motorsports header. R200 with Nissan motorsports LSD.
  38. #138
    Registered User
    Member ID
    CZCC-15087
    Join Date
    Sep 2007
    Location
    Vernal, Utah
    Age
    58
    Posts
    97
    Default
    Conedodger, I suppose it could be done in car but would be a pain and make a big mess. You would have to do a lot of masking to keep the spray on texture and paint from getting on everything. You'll also have alot of dust from the sanding. When I first tried this, I used the SEM bumper repair kit. Its pretty expensive for the amount of material that you have to use. The SEM Flexible Polyester Glaze worked better for me. The price is around $40 but I got it for half price because it had been on the shelf for awhile, plus it comes in a 24 oz tube. Not hard to do, just take you time and try not to put the putty on too thick. Also, use a sanding block for the flatter surfaces so you don't end up with groves that you'll be able to see. Around the instrument cluster, I sanded by hand but don't press too hard and just let the paper do the work. The results are definitely worth the time and expense.
  39. #139
    Registered User getrdone's Avatar
    Member ID
    CZCC-3523
    Join Date
    Feb 2003
    Location
    Greensboro, NC
    Posts
    71
    Default
ID:	58214Click image for larger version.
ID:	58215Click image for larger version.
ID:	58216Click image for larger version.
ID:	58217Click image for larger version.
ID:	58218Click image for larger version.
    I used pretty much the same procedure and SEM products that are shown throughout this thread. Thanks everyone for the pictures that helped me along the way.
  40. #140
    Member ID
    CZCC-26512
    Join Date
    Feb 2012
    Location
    The Netherlands
    Posts
    1,420
    Default
    This is truly the most impressive resto job you can do on your car. Really amazed how the old badly cracked dashes turn up like new.
    Im now buzy with 240 bumpers on my 280z and a 71C transmission swap. The next project will be the dash, thanks to you guys.
    My dash is cracked and the PO put a cap on it. He used plenty of glue and I think he might of been cross eyed because it didnt line up to good. It really annoys me when I look at it.
    Grats for the Great posts and the dashes, but that goes without saying, just look at the results.
    Chas
  41. #141
    Member ID
    CZCC-26512
    Join Date
    Feb 2012
    Location
    The Netherlands
    Posts
    1,420
    Default
    Can someone post a link to a shop where you can buy SEM's. Im having trouble trying to find it in Europe and might have to order it over the net. Or a photo of the cans, then I can ask a local if he can supply it.
    Thanks Chas
  42. #142
    Member ID
    CZCC-14427
    Join Date
    May 2007
    Location
    Age
    55
    Posts
    904
    Default
    Try to make a search on Ebay UK, i believe i have seen SEM there, but not sure tho.
  43. #143
    Registered User moritz55's Avatar
    Member ID
    CZCC-14684
    Join Date
    Jul 2007
    Location
    Raleigh, North Carolina 27617
    Posts
    186
    Default Dash Repair while installed in 240z - thanks to this thread. Six10 Epoxy Used !
    Well, I spent 1 week repairing my dash while installed in my car. I didn't want to tear everything out and I was absolutely sick of the dash mat. I followed all of the procedures in this thread ... THANK YOU with one exception. I had trouble smoothing and sanding the SEM Bumper Repair epoxy. With my dash installed it's tough to shape it properly. I had quite a lot of experience using Six10 Marine Epoxy on my boat to repair a swim platform. It's got great bonding and strength characteristics plus it's thick and holds perfectly when spread while also having a 42 minute working life. I applied it with a siringe on top of the cracks still visible from the Stuff Foam allowing it to be reaised above the surface for easy spreading. It spreads superbly thin such that I had at least 1.5 inches spread over the uncracked portions for proper overlap adhesion. It required minimal sanding even though sanding is not to bad after 24hr cure. After I sanded it down pretty well shaping it close to original contour I used car body fine glazing compound to fill scratches and fine pin holes. This allowed me to get the shape pretty well back to original without damaging my windshield (which is 3yrs old - I know, I should have repaired the dash back then - but never thought of it!).
    The Six10 Marine Epoxy Link: Six10 Introduction
    If it were'nt for Six10 Epoxy that I used on my boat so successfully, I would have never been able to tackle this and get the shape right with my dash installed. I hope it holds up well ... will keep you all apprised.
