Results 1 to 10 of 10
Thread: My rear disc conversion
  1. #1
    Registered User Noddle's Avatar
    Member ID
    CZCC-12467
    Join Date
    Aug 2006
    Location
    Tasmania
    Posts
    495
    Default My rear disc conversion
    Hi all,
    I've been slowly getting the bits I need for my rear disc conversion,
    I had my brackets made (laser cut), and I threaded them,
    also I had my brother spin down the "tab" to make a 4mm offset to centre the caliper to the disc,
    as you can see they fit pretty good (on my spare 240k).
    also here's a link to my web site with more pictures
    http://noddle.110mb.com/Rear%20Disc%...ion/index.html
    Nigel
    Attached Thumbnails Attached Thumbnails Click image for larger version.
ID:	22869   Click image for larger version.
ID:	22870   Click image for larger version.
ID:	22871   Click image for larger version.
ID:	22872   Click image for larger version.
ID:	22874   Click image for larger version.
  2. #2
    www.project240k.com khughes's Avatar
    Member ID
    CZCC-6769
    Join Date
    Jun 2004
    Location
    Australia
    Age
    40
    Posts
    1,191
    Default
    looking good, great work!
    how close did your calipers end up being compared to the set i have?
    Kent
    07/74 Datsun 240K GL Hardtop KHGC110 - #5497 (longest 240k project in history?)
    1970 Datsun 240Z HS30 #212
    www.project240k.com - project details on all my cars
  3. #3
    Member ID
    CZCC-12467
    Join Date
    Aug 2006
    Location
    Tasmania
    Posts
    495
    Default
    Hi,
    I used "240K&Beyond" original CAD drawing,
    from this thread http://www.classiczcars.com/forums/s...t=bracket+240K
    it was a one piece bracket, there is no one around where I live, that could do a C&C bracket for me, (cheap enough anyway)
    all I did was "hack" it so it was in two pieces,
    it cost me $37 to get the two sides made (4 pieces)
    and all I have to do is bolt the two half's together, the engineering place offered to weld them, but I preferred to bolt them as I saw it would be easier to get them passed by a engineer .
    I'm sure if anyone wants the original CAD drawing, 240K&Beyond, would be happy to give you a copy
    Nigel
  4. #4
    Member ID
    CZCC-12467
    Join Date
    Aug 2006
    Location
    Tasmania
    Posts
    495
    Default
    This is the CAD drawing for my bracket, it was based on 240K&Beyond original CAD drawing.
    Attached Files Attached Files
  5. #5
    V8 convertible 240kconvertible's Avatar
    Member ID
    CZCC-9623
    Join Date
    Oct 2005
    Location
    Brisbane
    Age
    40
    Posts
    510
    Default
    Looking good Nigel, how much better does it brake with the rear discs on it? is it very noticible
  6. #6
    Member ID
    CZCC-12467
    Join Date
    Aug 2006
    Location
    Tasmania
    Posts
    495
    Default
    I haven't finished it yet,
    I have been busy doing other stuff, and now with the weather getting worse (cold and wet) and getting darker sooner (don't forget I live in Tassie), I haven't got back to it yet,
    also you may have noticed, I have about 3 other jobs on, on my 240K
    If you check out my web site, I put a lot of picture up on it.
    Nigel
  7. #7
    Member ID
    CZCC-9623
    Join Date
    Oct 2005
    Location
    Brisbane
    Age
    40
    Posts
    510
    Default
    Just checked your site out,
    Turbo upgrade! wicked
    You've done really well Noodle, I'm impressed
  8. #8
    Member ID
    CZCC-12467
    Join Date
    Aug 2006
    Location
    Tasmania
    Posts
    495
    Default
    Quote Originally Posted by 240kconvertible View Post
    Thanks you,
    and I added some more stuff to my site, all I need to do, is to finish my projects ..
    Nigel
  9. #9
    Member ID
    CZCC-9623
    Join Date
    Oct 2005
    Location
    Brisbane
    Age
    40
    Posts
    510
    Default
    Quote Originally Posted by Noddle View Post
    Thanks you,
    Nigel
    Don't we all need to finish our projects, 2012 guys lets all try and make it there.
  10. #10
    Registered User matt240K's Avatar
    Member ID
    CZCC-11461
    Join Date
    May 2006
    Location
    Tallebudgera (Gold Coast)
    Age
    51
    Posts
    53
    Default
    I have a set of ventilated rotors and mounting brackets to convert to disk brake rear end if anyone wants them. (free) They have no calipers at the moment. This is not the best setup in the world, for a number of reasons.
    the rotors were Chrysler Centura 6Cly fronts. (rare as rocking horse poo these days, so hard to replace, but there's an Audi one which you can use) they've been turned down in diametre by about 10MM (this allows them to fit inside the standard 14"steel rim)
    they use Commodore VB front calipers. This means you have no handbrake unless you use a hydraulic one. you can buy VB calipers from wreckers for about $50.
    The mounting brackets are something I made myself. hmmm.....smacks of quality doesn't it? . but they work fine. I used this setup on my rally car for about 6 years. they were fine.
    the reason I changed them was that the calipers sat on the top. In rally use the dust used to sit on the caliper and cause it to get really hot. you also had to take that caliper off to bleed the brakes, not that that's a big drama. So I figured since I no longer had 14" rims, I might just as well build new brakes that fit the caliper at the back. other than that the brakes on my car are the same as these.
    I'm chucking them over the tip if I still have them next weekend, but if anyone thinks they might have a use for them, please let me know.
    Matt.
Thread Information
Users Browsing this Thread
Similar Threads
  1. 240z rear disc conversion
    By red_dog007 in forum Wheels, Tires and Brakes (S30)
    Last Post: 04-07-2009, 02:22 PM
  2. Rear Disc Brake Conversion
    By Tommo560 in forum Australia and New Zealand
    Last Post: 03-12-2007, 03:21 AM
  3. Rear Disc Conversion
    By Mike in forum Open Modification Discussions
    Last Post: 12-21-2005, 07:39 AM
  4. rear disc conversion - how to remove backing plate?
    By 2003z in forum Suspension and Steering (S30)
    Last Post: 06-22-2005, 08:01 AM
Bookmarks
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
