Results 1 to 42 of 42
Thread: Fog Lamps
  1. #1
    Registered User widget777's Avatar
    Member ID
    CZCC-11721
    Join Date
    Jun 2006
    Location
    Gig Harbor, Washington
    Posts
    48
    Default Fog Lamps
    I am thinking of putting driving/fog lamps on my 78 280Z that has stock front bumpers and body panels. I am open to the type of fog lamp but have been looking at the hella rectangular lamps in Black Dragon's catalog. I have 2 questions:
    1) where should I mount them to keep them out of harm's way?
    2) What lamps would you recommend if not the Hellas?
    Regards,
    Warren Thomson
    Gig Harbor, WA
    253-970-5242 cell
  2. #2
    240Z Original Owner ZIII's Avatar
    Member ID
    CZCC-7417
    Join Date
    Dec 2004
    Location
    El Paso, Texas
    Posts
    240
    Default
    There’s a difference between fog and driving lights…. Fog lights should be mounted as close to the ground as you can get. I hang mine down from the bumper and if I could get them lower I would. If you have a front spoiler, or you are thinking of getting one, you might want to consider putting them in there as some spoilers have slots for lights and these are usually well spaced apart which is good. For fog, low is best. Driving lights, on the other hand, are usually mounted higher, either above the bumper or inside the grill.
    I lived in Belgium for seven years and fog is an almost daily occurrence in the country. As a matter of fact, EU law mandates that you have a proper rear fog light (red) as well as a First Aid kit, fire extinguisher and safety triangle. I went through Bosch lights (pretty mediocre) Cibie (better) and Hellas (pretty good at the top of their line). It wasn’t until I rode in a friend’s car one night when I realized what fog lights could do. His lights were PIAA. Next day I went out and bought a set and let me tell you they are absolutely fabulous. I put them on all my cars. The others pale in comparison and capabilities. Besides the obvious benefits of light projection, the PIAA’s come with a more substantial relay and wiring set-up. They are not dinky 18 gauge wires etc…commonly found on most other light sets. It is just a quality product. The one drawback is that they are a bit pricy but they are, IMO, the best and well worth the extra money.
    I now have a set of PIAA driving lights (I now live in El Paso and there’s no fog here) that I placed in the same holes as the fogs underneath the bumper. Not the ideal place, but I wasn’t going to put any more holes in my bumpers. The PIAA driving lights are also phenomenal!!! So, I would recommend that you do some research. Some folks will jump in here and they will have their recommendations but do give PIAA a look and consider them. You will not regret it.
    George
    73-240Z, Original Owner
    Triple Mikuni Carbs
    5-Speed
    3.90 Diffy
    2:58 inch Exhaust
    Tokico Shocks/Springs
    105 Amp Alt
    MSD 6A ignition/coil/wires
    4 Core Radiator
    McIntosh Audio
  3. #3
    Member ID
    CZCC-11721
    Join Date
    Jun 2006
    Location
    Posts
    48
    Default
    Gearge,
    Thanks for the input. You sound like an expert. I will investigate teh PIAAs
    Regards
    Widget
    Regards,
    Warren Thomson
    Gig Harbor, WA
    253-970-5242 cell
  4. #4
    Member ID
    CZCC-11721
    Join Date
    Jun 2006
    Location
    Posts
    48
    Default
    George,
    Do you pics of teh front end?
    Regards,
    Warren Thomson
    Gig Harbor, WA
    253-970-5242 cell
  5. #5
    Her Majesty the 26th 26th-Z's Avatar
    Member ID
    CZCC-4148
    Join Date
    May 2003
    Location
    Sarasota, Florida
    Age
    67
    Posts
    3,854
    Default
    I have these - $100 - PM me.
    Attached Thumbnails Attached Thumbnails Click image for larger version.
Name:	FOG LIGHTS 1.jpg
ID:	16622   Click image for larger version.
Name:	FOG LIGHTS 2.jpg
    Enjoy the Ride
    HLS30-00026
    HLS30-00027
    http://home.earthlink.net/~cwenzel/index.html
    Go Gators
    Go Butler Bulldogs
  6. #6
    Known Zitus carrier! hls30.com's Avatar
    Member ID
    CZCC-4106
    Join Date
    May 2003
    Location
    Savannah, Georgia
    Posts
    6,702
    Default
    Warren,
    I'd jump all over those if I were you!
