Results 1 to 2 of 2
Thread: timing chain cover install
  1. #1
    Registered User -speed240z's Avatar
    Member ID
    CZCC-14214
    Join Date
    Apr 2007
    Location
    Washington
    Age
    38
    Posts
    24
    Default timing chain cover install
    I plan on putting in a point-less distributer does this require the peice that connects the distributer to the oil pump to be replaced too, if so am I able to replace this peice later without pulling off the timing cover?
    & when I put the timing chain cover on how do I get the seal over the crank shaft gear?
  2. #2
    Furthur GreenZZZ's Avatar
    Member ID
    CZCC-14083
    Join Date
    Mar 2007
    Location
    Austin, TX
    Age
    56
    Posts
    608
    Default
    You have to pull the crank pulley before pulling the timing cover off. You'll need a pulley puller. I did a Mallory distributor and it needed no timing cover work at all for a '72 240. Just pull the old distributor and mount the new one. Easy Easy...
Thread Information
Users Browsing this Thread
Similar Threads
  1. Fresh Motor; Running, but not well.
    By Mpower280z in forum Help Me !!
    Last Post: 02-05-2007, 06:48 PM
  2. Sorry about this, but I just have to ask
    By Hrududu in forum Engine and Drivetrain (S30)
    Last Post: 12-05-2005, 04:50 PM
  3. Timing Chain Installation 75 280
    By andy_5182 in forum Open S30 Z Discussions
    Last Post: 11-04-2005, 09:15 PM
  4. Help with timing cover!
    By RatMonger in forum Help Me !!
    Last Post: 10-12-2005, 11:32 AM
  5. Timing Chain & Gears / Cover Assembly
    By Bambikiller240 in forum Engine and Drivetrain (S30)
    Last Post: 05-24-2003, 01:41 PM
Bookmarks
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
