Results 1 to 9 of 9
Thread: How to Install New Electrical Harness Firewall Grommet?
  1. #1
    Registered User Oiluj's Avatar
    Member ID
    CZCC-15388
    Join Date
    Nov 2007
    Location
    SF Bay Area
    Age
    66
    Posts
    1,746
    Default How to Install New Electrical Harness Firewall Grommet?
    I'm ready to re-install my engine bay wiring harness. It's that last major item I need to do in the engine bay prior to engine installation.
    I got a new main harness grommet, but how do I get it onto the harness?
    The grommet is not that elastic and from both ends, there are fairly large plugs that have to go through it.
    I'm not sure how to proceed and don't want to damage anything trying to force things. Last time I split it and glued it back together, but I know that's not the "right" way...
    Will post some progress pics of the car in the next few days after the harness is installed.
    Thanks in advance for your help!
    Julio
    1972 240Z (in-progress, 95% complete)
    CZC# 15388
  2. #2
    Supporting Member
    Member ID
    CZCC-12938
    Join Date
    Oct 2006
    Location
    ON
    Posts
    2,232
    Default
    You will need to carefully remove those connectors, pass the wires through the grommet and then replace the connectors. You will require the use of a tool similar to one of these, in order to release the small lock tabs which hold the wire terminals in the connectors. Any good automotive supply store should carry the proper tools.
  3. #3
    Registered User
    Member ID
    CZCC-27230
    Join Date
    May 2012
    Location
    United States
    Age
    36
    Posts
    4
    Firewall connections are easy to pop out and in, and switches plug in quickly. Almost anyone can do it. You should use proper tools..
    _________________________________________
    For more info: electrical grommets | tire stem caps
  4. #4
    Registered User
    Member ID
    CZCC-18523
    Join Date
    Jan 2009
    Location
    Texas
    Posts
    25
    Default
    I just went through this on a 260Z. The old grommet was shot, but not split all the way through. I used a tool from Lisle - 56500 purchased at the local O'Reilly auto supply. I numbered the plastic connector with a sharpie, labeled the wires to match with strips of masking tape, then wrapped the loose wires tight with masking tape and wrote the color of the connector on that tape. I then took some harness tape (the thin stuff with no glue) and wrapped the wires tight like the rest of the harness. I then slid the grommet on as far as I could, when it got tight, I pulled it to turn it inside out to make it easier to feed the wires, then sprayed the harness with some 409 soap to help the grommet slide along. Once I had it close to where it needed to be, I soaped it again and turned the grommet right-side-out. Then it was a matter of unwrapping the wires and re-installing in the plastic connectors. The most important part was having the correct tool for removing the connector pins.
    Good luck with yours, just take your time and it will come out great!
  5. #5
    Nova Scotia,Canada,Earth Blue's Avatar
    Member ID
    CZCC-7641
    Join Date
    Jan 2005
    Location
    NS
    Posts
    4,085
    Default
    Or if you are in a rush.
    Slit the grommet with a razor, install on harness, then use an appropriate glue to repair the grommet.
    3M most likely have a product.... maybe even the black weatherstripping adhesive will do the job nicely.
    There is scarcely anything in the world that some man cannot make a little worse, and sell a little more cheaply.
    The person who buys on price alone is this man's lawful prey.
    John Ruskin (1819 - 1900)
    ZCars in Eastern Canada seaport ready for shipment to Europe
    http://ZSportCanada.com
  6. #6
    Registered User madkaw's Avatar
    Member ID
    CZCC-7622
    Join Date
    Dec 2004
    Location
    bloomington IN
    Age
    58
    Posts
    2,288
    Default
    "The grommet is not that elastic and from both ends, there are fairly large plugs that have to go through it. "
    You'd be suprised!
    I did it WITHOUT removong any connectors. Prepare for a battle on some of the connectors and grease things up so they slide easier, but they will go.
    Steve
    71 240z,bw-5sp 2.4-40 over,balanced,e-88,big valves,ported&polished, stage2,header, triple Mikuni's 40's
    3.90 Subaru STI LSD
  7. #7
    Registered User ZCurves's Avatar
    Member ID
    CZCC-7312
    Join Date
    Nov 2004
    Location
    Spring, Texas USA
    Age
    56
    Posts
    1,052
    Default
    Quote Originally Posted by domsmith View Post
    Take the plugs loose from the underside of the dash pull through to engine side. Lube up the connectors with some silicone "Tire Shine" oil and slowly squeeze them through the grommet. Clean with Circuit Cleaner, plug back into receptacle under the dash. While you are at it, replace all of your fuses and clean your fuse box - you will be right there anyway.....
    Andrew (ZCurves)
    1978 Coupe - HLS30-440105
    Spring, Texas USA
    pro deo et patria
    My Albumz
  8. #8
    Member ID
    CZCC-7641
    Join Date
    Jan 2005
    Location
    NS
    Posts
    4,085
    Default
    Put the grommet in boiling water to soften it.
  9. #9
    Brian
    Member ID
    CZCC-20911
    Join Date
    Feb 2010
    Location
    Richmond VA
    Age
    42
    Posts
    243
    Default
    I also did it without removing wires from plugs on a 71.
Thread Information
Users Browsing this Thread
Similar Threads
  1. Replies: 3
    Last Post: 11-11-2006, 06:05 PM
  2. Firewall heater grommet
    By RIP260Z in forum Help Me !!
    Last Post: 07-20-2006, 05:59 AM
  3. Needed, firewall grommet
    By Ed in forum Help Me !!
    Last Post: 03-04-2005, 08:22 AM
  4. FW rubber grommet for engine harness
    By EricB in forum Electrical (S30)
    Last Post: 07-02-2004, 06:16 AM
  5. Wiper harness grommet
    By Victor Laury in forum Open Discussions
    Last Post: 01-15-2003, 11:57 AM
Bookmarks
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