    Will
    A Z is beautiful from any angle, I just happen to prefer to view from the drivers' seat!
  7. #7
    Member ID
    CZCC-4148
    Join Date
    May 2003
    Location
    Sarasota, Florida
    Age
    67
    Posts
    3,854
    Default
    I was (and still am) looking for these when I bought the ones I would sell. Chloe (remember her?) e-mailed me with a zcar.com ad and I bought them sight unseen. I think they are for the 280Z as a Datsun option. They are in pretty good shape but I do not know if the bulbs work. Metal and plastic housings. Glass lens. Plastic slip-on caps. I recall one of the caps has a scratch.
Name:	Fog Lamp3.jpg
    Enjoy the Ride
    HLS30-00026
    HLS30-00027
    Go Gators
    Go Butler Bulldogs
  8. #8
    Registered User
    Member ID
    CZCC-3237
    Join Date
    Dec 2002
    Location
    Sunriver, Oregon
    Age
    59
    Posts
    52
    Default Series 1 fog/driving lights?
    Does anyone have a good picture of the stock lights that are listed in my factory wiring diagram and is switched at the choke plate area. I can't say I have ever seen how this was done. I believe/ or led to believe this was a option on the overseas cars.
    Thanks,
    Bob
  9. #9
    Member ID
    CZCC-4106
    Join Date
    May 2003
    Location
    Savannah, Georgia
    Posts
    6,702
    Default
    I think the lights that switch there are actually running lights that are individually switched(L or R side) for safety in pulling off the road, several threads have discussed this, and the fog light switch was actually on the dash in what lookes like a conventional cigarette lighter position. I'll try to find a thread and post it for you.
    Will
  10. #10
    Member ID
    CZCC-4106
    Join Date
    May 2003
    Location
    Savannah, Georgia
    Posts
    6,702
    Default
    Bob, here you go... there are more...
    http://www.classiczcars.com/forums/s...ght=jdm+switch
    Will
  11. #11
    Registered User
    Member ID
    CZCC-3237
    Join Date
    Dec 2002
    Location
    Sunriver, Oregon
    Age
    59
    Posts
    52
    Default Thank You...
    Thanks for the link, that clears it up. So, the early cars never had any kind of front driving light?
    Enjoy the ride,
    Bob
  12. #12
    Semi-retired admin Arne's Avatar
    Member ID
    CZCC-8596
    Join Date
    Jun 2005
    Location
    Eugene, Oregon, USA
    Age
    64
    Posts
    8,465
    Default
    Hi, Bob. Nice to see yet another Oregonian here!
    The early cars in other parts of the world could have fog lights as an option, but they were never offered on 240Zs here in the states. Escanlon (in Vancouver, WA) has one of the factory fog light switches, I believe. It went in the empty hole above the hazard switch on the early dashes.
    Arne - Former owner, HLS30-37705, 7/71, 905 Red
    Car blogs - 240Z - Porsche 911
  13. #13
    Member ID
    CZCC-4106
    Join Date
    May 2003
    Location
    Savannah, Georgia
    Posts
    6,702
    Default
    26thZ pictured them earlier in his second post-they were available through Datsun Compettion parts.
    Will
  14. #14
    Registered User kats's Avatar
    Member ID
    CZCC-3193
    Join Date
    Dec 2002
    Location
    JAPAN
    Age
    51
    Posts
    850
    Default  I need a fog lamp
    Hello,
    The fog lamp is very rare here in Japan.We acturely could buy them as an option listed in the brochure.
    Mr.Matsuo gave me only one fog lamp which he managed to find from his old stock yards.Remember Mr.Matsuo owned a 1971 Fairlady-Z(type Z,standard) and he bought hubcaps,fog lamps and some other stuff.He wanted to buy Z as soon as posssible when he had done Z's designe because he really proud and loved his job for S30 series.But at that time Nissan had to ignore emproyee's parchase,due to huge waiting lists all over the world.
    We can not see the part number of the fog lamp in the NOV 1969 U.S. & CANADA catalog.But we can see them in the 1969 R-DRIVE S30 parts catalog.