    Here are photos before, during and after completed.
ID:	61850   Click image for larger version.
ID:	61851   Click image for larger version.
ID:	61852   Click image for larger version.
ID:	61853   Click image for larger version.
ID:	61855   Click image for larger version.
ID:	61856   Click image for larger version.
ID:	61857   Click image for larger version.
ID:	61858   Click image for larger version.
    Regards,
    Mark M. .........
    1973 240z HLS30-124668 (9/72), "Deep Beryl Green-PGV"
    2010 370z JN1AZ4EH3AM503017 (3/10), "Black Cherry-NAG"
  44. #144
    Member ID
    CZCC-14684
    Join Date
    Jul 2007
    Location
    Posts
    186
    Default Few more of the finished dash using Six10 Epoxy
    Here's a few more of the finsihed dash..
    Overall it was a bit tricky painting .. I practiced outside the car on a piece of wood to assure I had the SEM texture paint distance right. At best I could only get about 16inches of distance, so after 24hrs, I used a gray scotch brite pad to smooth them down evenly. Then for top coating I used light coats of Dupli-Color Low-Gloss Black (DE1634) and Semi-Gloss Black (DE1635) which withstands excessive temperatures. Alternating light coats allowed me to blend to the original face which had more luster. This paint is used on all types of engine parts and bonds superbly to clean surfaces of all types.
    Anyway .. many thanks for this outstanding thread. I would not have tackled this dash repair while still installed if I did not have materials that worked easily for shaping the dash back to almost original contour.
    It's denfintely better than having the dash mat. Let's see how it holds up in the North Carolina Summer!
    Happy St. Patrick's Day to all ...
    Mark
ID:	61862   Click image for larger version.
ID:	61861   Click image for larger version.
ID:	61860   Click image for larger version.
ID:	61863   Click image for larger version.
    Regards,
    Mark M. .........
  45. #145
    Member ID
    CZCC-27888
    Join Date
    Aug 2012
    Location
    Age
    27
    Posts
    402
    Default
    I absolutely love seeing the results on this thread. Can't wait to get to mine.
    1973 240z w/ ztherapy round top conversion.
  46. #146
    Member ID
    CZCC-26512
    Join Date
    Feb 2012
    Location
    The Netherlands
    Posts
    1,420
    Default
    Quote Originally Posted by ninjazombiemaster View Post
    Me too. This would have to be the Nr. 1 resto for result versus' time and effort. Just amazing.
    Chas
    5/77 280Z HLS30 403100 with some modifications
    Original colour: 305 Light Blue. The PO changed it to Red
  47. #147
    Registered User
    Member ID
    CZCC-29198
    Join Date
    Apr 2013
    Location
    United States
    Age
    31
    Posts
    2
    Default
    I got so excited when I found this thread. Just recently bought myself a 1972 240z started to get the dash out and everything was working smoothly until i bumped my steering column. Driver side just broke off it was very brittle. No luck in saving it now. No idea what to do now. Any suggestions?
  48. #148
    Registered User
    Member ID
    CZCC-24552
    Join Date
    Jun 2011
    Location
    kona hawaii
    Age
    59
    Posts
    481
    Default picture?
    got pictures of this dash? i cant imagine the whole dash broke apart just by bumping the steering column.
    Quote Originally Posted by DatRedZ View Post
  49. #149
    Registered User
    Member ID
    CZCC-29198
    Join Date
    Apr 2013
    Location
    United States
    Age
    31
    Posts
    2
    Default
    I don't have any. Went ahead and pieced it together this morning I used finishing nails for them to stick. I have it drying right now with the foam. Going to attempt to mold the missing pieces I couldn't find
  50. #150
    Supporting Member Zedyone_kenobi's Avatar
    Member ID
    CZCC-16285
    Join Date
    Mar 2008
    Location
    Houston
    Age
    47
    Posts
    2,919
    Default
    THATS IT
    I am doing this next. The result are just too fantastic!!!
    And if it does no work, I will just slap a damn cap back on it.
    BRAVO everyone who has done this!!!
