Results 1 to 11 of 11
Thread: Loud vibrating-type noise on decel
  1. #1
    Registered User 81 ZXT's Avatar
    Member ID
    CZCC-18629
    Join Date
    Jan 2009
    Location
    Oklahoma
    Age
    59
    Posts
    51
    Default Loud vibrating-type noise on decel
    81 280ZX w/A/T - I drive about 22 miles to work. In the first 5 or 6 miles when i decelerate I get a loud noise. At first I thought it was something loose in the exhaust but now I am wondering if it could be u-joints or something. After I drive it more than 6 miles the noise is gone. Could something be warming up and only makes noise when cold? It sounds kinda like a semi useing jake brakes. Any suggestions?
  2. #2
    Registered User five&dime's Avatar
    Member ID
    CZCC-16082
    Join Date
    Feb 2008
    Location
    Richmond, VA
    Age
    41
    Posts
    860
    Default
    I would also assume U-joints but not if it goes away after 6 miles. Odd.
  3. #3
    Registered User MikeW's Avatar
    Member ID
    CZCC-3294
    Join Date
    Dec 2002
    Location
    Atlanta, GA, USA
    Posts
    2,739
    Default
    I would try to isolate the problem some more. You say it only happens on deceleration. Is it when you take your foot off the gas, manually downshift, or brake? Is it a single loud clunk or a continuous sound? Can you reproduce it in each forward gear?
    -Mike
    Add your Z to my online spreadsheet registry
  4. #4
    Member ID
    CZCC-18629
    Join Date
    Jan 2009
    Location
    Oklahoma
    Age
    59
    Posts
    51
    Default
    Thanks for replying guys. 280ZX with Automatice Transmission. It happens when I take my foot of the gas. It sounds a lot like a guard on the exhaust is rattling. It is not a clunk, its more of a brdddddddddd. I am still not ruling out exhaust due to the fact that it disappears after full warmup. Just wondered if a u-joint can make that kind of a sound.
  5. #5
    Registered User 280zx@541's Avatar
    Member ID
    CZCC-19581
    Join Date
    Jun 2009
    Location
    Central Point, Oregon
    Age
    35
    Posts
    6
    Default
    Mine does a similar sound sure if it's the same exact noise but mines the cadilistic converder, I'm going to just get a full on straight exhaust.
  6. #6
    Member ID
    CZCC-18629
    Join Date
    Jan 2009
    Location
    Oklahoma
    Age
    59
    Posts
    51
    Default
    Last night I jacked it up and tightened every bolt and clamp I could find. Nothing was very loose. Test drove and no improvement. It is for sure speed related and is really loud decelerating right at 2900rpm. It vibrates at other speeds but 2900 is the majic number.
  7. #7
    Former frequent poster sblake01's Avatar
    Member ID
    CZCC-3797
    Join Date
    Mar 2003
    Location
    San Bernardino, Ca. U.S.A.
    Age
    70
    Posts
    10,574
    Default
    Take a rubber mallet and tap on the catalytic converter. If you hear rattling inside, the 'honeycomb' has become britle and fallen apart and that's where the noise is comming from. If that's the case, not only do you need to replace the cat but the muffler also because particles/pieces from that damaged cat will get lodged in the muffler.
    2004 Ford Ranger EDGE Supercab
    (@Moonpup: This one really is an EDGE!)
    2005 Pontaic GTO
    2010 Mercedes Benz C300 AMG Sportline (Wife's car)
    2014 Kia Rio LX (Wife's daily driver)
    Certified HVAC/MVAC Technician
  8. #8
    Member ID
    CZCC-18629
    Join Date
    Jan 2009
    Location
    Oklahoma
    Age
    59
    Posts
    51
    Default
    I will try that. That would make a lot of sense because the car sat for 4 years and now I have been driving it regularly. Brand new muffler, less than 2 months old.
  9. #9
    Member ID
    CZCC-18629
    Join Date
    Jan 2009
    Location
    Oklahoma
    Age
    59
    Posts
    51
    Default
    Not catalytic converter. The noise has gotten now to the point that it does it at lower speeds. Makes it a little easier to diagnose. I believe it is drivetrain related. At low speeds (less than 20 mph) it sounds like a guard hitting the u-joint of the driveshaft and is worse while turning right. Still only makes noise on decel. It might make some noise while accelerating but is worse when decelerating. I was going to look at it last night but we had storms on Wednesday and I had to clean up some downed trees and such. Maybe tonight.
  10. #10
    Member ID
    CZCC-18629
    Join Date
    Jan 2009
    Location
    Oklahoma
    Age
    59
    Posts
    51
    Default
    Figured it out. There is a heat sheild between the C. converter and the driveshaft. One of the weights on the driveshaft was hitting the guard. When I tightened the guard it only moved it closer to the driveshaft. Some creative bending and no more noise.
  11. #11
    Member ID
    CZCC-16082
    Join Date
    Feb 2008
    Location
    Richmond, VA
    Age
    41
    Posts
    860
    Default
    Hooray!!! Nothing better than an easy fix to an annoying rattle!!!
Thread Information
Users Browsing this Thread
Similar Threads
  1. Loud Clunking Noise Upon Putting In Reverse
    By chaddy1984 in forum Help Me !!
    Last Post: 02-19-2008, 02:39 PM
  2. LOUD ringing noise from inside . .
    By New-to-240z in forum Electrical (S30)
    Last Post: 04-25-2007, 08:54 PM
  3. Loud Vibrating sound in rear! What's the deal?
    By Hrududu in forum Help Me !!
    Last Post: 10-31-2005, 08:15 AM
  4. fuel pump making loud ticking noise
    By TTDRIVER in forum Engine and Drivetrain (S30)
    Last Post: 11-04-2003, 06:23 AM
  5. Replies: 11
    Last Post: 02-12-2003, 05:20 AM
Bookmarks
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