    Chris,you put the picture of yellow classic fog lamps they are 26150/26155-E4100 I think that picture came from a Yahoo Japan auction some years ago?Because I too was watching them for bidding.But I failed,my friend won for them.I also have saved that image in my computer when I was watching.
    I put pictures of my only one fog lamp from Mr.Matsuo and a fog lamp switch of Jan 1970 Z432(PS30-00088) now restoration in progress.This switch's picture was taken by mobile phone camera so it is not good.
    I need one more fog lamp.
    kats
ID:	16631   Click image for larger version.
ID:	16632   Click image for larger version.
    Katsuhiko Endo
    1970 DATSUN 240Z
    HLS30-02156 (03/70)
    L24-005562
    1970 FAIRLADY Z432
    PS30-00088 (01/70)
    S20-000884
    1972 DATSUN 240Z
    HLS30-60213 (12/71)
    L24-072419
    JAPAN
    Welcome to my web site,
    http://www.geocities.jp/datsunz903
  15. #15
    Registered User
    Member ID
    CZCC-3237
    Join Date
    Dec 2002
    Location
    Sunriver, Oregon
    Age
    59
    Posts
    52
    Default
    Kats,
    Thanks for the information. Can you let me know roughly what size those factory fog lights are? Also, where did they mount? I assume to the bumper.
    Your web site is a wealth of great information.
    Thanks so much for sharing. Love the blue car. My first experience was with a blue care with the white racing stripe. When I went to buy my early z, I just missed out on a blue car and ended up with a silver one on my way home.....
    Thanks,
    Bob
  16. #16
    Member ID
    CZCC-4148
    Join Date
    May 2003
    Location
    Sarasota, Florida
    Age
    67
    Posts
    3,854
    Default
    As usual, Kats, you make me jealous.
Name:	fog lamp position-1.jpg
    Enjoy the Ride
    HLS30-00026
    HLS30-00027
    Go Gators
    Go Butler Bulldogs
  17. #17
    Member ID
    CZCC-4106
    Join Date
    May 2003
    Location
    Savannah, Georgia
    Posts
    6,702
    Default
    Thanks Kats, I had researched the threads looking for exactly the pictures you just posted-a front and rear shot!
    Can you tell what manufacturere made them?
    Thanks!
    Will
  18. #18
    Member ID
    CZCC-7417
    Join Date
    Dec 2004
    Location
    El Paso, Texas
    Posts
    240
    Default
    Warren,
    Thank you for the compliment. I can assure you that I am not an expert on fog lights. I am, however, the beneficiary of my own experience. If you live in a geographical area that really requires fog lights then you should get a proper set. While in Belgium, I went through a successive series of lights with water getting in the housing, lenses getting fogged over, rust developing in the reflectors and little light cutting thru fog. Like many other folks, my motto was how little can I pay to get an acceptable outcome. Wrong thought process. But it seems like I always have to re-learn this lesson.
    Most folks are not confronted with such adverse weather conditions and put lights out in front because they look cool or make the car go faster. In Europe you can get a ticket for running your fog lights when there’s no fog. Imagine that here? Anyway, I digress. Fact is PIAA are great lights and well worth your consideration. Jump on corvette forum and do a search and you shall find many more praises for such lights in both fog and driving format. My vette lights set me back $240 but on many a night driving through the Belgium countryside I would have happily paid double and would have been thankful for it.
    On another note, there is really no such thing as a driving/fog light. It is one or the other. There are some sets made that are both but they have two housings/reflectors and two different bulbs.
    Attached are my current PIAA driving lights… as I mentioned, they are not mounted in the ideal spot but have replaced my fogs which were mounted on the underside of the bumper. Also, I have included a pic of the relay, which is in white. The two black relays on the left of the PIAA are from Dave’s headlight wiring harness.
Name:	Fog Light.jpg
ID:	16651   Click image for larger version.
Name:	Fog Light 2.jpg
ID:	16652   Click image for larger version.
    George
    Triple Mikuni Carbs
    5-Speed
    3.90 Diffy
    2:58 inch Exhaust
    105 Amp Alt
    4 Core Radiator
    McIntosh Audio
  19. #19
    Member ID
    CZCC-11721
    Join Date
    Jun 2006
    Location
    Posts
    48
    Default
    26th Z<
    what are the dimensions of teh light sets? I presume that you are selling both sets. If so , how much for the fog lamps. I am concerned that I will not be able to get replacement bulbs for the lights. Do you know what bulbs they use and the wattage?