    1971 240Z HLS30-38691
    93.9% done and getting better every day
    Now with 100% more DATSUN SPIRIT L28 Power
    1968 Datsun 2000 SRL311-03416
  51. #151
    Fumblin'Bumblin Z car fan
    Member ID
    CZCC-2858
    Join Date
    Sep 2002
    Location
    Atlanta
    Age
    51
    Posts
    111
    Default
    Nothing like jumping onto a 4 year old thread, but I am going to do this process to 2 dashes this weekend, and will seel one...gotta raise some funds!
  52. #152
    Member ID
    CZCC-2858
    Join Date
    Sep 2002
    Location
    Atlanta
    Age
    51
    Posts
    111
    Default
ID:	70742Here's my progress so far - it is slow, but kids have to eat and stuff.
  53. #153
    Member ID
    CZCC-2858
    Join Date
    Sep 2002
    Location
    Atlanta
    Age
    51
    Posts
    111
    Default
ID:	70743And here's the Great Stuff sliced off.
  54. #154
    Registered User HaZmatt's Avatar
    Member ID
    CZCC-29861
    Join Date
    Nov 2013
    Location
    Colorado
    Age
    44
    Posts
    160
    Default
    Hello. I am in the process of repairing my dash as well and I just wanted to share something. I am using the Bondo brand bumper repair kit.(similar to SEM). Yesterday I had the dash laying on my bench about 4' high and this morning when i came out to the garage it was laying on the ground. I thought for sure it was ruined. To my surprise it held up perfectly. No cracks at all. This stuff is strong and I see this as a permanent fix.
ID:	70757Click image for larger version.
ID:	70758Click image for larger version.
  55. #155
    Member ID
    CZCC-2858
    Join Date
    Sep 2002
    Location
    Atlanta
    Age
    51
    Posts
    111
    Default
    I ended up using Evercoat flexible poly for my coating. I saw lots of posts about NAPA and Bondo, etc, but those didn't have enough product for what I was wanting. Lots o cracks. It sands well, which was a concern of mine. I will post pics as soon as I get it finished. Thanks for the inspiration!
  56. #156
    Member ID
    CZCC-27817
    Join Date
    Aug 2012
    Location
    Central FLorida
    Posts
    405
    Default
    I attempted a repair with SEM bumper repair and was shocked just how fast it set up. I did manage to get a butt joint bond to the vinyl on two of the three cracks. I thought this might be sufficient as I had stop drilled the ends of the cracks.
    The repairs last a matter of weeks before the butt joints failed and a hairline crack re-appeared. Considering the thinness of the crack, I tried filled with crazy glue filled with micro-balloons used in model aircraft. This also failed. At first I thought it was caused by heat, but over time I've noticed the cracks widen on a cold night and close up in the hot summer sun.
    I have come to realize that the butt joint will never be strong enough using any kind of adhesive due to the small bonding area. The would indicate a lap joint is needed by inserting a piece of plastic bridging both sides of the crack. Getting good pressure to achieve a good bond would problematic when pressing against the soft, deteriorating foam rubber.
    I recalled Edd China doing a front plastic bumper cover repair on Wheeler Dealers. He made a point of drilling holes on each side of the crack so that the epoxy not only spanned across the crack, but also through the hole.
    The Six10 material looks promising. I'm contemplating adding a substrate to for a lap joint, adding through holes, and securing the substrate with sheet metal screws while waiting for the epoxy to set up. After its sets up, I'll remove the screws and fill the holes with more Six10.
    1971 240Z HLS30A 17574 L24-021025
  57. #157
    Member ID
    CZCC-2858
    Join Date
    Sep 2002
    Location
    Atlanta
    Age
    51
    Posts
    111
    Default Progress so far
    Evercoat Applied - sanding tonight. Going good so far!
  58. #158
    Registered User mjr45's Avatar
    Member ID
    CZCC-21301
    Join Date
    Mar 2010
    Location
    Divide, CO
    Posts
    572
    Default
    I've been watching this thread for a long time and would like to do my dash. Currently it has a full dash cap that I've tried multiple methods to remove(dash is still in the car), I've let it sit outside in the sun, tried a heat gun(don't do this) tried prying and pulling and no luck so far it appears that when the cap was put on, it was slavered with glue on the top but not much on the bottom end. Any suggestions, besides take the dash out and just rip it off?
    75 280Z almost done
    49 Chevy 3100 p/u next project
    96 Dodge 2500 4X4 tows my 5th wheel
  59. #159
    Member ID
    CZCC-2858
    Join Date
    Sep 2002
    Location
    Atlanta
    Age
    51
    Posts
    111
    Default
    Did you take the metal plate off the front of the dash where it meets the windshield? I imagine that w/o doing that, you'd have a very hard time getting the cap off.
