Results 1 to 14 of 14
Thread: A/C compressor won't switch on
  1. #1
    280Z go zoom! efhjr's Avatar
    Member ID
    CZCC-3540
    Join Date
    Feb 2003
    Location
    San Antonio, TX
    Age
    54
    Posts
    17
    Question A/C compressor won't switch on
    My air conditioner only blows hot air. Contol panel is set to AC, but no cold air -- and I don't hear the compressor kick in.
    The car's air conditioner control panel was replaced about a year ago (apparently it was the last OEM unit left in the US). There are no blown fuses.
    Today I had the cooling system checked out by professionals and it passed all tests -- freon pressure is good, and the compressor comes on when given power from battery.
    Any ideas?
    1977 280Z Coupe. 129,000 miles. Balanced motor, some go-fast parts.
  2. #2
    Registered User
    Member ID
    CZCC-7867
    Join Date
    Feb 2005
    Location
    Phoenix, Arizona
    Age
    62
    Posts
    208
    Default
    I'm not an AC guy and I don't know if these systems have a valve/switch that keeps the clutch from engaging if the freon is low. I see you had the freon level checked but if it has this valve/switch and it's bad, it might prevent the voltage from reaching the clutch.
    The clutch clicks on and off when you applied voltage from the battery but it doesn't when you turn the switch from inside the car. Start at the compressor and work your way back towards the switch inside the car trying to find out where the voltage is going.
    Test the fuse with an ohm meter or replace the fuse, don't assume it's good. Do this first!
    The "professionals" that inspected the car for you should have given you some suggestions on what to check.
    Good luck with your car.
    BD
    HLS30-004880
  3. #3
    Member ID
    CZCC-3540
    Join Date
    Feb 2003
    Location
    San Antonio, TX
    Age
    54
    Posts
    17
    Default
    Quote Originally Posted by BD240Z View Post
    They're a good shop. They just didn't know what to do with a car that's 32 years old, and were honest enough to tell me.
    Thanks for the suggestions. I'll double-check and/or replace fuses next.
  4. #4
    Registered User zcarnut's Avatar
    Member ID
    CZCC-11468
    Join Date
    May 2006
    Posts
    90
    Default
    It is the AC relay (located on the small AC bracket with also holds the vacuum switches and the check valve) that energizes the compressor clutch through its switch contacts. The AC relay coil, in turn, has three switches in series with it: the under pressure switch (located on the receiver/drier); the ON micro-switch (energized by the AC control lever on the console); and the thermostat switch (located behind the temperature control lever). In addition the blower switch is also part of the circuit since the blower fan must be on while the AC is running (to prevent excessive pressures in the AC system). So, there are several items that must be checked to verify the series circuit is complete.
    Check the easiest-to-get-to items first: The AC relay and the under pressure switch. The AC relay can be checked for both switch continuity and whether or not the coil has voltage across it. If it is suspected then it can be substituted with a good working one. The AC relay can be taken apart to inspect the contacts for pitting (very common since you are switching an inductive load) and the contact points can be cleaned with a points file.
    The under pressure switch is screwed into the top of the receiver/drier. It can be tested with an ohmmeter after it is unplugged or you can short it out with a jumper wire to check it. The under pressure switch is available separately from Nissan, but it requires you to discharge the AC system first before replacing it.
    The micro-switch and thermostat switch can be tested after you remove the control panel on the located between the console and the dash. Again, use a jumper wire or an ohmmeter to check them. I’m not sure about the availability of NOS parts as I have never seen these parts become defective (fortunately). Since your blower fan switch seems to be working (based on your post) I would assume that your blower switch is OK.
    BTW, all of this info is in the factory service manual. I urge you to obtain one and do the troubleshooting yourself. You learn a lot more from doing than asking.
    Attached Thumbnails Attached Thumbnails Click image for larger version.
    Steve Golik
    Huntsville, AL
    1970 240Z
    1974 260Z
    1979 810 Hardtop
    2008 G37S
    "35 years of Z car ownership"
  5. #5
    Yellow Z-Car Club DougN's Avatar
    Member ID
    CZCC-8920
    Join Date
    Jul 2005
    Location
    Atlanta, GA
    Age
    56
    Posts
    681
    Default
    Also make sure your top control lever is set to "off" not "vent", as you will not get any cold air if you are pulling in outside air from the vent.
    Doug
    '73 240Z (HLS30-126840)(10/72) Yellow (64XXX original miles)
    '66 MGB (GHN3L108501)(12/14/66) BRG
    '10 BMW E93 Silver
  6. #6
    Member ID
    CZCC-3540
    Join Date
    Feb 2003
    Location
    San Antonio, TX
    Age
    54
    Posts
    17
    Default
    Thanks for all the good tips and info, gents.
    I'll hit the books and get under the hood this weekend.