    Regards,
    Warren Thomson
    Gig Harbor, WA
    253-970-5242 cell
  20. #20
    Member ID
    CZCC-11721
    Join Date
    Jun 2006
    Location
    Posts
    48
    Default
    George,
    What model PIAA are they?
    Regards,
    Warren Thomson
    Gig Harbor, WA
    253-970-5242 cell
  21. #21
    Member ID
    CZCC-7417
    Join Date
    Dec 2004
    Location
    El Paso, Texas
    Posts
    240
    Default
    Warren,
    The driving lights on the Z are PIAA 60 XT series, model 6252.
    George
    George
    Triple Mikuni Carbs
    5-Speed
    3.90 Diffy
    2:58 inch Exhaust
    105 Amp Alt
    4 Core Radiator
    McIntosh Audio
  22. #22
    Member ID
    CZCC-4148
    Join Date
    May 2003
    Location
    Sarasota, Florida
    Age
    67
    Posts
    3,854
    Default
    I need to go out to the shop and get the lamps. I'll measure them and post some answers. I have two lamps = one set. I believe they were 280Z vintage Datsun options and I don't know if they are fog or driving lamps. They come with the Datsun covers.
    Yes, fog lamps are made for a different lighting pattern than driving lamps. Driving lamps illuminate distance and cannot pierce the fog. Fog lamps illuminate the ground in front of the car and although they do not pierce the fog either, they are great for a wide range of illumination directly in front of the car.
    Enjoy the Ride
    HLS30-00026
    HLS30-00027
    Go Gators
    Go Butler Bulldogs
  23. #23
    Member ID
    CZCC-8596
    Join Date
    Jun 2005
    Location
    Eugene, Oregon, USA
    Age
    64
    Posts
    8,465
    Default
    Quote Originally Posted by 26th-Z View Post
    Chris, the ones you pictured are fogs, not driving. The heavily fluted lenses widen out the beam. Driving light lenses are very mildly patterned, if at all.
    Yours look like Datsun-badged Bosch lights to me.
  24. #24
    Member ID
    CZCC-3193
    Join Date
    Dec 2002
    Location
    JAPAN
    Age
    51
    Posts
    850
    Default
    Hi,
    The OEM fog was manufactured by KOITO,it is about 5.7 X 3.1 inch.
    I attached a picture of installing the fog illustrated in the service bulletin Nov 1969.
    kats
    Katsuhiko Endo
    1970 DATSUN 240Z
    HLS30-02156 (03/70)
    L24-005562
    1970 FAIRLADY Z432
    PS30-00088 (01/70)
    S20-000884
    1972 DATSUN 240Z
    HLS30-60213 (12/71)
    L24-072419
    JAPAN
  25. #25
    Member ID
    CZCC-4148
    Join Date
    May 2003
    Location
    Sarasota, Florida
    Age
    67
    Posts
    3,854
    Default
    Thanks for the picture!
    Enjoy the Ride
    HLS30-00026
    HLS30-00027
    Go Gators
    Go Butler Bulldogs
  26. #26
    Member ID
    CZCC-4106
    Join Date
    May 2003
    Location
    Savannah, Georgia
    Posts
    6,702
    Default
    Yes, Thanks for the scan, te measurements, and the manufacturer confirmation!
    Will
  27. #27
    Supporting Member
    Member ID
    CZCC-12938
    Join Date
    Oct 2006
    Location
    ON
    Posts
    2,232
    Default
    Great information Kats! Can you confirm something for us? In the Nov 1969 Service Bulletin the mounting brackets are pictured. Is that a continuous rubber strip bonded to the bracket acting as vibration isolators?
  28. #28
    Member ID
    CZCC-3193
    Join Date
    Dec 2002
    Location
    JAPAN
    Age
    51
    Posts
    850
    Default excerpt from Parts catalog
    Hi,
    geezer,I am not for sure about bracket,I have never seen it in my hand.But hopefuly I can tell you soon,the original fog lamp set with bracket is coming to my home.I will post its pictures.
    I post two pictures of the fog lamp which is never seen in the U.S. & CANADA catalog.