  60. #160
    Registered User
    Member ID
    CZCC-30399
    Join Date
    Apr 2014
    Location
    Windsor, California
    Posts
    17
    Default
    Well, I wonder if anyone has done a custom dash? I want to see pics of creations if so. We are considering a new flat aluminum face with hardwood cap either varnished or wrapped in leather. Custom center console to match.
    The father-son resto of a '72 with '83 turbo ...
  61. #161
    Member ID
    CZCC-29861
    Join Date
    Nov 2013
    Location
    Colorado
    Age
    44
    Posts
    160
    Default
    What are you guys using for primer? Is it necessary to use a flexible primer?
  62. #162
    Member ID
    CZCC-29861
    Join Date
    Nov 2013
    Location
    Colorado
    Age
    44
    Posts
    160
    Default
    Just found this if anyone wants to try it. Looks promising.
    Amazon.com: Padded Dash Filler: Automotive
  63. #163
    ZCCIV Webmaster motorman7's Avatar
    Member ID
    CZCC-19125
    Join Date
    Apr 2009
    Location
    San Diego CA
    Age
    58
    Posts
    988
    Default Roadster Dash
    So, I figured I could do this on my roadster same as everyone else has done for their Z dashes. Sure enough, the final product came out looking pretty nice. I am very happy with the results. I must say, however, this was really a lot of work only because the dash seemed to be pretty warped. It wasn’t just a matter of cutting and filling the cracks, that part was pretty easy and took me about 3 Bumper bite applications to finish. The warped dash however was very obvious and took about 6 more iterations of Bumper Bite to get resolved, meaning it was a lot of work.
    Then, after putting on the second coat of texture paint and hanging to dry, the dash came un-hooked and dropped two feet to the concrete, resulting in two more applications of Bumper Bite on the end and repaint. Anyway, once the paint was on everything was looking pretty good. The texture finish is matte and picks up all finger prints that touch it so I put a couple coats of clear over the texture spray. That works out pretty well and gives the final finish which is a bit glossy, but very nice.
    I also go the original 44 year old clock working. I took the little motor apart and notice the gunk on the armature where the two brushes contact. I cleaned the gunk off with carb cleaner and used electronics cleaner spray on the mechanism and the clock started right up when I applied 12 volts. Pretty cool. After 24 hours it seems to run a couple minutes fast, but it is still running.
    Anyway, here are the pics. Hope to have the dash with gauges and glove box assembled and on car in the next week here or so. Making some pretty good progress.
    Rich
ID:	70976   Click image for larger version.
ID:	70977   Click image for larger version.
Name:	Dash Re-furb stuff.jpg
ID:	70978   Click image for larger version.
Name:	dash_almost finish.jpg
ID:	70979   Click image for larger version.
    HLS30-02614 in the Cocoon
    HLS30-40147 Very Yellow Daily Driver
    HLS30-40498 Next resto
    SPL311-27444 It lives
    http://www.rcdeng.com
  64. #164
    Member ID
    CZCC-29861
    Join Date
    Nov 2013
    Location
    Colorado
    Age
    44
    Posts
    160
    Default
    My dash was in need of some love so I followed the dash repair techniques on this forum and I think it came out really good. Not perfect but 100X better than it was. I ended up spending about $100 on materials and a good week or 2 of working on it here and there.
Name:	2014-05-10 11.31.20.jpg
  65. #165
    Registered User suprayoshi's Avatar
    Member ID
    CZCC-30477
    Join Date
    May 2014
    Location
    United States
    Age
    33
    Posts
    1
    Default
    I'm gonna be pulling the dash from my Z this weekend and try this out, but i was wondering what y'all did to get the shape back in the pod holes? cause mine are out of round, do i just pull it till its right or is there a better way of doing this?