  7. #7
    Member ID
    CZCC-3540
    Join Date
    Feb 2003
    Location
    San Antonio, TX
    Age
    54
    Posts
    17
    Default
    With the car off and the leads disconnected, I put my multimeter on the under pressure switch and it failed a continuity test. So there's my problem.
    Now to find a new one and start saving for a few cans of R12!
  8. #8
    Member ID
    CZCC-3540
    Join Date
    Feb 2003
    Location
    San Antonio, TX
    Age
    54
    Posts
    17
    Default
    Uh-oh. Just paid a visit to my local Nissan stealership, and they told me that part is no longer unavailable.
  9. #9
    Member ID
    CZCC-11468
    Join Date
    May 2006
    Posts
    90
    Default
    Quote Originally Posted by efhjr View Post
    Use the 27648-U8710 low pressure switch. Cost is $10.21. The electrical connector is different (you will have to cut and splice in your old one) but it is available through Courtesy Nissan: www.courtesyparts.com
    Steve Golik
    Huntsville, AL
    1970 240Z
    1974 260Z
    1979 810 Hardtop
    2008 G37S
  10. #10
    Member ID
    CZCC-3540
    Join Date
    Feb 2003
    Location
    San Antonio, TX
    Age
    54
    Posts
    17
    Default
    Thanks for that info and link, Steve.
    My car's A/C was rebuilt a few years back and is still using R12. Is there any good reason to have it converted to R134?
    I ask because this will come up when I have the system recharged when the pressure switch is replaced.
  11. #11
    Z geek at large FastWoman's Avatar
    Member ID
    CZCC-19635
    Join Date
    Jul 2009
    Location
    Hampton Roads, VA
    Posts
    2,787
    Default
    The R134a operates at much higher head pressures and often doesn't get along well with existing hoses, coils, and configurations. I've had two cars retrofitted to use existing coils and hoses. The budget retrofit (Fred's no-name in an old Cadillac) blew up. The expensive manufacturer retrofit (Saturn) works fine but leaks. I've also put a complete Vintage Air 134a system in a Mustang, and of course it works great. However, that didn't involve a combination of old R12 parts and new R134a parts. I'd stick with R12 as long as feasible, as long as it works.
  12. #12
    Member ID
    CZCC-3540
    Join Date
    Feb 2003
    Location
    San Antonio, TX
    Age
    54
    Posts
    17
    Default
    "Blew up" is about all I need to hear, FastWoman. I think I'll stick with the R12.
    I'll ask the shop if they'll fill it with Freeze 12, maybe that'll save me a few dollars.
  13. #13
    Former frequent poster sblake01's Avatar
    Member ID
    CZCC-3797
    Join Date
    Mar 2003
    Location
    San Bernardino, Ca. U.S.A.
    Age
    70
    Posts
    10,574
    Default
    I can vouch for Freeze 12 as I used it in both my air conditioned Datsuns for years with no problems. It's much less costly than R12, requires less refrigerant and runs at a lower high side pressure than R12. I'm a licensed HVAC/MVAC tech and have tested a few R12 replacements/alternatives such as R414B (Hotshot), Red Tek 12, Freeze 12, Autofrost as well as R134a. You'll hear pros and cons for Freeze 12 as you would with any R12 alternative. IMO, for Freeze 12, the pros outweigh the cons.
    2004 Ford Ranger EDGE Supercab
    (@Moonpup: This one really is an EDGE!)
    2005 Pontaic GTO
    2010 Mercedes Benz C300 AMG Sportline (Wife's car)
    2014 Kia Rio LX (Wife's daily driver)
    Certified HVAC/MVAC Technician
  14. #14
    Member ID
    CZCC-3540
    Join Date
    Feb 2003
    Location
    San Antonio, TX
    Age
    54
    Posts
    17
    Default
    I just had the car in for a checkup at the shop that rebuilt the A/C. They determined that there's an electrical problem -- the low pressure switch isn't coming on because it's not getting the juice it needs.
    So somewhere in that car is a wire, connector, and/or harness that's shot. I imagine it's somewhere under the dash. Pity I can't just buy a new dash harness and install it.
Thread Information
Users Browsing this Thread
Similar Threads
  1. Replies: 0
    Last Post: 02-03-2009, 02:06 PM
  2. Fog Lamp Wiring Part 2
    By EScanlon in forum Tech Pubs and HowTo
    Last Post: 10-11-2006, 02:10 PM
  3. foglights and the parking light harness upgrade....
    By xray in forum Electrical (S30)
    Last Post: 02-26-2006, 08:39 PM
  4. Steering column jacket and headlight switch
    By oldroaddog in forum Electrical (S30)
    Last Post: 09-30-2005, 05:50 PM
  5. 72 240Z Brake Light Wiring
    By 72SLOZ in forum Tech Pubs and HowTo
    Last Post: 07-02-2005, 03:35 PM
Tags for this Thread
Bookmarks
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