    The first one is a DEC 1970 RHD DATSUN SPORTS 240Z catalog.The second one is a late 1972 Fairlady-Z catalog.
    kats
ID:	16974   Click image for larger version.
    Katsuhiko Endo
    1970 DATSUN 240Z
    HLS30-02156 (03/70)
    L24-005562
    1970 FAIRLADY Z432
    PS30-00088 (01/70)
    S20-000884
    1972 DATSUN 240Z
    HLS30-60213 (12/71)
    L24-072419
    JAPAN
  29. #29
    Supporting Member
    Member ID
    CZCC-12938
    Join Date
    Oct 2006
    Location
    ON
    Posts
    2,232
    Default
    Thank you Kats for taking the time to post these pictures. Looking forward to seeing pictures of the fog lamp set with brackets.
  30. #30
    Registered User
    Member ID
    CZCC-4680
    Join Date
    Aug 2003
    Location
    Portland, Oregon USA
    Posts
    135
    Default Wiring in the fog light harness; what to do with the ground wire?
    This is an old thread but I'd like to ask about the wires on the fog lights. The harness has two wires for each light, as shown in the diagram. The replica fog lights being made now have one wire, just the "hot lead".
    When installing a replica set, what does one do for the common/ground? Should the "ground wire" in the harness be fastened to the fog light bolt or ?
    Thank you.
  31. #31
    Registered User grannyknot's Avatar
    Member ID
    CZCC-26437
    Join Date
    Feb 2012
    Location
    Toronto
    Posts
    698
    Default
    I don't know the replica fog light kit you speak of but if it only has a hot wire then its mounting bolt is its ground. Attach the harness hot wire to the light and leave the grnd wire hanging, just be sure the mounting bolt is well grounded.
    1970 240Z HLS30 01955 March/70
  32. #32
    1978 280Z (stock) TomoHawk's Avatar
    Member ID
    CZCC-2169
    Join Date
    May 2002
    Location
    NorthCoast, Ohio
    Age
    60
    Posts
    6,497
    Default
    When I mounted my driving lamps, I was able to use the bumper as the earth leg. I checked for a good connection from the bumper to the chassis first. I put an eyelet connector on the ground wire and that went on the attachment bolt under the nut. the 'hot' wire was carefully routed to the cigarette lighter inside (which is temporary until I get a relay setup installed.)
    Drive Responsibly.
    enjoy classic Rock music.
  33. #33
    Registered User mjr45's Avatar
    Member ID
    CZCC-21301
    Join Date
    Mar 2010
    Location
    Divide, CO
    Posts
    572
    Default
    When I put the "El Cheapo" driving lights on my Z, I did as suggested by TomoHawk put a relay into the driving light circuit to put less stress on the overall circuitry of the car.
    75 280Z almost done
    49 Chevy 3100 p/u next project
    96 Dodge 2500 4X4 tows my 5th wheel
  34. #34
    Member ID
    CZCC-2169
    Join Date
    May 2002
    Location
    NorthCoast, Ohio
    Age
    60
    Posts
    6,497
    Default
    Where did you get the power feed for the relay? Not from the wiring, I hope. I mounted a terminal post on the side near the starter, then a heavy wire to the battery feed to the starter. You can get many feeds off the post then.
Name:	Distribution Post Terminal.jpg
    Drive Responsibly.
  35. #35
    Registered User
    Member ID
    CZCC-4680
    Join Date
    Aug 2003
    Location
    Posts
    135
    Default
    Does the original Z wiring which contains the leads for the fog lights come from the dash switch? I have the toggle, with long handle, above the hazard light switch. I like the long toggle for flipping the lights on or off with hand on the wheel.
  36. #36
    Member ID
    CZCC-21301
    Join Date
    Mar 2010
    Location
    Divide, CO
    Posts
    572
    Default
    Tomo, I attached the power feed directly to the battery, was that a bad thing to do?
    75 280Z almost done
  37. #37
    No more body roll! SteveJ's Avatar
    Member ID
    CZCC-5413
    Join Date
    Dec 2003
    Location
    Gainesville, GA
    Age
    54
    Posts
    3,651
    Default
    Not as long as you have an alternator that will keep up.
    73 240Z
    74 260Z
    Blue's collection of tech tips - A great place to look for answers
    XenonS30 -The cheap source for FSMs
    Georgia Z Club
    Fiddling with Z Cars - Z car tips & tricks and pictures of my car-loving life.