    Thanks!
    dfvefv
  66. #166
    Registered User
    Member ID
    CZCC-29959
    Join Date
    Dec 2013
    Location
    LA
    Posts
    9
    Default
    I recently did my 280Z dash. It came out pretty good for the 1st time attempting something like this. It looks way better than a dash cap, that's a definite. I used great stuff to fill the cracks, the padded dash filler and flexible dash texture from Urethane Supply Company. Stuff is very flexible, almost like rubber. I Da'd it all smooth. I also used speedhut gauges for the tach and speedo. If you use a 4" DWV cap (it has a flat end, not rounded) from ace hardware, the hole saw for the gauge cutout fits just about perfects inside the cap, so it sort of self centers, to fit the gauge in, you have to file off the knubs on the locking ring for the gauge, then that's a tight fit inside the cap, and the cap OD is about 1/16" smaller than the gauge pod ID, so it all fits together just about perfect.
    Padded Dash Filler
    Flextex VT Texture Spray
  67. #167
    Registered User
    Member ID
    CZCC-26031
    Join Date
    Jan 2012
    Location
    Forney, TX
    Age
    77
    Posts
    4
    Default
    I'm getting ready to try this on the dash pad of my 1970 Ford Falcon. Am wondering what people are using to remove the old, cracked, portions prior to filling them with the Great Stuff?
    Didn't want to post any photos of my current pad since it's not a "Z" car, but will if the community approves.
    Thanks in advance,
    Otto...
  68. #168
    Registered User nix240z's Avatar
    Member ID
    CZCC-24576
    Join Date
    Jun 2011
    Location
    usa
    Posts
    205
    Default
    Quote Originally Posted by Otto View Post
    Thanks in advance,
    Otto...
    I used a dremel with a small bit.
    Steve
  69. #169
    Registered User
    Member ID
    CZCC-26031
    Join Date
    Jan 2012
    Location
    Forney, TX
    Age
    77
    Posts
    4
    Default
    Quote Originally Posted by nix240z View Post
    Steve
    Thanks for the reply, Steve.
    I was thinking about using my Dremel, but wasn't sure what type of bit to use. Would you use a stone type, or a metal cutting bit similar to a die grinder type?
    Otto...
  70. #170
    Member ID
    CZCC-24576
    Join Date
    Jun 2011
    Location
    usa
    Posts
    205
    Default
    Otto...
    I used the tungsten steel solid carbide burr bits.
    Steve
  71. #171
    Registered User
    Member ID
    CZCC-26031
    Join Date
    Jan 2012
    Location
    Forney, TX
    Age
    77
    Posts
    4
    Default
    Great, thanks Steve.
  72. #172
    Registered User
    Member ID
    CZCC-21286
    Join Date
    Mar 2010
    Location
    Ontario, Canada
    Posts
    55
    Default
    I've just finished my dash project. Will post pix and notes later, when time allows. I tried a lot of different bits in my Dremel when working on the vinyl overlay (which is ~ 1/16" thick). It's very a tricky process. Too aggressive with bit choice/speed results in melting rather than abrading, and creates a mess. The goal is to feather-edge the vinyl so that the top-coat filler (I used SEM Bumper-Bite) has a good edge to bond onto. In the end, I found that an engraving-type bit (all-metal, ball-tip -- not the textured tip -- the one I had good results with looks like it's fluted, like a drill bit) with medium-low rpm worked best. My attempts with various rotary sanding discs were unsuccessful (too easy to overshoot the vinyl and accidentally create unwanted deep gouges into the old foam underlay). This job requires a lot of patience to do right. I used a cable-type extension drive, hooked up to my Dremel tool, in order to get the bit at the right cutting angle. Remember to wear safety glasses (a small chip of vinyl cutting lodged in the eye is not a happy experience - don't ask me how I know this).
    Be sure that you cut back the vinyl and oem foam far enough away on each side of the crack to get past the curled-up area. Otherwise, you'll end up with a big problem when you start sanding. Avoid cutting too deep into the oem foam during this cut-back process, Otherwise, you'll end up having to use too deep a layer of Bumper-Bite (which, by the way, isn't really all that flexible). Aim for a depth of Bumper-Bite fill that's no more than 3/16".
    Important FYI - Even though the textured bedliner paint looks like it will mask small mistakes in your sanding/contouring job, you may as well know right now that it doesn't. Be sure to put a full primer coat over the sanded areas of your dash before you even think about reaching for the bedliner spray can. Then take a long, hard look at your work under natural sunlight before you proceed to the bedliner spray (shop lighting won't tell you the whole story).
