Results 1 to 7 of 7
Thread: SU Carbs Bogging While Accelerating at Low RPM's
  1. #1
    Registered User Nismo49's Avatar
    Member ID
    CZCC-6916
    Join Date
    Jul 2004
    Location
    Kitchener Ontario (Actually Gowanstown)
    Age
    71
    Posts
    2
    Question SU Carbs Bogging While Accelerating at Low RPM's
    Hey, I have been having some trouble my SU Carbs Bogging out. Help!
    My 1973 240Z with Round Top SU's is bogging out and sometimes stalling on acceleration with low engine RPM's. Pulling the choke on helps to aleviate this condition while accelerating up to highway speed. The engine runs great driving at higher RPMs (ie) 60 - 80 mph....or higher when the road is clear....it runs up to 120 mph...tail wind on nice level highway. When I slow down to make a turn and try to accelerate after making the turn, the engines sputters and boggs untill I pull on the choke and then it will hook up and accelerate smoothly. The engine sometimes back fires, boggs, coughs in this situation.
    The other strange condition is the engine will run reasonable smooth with the choke fully on while at highway speed..one would think that it should run rich and sputter and bogg out..other than stinky exhaust and some smoke, it runs fairly smooth.
    I have installed a new gas line filter, used some carb cleaner and this bogging issue still exists as before. The engine also is hard to accelerate from a standing stop...it quite often stalls when taking off from a stop. Pulling on the choke most often aleviates this problem.
    Another point of interest is that starting cold takes a lot of cranking to get it to fire up. My 240Z is an automatic...I have heard that the jets are different for the Automatics. Holding the accelerator pedal to the floor helps..and the choke fully on....it will take up to a minute of spinning to get the engine to fire the first time. Usually takes another 2-3 times on the starter before the engine will remain running with out stalling. The engine takes about 3-5 minutes to warm up and smooth out at idle.
    Starting hot usually is perfect..it will fire on less than one turn over if the engine has been shut off for up to an hour.
    PS: Previous owner had a complete new OEM SU Carb Kits installed less than 4 years ago. 3000 Miles since carb kits installed.
    I am looking for some advice on where to start making adjustments or service recommendations. Thanks
    Dave
    NISMO49
    1973 240Z - 98% Original Documented California Car
    110 Red - Original Paint
    Automatic Transmission
    42,000 Original Miles
  2. #2
    240Z Elec. Upgrade guy Zs-ondabrain's Avatar
    Member ID
    CZCC-4921
    Join Date
    Sep 2003
    Location
    Marysville, WA. U.S.A.
    Age
    49
    Posts
    4,004
    Default
    Try this link out, it has everything SU related that you EVER want to know.
    http://www.teglerizer.com/sucarbs/index.html
    Dave.
    Rate my Z at Car Domain.com
    My 70' 240Z, Daily Driver
    My Parking Light and Headlight Upgrade Harness's at MotorSport Auto
    HLH - PLH - SCP - ZXP's at MSA *They accept PayPal!!*
    Headlight Upgrade Harness info here at ClassicZCar Club
    HLH info at CZCC Do a search for info on the other upgrades I offer.
  3. #3
    Registered User
    Member ID
    CZCC-14431
    Join Date
    May 2007
    Location
    Hickory, NC
    Age
    74
    Posts
    65
    Default
    David,
    Your symptoms -- running lean, worse at low RPM -- suggest an air leak into the manifold. It's time to start troubleshooting things like the throttle shafts, vacuum advance, brake booster, and BCDD actuator diaphrams.
    Re SU needles -- The 3 screw round tops used on 72's came with N-58 needles in automatics and slightly richer N54's in 4 sp cars. All 4 screw SU's, used in 70 and 71, came with N-27's.
  4. #4
    Registered User
    Member ID
    CZCC-2139
    Join Date
    May 2002
    Location
    Salem Or
    Posts
    1,556
    Default
    David,
    Have you tried adjusting the nozzles down in increments to richen them up?
    Secondly I'd shoot carb cleaner at the throttle shaft openings and all the mounting flanges toward the head to search out any vacuum leaks.
    Our JUST SUs video does a fair country job of walking one through all this....
    Bruce Palmer
    Salem Or
    Sales@ztherapy.com
    www.ztherapy.com
    503-587-9800
  5. #5
    beandip beandip's Avatar
    Member ID
    CZCC-1887
    Join Date
    Mar 2002
    Location
    Beaverton, Oregon
    Age
    81
    Posts
    4,038
    Default
    What wt oil are you using in the dampeners. To thin of oil can cause the engine to stumble at first throttle opening at low rpm. Try some 10w30 and better yet 20wt available at the local cycle shop. ( fork oil) Cold start up. Depressing the throttle actually has vary little effect when starting the engine . Actually if the mixture is set correctly , just adding choke should be all that is necessary. As Bruce stated, sounds like a lean condition also. Check the vacuum advance also. Gary
    I'd rather die while I am living than live while I am dieing. CZC 1887 IZCC 12602 Member of NorthWest Z Car Club
  6. #6
    Member ID
    CZCC-6916
    Join Date
    Jul 2004
    Location
    Age
    71
    Posts
    2
    Default
    Hi Dave,
    I checked out the website and found many references that will be helpful. From what I have read so far...Ihave a lean condition or an air leak as others have mentioned. Really appreciate your references. Thanks
    Dave
  7. #7
    Member ID
    CZCC-6916
    Join Date
    Jul 2004
    Location
    Age
    71
    Posts
    2
    Default SU Lean Condition
    Hi Guys,
    I think that the previous owner told that he was using ATF in the dampers. The article that I read from Dave's website resource suggested 20W-50 for worn carbs as a third choice after ATF and 10w-30. I have some 20W-50 oil on hand ...will change it out and try that first before I get into changing the settings. Its about trial and error and learning....I have little experience in setting SU carbs.
    Thank You to everyone that responded..really appreciate the sugestions and recommendations. Will keep eveyone posted on my progress.
    Dave
    Nismo49
    Quote Originally Posted by beandip View Post
Thread Information
Users Browsing this Thread
Similar Threads
  1. Simple answer requested - tuning SU carbs
    By Brandy in forum SU Carb Discussions
    Last Post: 08-07-2007, 08:57 PM
  2. SU Carbs different and not running good
    By neoxman in forum SU Carb Discussions
    Last Post: 09-29-2006, 05:28 PM
  3. SU carbs with metal oil filler caps?
    By zcarnut in forum Carburetors (S30)
    Last Post: 07-11-2006, 02:48 PM
  4. Leaking SU carbs
    By seerex in forum Carburetors (S30)
    Last Post: 10-22-2003, 10:45 PM
  5. SU carbs and high revs
    By 240ZMan in forum Carburetors (S30)
    Last Post: 10-06-2003, 07:29 AM
Bookmarks
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