    Steve's CARtography - Just car pictures.
  38. #38
    Member ID
    CZCC-2169
    Join Date
    May 2002
    Location
    NorthCoast, Ohio
    Age
    60
    Posts
    6,497
    Default
    That's the way you should do it, basically, just not by splicing into the car's old cruddy wires. I suppose if you use the factory wiring (on a240Z for example) to power lamps the way it was done at the factory, then it ought to work fine. IMO, new wiring should be added to the car in a way to protect the integrity of the factory wiring, while looking like factory wiring.
    Maybe you should dirty up the new wires to make them look like all the rest?
    As I mentioned, I took a wire from the starter battery post to a terminal I mounted in the fender, then I run wires to wherever I need power.
    Like Steve says, the alternator is what really powers things. the battery is just there for power storage between the times the engine is running (to restart the engine.)
    Drive Responsibly.
  39. #39
    Registered User
    Member ID
    CZCC-4680
    Join Date
    Aug 2003
    Location
    Posts
    135
    Default
    I'm thinking the battery is the primary power source; the alternator attempts to keep the battery fully charged, but all the power actually flows from the battery.
    Quote Originally Posted by TomoHawk View Post
  40. #40
    Member ID
    CZCC-5413
    Join Date
    Dec 2003
    Location
    Gainesville, GA
    Age
    54
    Posts
    3,651
    Default
    Quote Originally Posted by Kerrigan View Post
    Think of the battery as a water tower. The water pressure is a function of the height of the water in the tower (This translates to your voltage or potential.). As water flows out of the tower, you have to pump more water into the tower (This is your alternator.). If the pipes are too small from the pump (wiring) or if the pump is undersized, you will have problems.
    The argument of whether the alternator or battery is supplying the power is not really relevant. What matters is sizing the components (battery, alternator, wiring, switches, and fuses) for the demands of the system.
    73 240Z
    74 260Z
    Georgia Z Club
  41. #41
    Registered User rocketdog's Avatar
    Member ID
    CZCC-7592
    Join Date
    Dec 2004
    Location
    sedona, az
    Age
    72
    Posts
    45
    Default
    I put Cibie Series 95 driving lights above the bumper way back in the late 70's when I lived in the boonies of Wyoming. They are halogen.....fairly new lights back then... so I could see the "prairie goats" (antelope). They are wired with a relay direct to the + of the battery but with the switch tied into the high beam switch so they'd only have power if the high beams are on. I put a rocker switch into the dash heater duct trim so they can be on or off with the high beams. The front bumper is the ground so there's only the hot wire to them. The plastic covers got weather-beaten so I've "bondo'd" and patched them and repainted because I cannot find replacements and the car is also a show car now. Everything still works.
    Late 260Z; 2005 Daytona Blue paint; Triple Webers 40DCOE; competition springs w/Tokico HP shocks; Koenig 17x7 Crosshairs w/ Yokohama AVS 215/45 WR 17; Original owner; Show car w/ many awards
  42. #42
    Member ID
    CZCC-2169
    Join Date
    May 2002
    Location
    NorthCoast, Ohio
    Age
    60
    Posts
    6,497
    Default
    Is it OK to wire driving lamps to always turn on with the high beams? I know some people have an extra switch to disable fog or driving lamps, but driving lamps should only go on with the high beams, and it would simplify the wiring.
    Drive Responsibly.
Thread Information
Users Browsing this Thread
Similar Threads
  1. 240z Pre-Wired Driving Lights?
    By Mike in forum Electrical (S30)
    Last Post: 04-05-2013, 01:21 PM
  2. Wiring Fog Lights on the Early Z
    By EScanlon in forum Tech Pubs and HowTo
    Last Post: 01-13-2010, 10:24 AM
  3. Fog Lamp Wiring Part 2
    Last Post: 10-11-2006, 02:10 PM
  4. foglights and the parking light harness upgrade....
    By xray in forum Electrical (S30)
    Last Post: 02-26-2006, 08:39 PM
  5. Does 280Z Have Wiring for Fog Lamps?
    By TomoHawk in forum Electrical (S30)
    Last Post: 02-13-2005, 09:29 AM
Bookmarks
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