    I found that sanding the Bumper-Bite to get true contours over the arches of the gauge clusters was r-e-a-l-l-y difficult to get right (you'll be working with a combination of concave, convex and flat surfaces -- the convex ones being the most difficult to get right). Recommend you get a set of hard-foam sanding blocks from Eastwood for this job. There's one in this set that has an onion-type cross-section that works really well for the concave and flat surfaces of this job. However, none of these blocks is suitable for the convex contours of the gauge bezel peaks. I recommend you find a piece of properly contoured thick rubber for this part of the job (go to the plumbing section of your hardware store and look for a large-diameter rubber pipe-joint, and then cut a small section out as your sanding pad).
  73. #173
    Registered User lcord's Avatar
    Member ID
    CZCC-15641
    Join Date
    Nov 2007
    Location
    Redondo Beach, CA
    Age
    61
    Posts
    38
    Default
    If you had a hairline fracture would you still need to widen the gap?
    Thanks
    Larry
  74. #174
    Registered User
    Member ID
    CZCC-21286
    Join Date
    Mar 2010
    Location
    Ontario, Canada
    Posts
    55
    Default
    My dash had three, full-span cracks and that was what made me decide to do the repair. However, when I had the dash out and sitting on my workbench under good lighting, I found a few tiny hairline cracks (~ 1/16" long) along the forward (windshield) edge. My guess is that these little cracks are the way that the big cracks get started. All I did was grind out the vinyl top surface locally so that the ends of each little crack got round edges. What I would end up with in each case was a cut in the vinyl that was the width of the tip of my Dremel bit ( ~ 1/8") and -- in length -- a little bit longer than the original hairline crack. The ball-shape of the Dremel bit automatically gave me the rounding that I wanted at each end of the crack.
    If you've got a long hairline crack (I've never seen this -- they usually open up, starting from the windshield and getting wider as they track towards the gauge openings), you still need to: 1) 'V' the edges of the vinyl all along the length of the crack (so that you filler coat has something to bond to), and; 2) round off the end of the crack, to stop it from growing any further. You should probably try to fiberglass along the underside of the dash foam too (that is, if you can access the crack area from underneath), because a long hairline crack is almost certainly going to grow as the old foam shrinks and pulls back (and Bumper-Bite filler on the top isn't going to stop this from happening).
  75. #175
    Member ID
    CZCC-15641
    Join Date
    Nov 2007
    Location
    Redondo Beach, CA
    Age
    61
    Posts
    38
    Default
    Thanks so much for the detailed information. This is really helpful. I ordered the ball-shaped Dremel bit that you suggested and waiting for delivery.
    Thanks
    Larry
  76. #176
    Registered User sdyck's Avatar
    Member ID
    CZCC-30672
    Join Date
    Jul 2014
    Location
    Calgary Alberta
    Age
    57
    Posts
    32
    Default
    This is in my future so a couple of quick questions.
    1. Hazmat asked about primer but I didn't see an answer. What are you guys using for primer?
    2. I'm assuming the texture is different enought that the full dash needs coating?
    3. Is everyone clearcoating afterwards? I'm not sure I'd like a shine to the dash.
    Thanks!
  77. #177
    Registered User
    Member ID
    CZCC-29959
    Join Date
    Dec 2013
    Location
    LA
    Posts
    9
    Default
    I used a cone shape stone in my dremel. Thats what the guy recommended when I called to order the dash repair stuff. It gave a good controllable cut. Make sure you go past the end of cracks and round them to make it a little less likely to crack. I used a DA on very slow speed to sand the urethane supply padded dash filler. This stuff is way too rubbery, it takes a while to knock it down by hand if you get it too thick, which I did. Still can't understand why people use something to fix bumpers on dashes when there is something made for specifically repairing dashes. Urethane supply recommended a flat or satin vinyl paint to topcoat it with if you wanted to coat it for some extra UV protection. They said a high gloss coat may give you a lot of glare depending on the car.
  78. #178
    Member ID
    CZCC-15641
    Join Date
    Nov 2007
    Location
    Redondo Beach, CA
    Age
    61
    Posts
    38
    Default
    Good question! This brings up another question. Should the final coat of the dash be the same color of the other trim areas. For example if I paint the dash in Landau black should I paint all the interior in the same color?
    Thanks
    Larry
Thread Information
Users Browsing this Thread
Bookmarks
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
