Results 1 to 8 of 8
Thread: Car sat too long
  1. #1
    Supporting Member Zedyone_kenobi's Avatar
    Member ID
    CZCC-16285
    Join Date
    Mar 2008
    Location
    Houston
    Age
    47
    Posts
    2,919
    Default Car sat too long
    I recently took my Z out to a local car get together this weekend just to kick the dust off. Well it has been about 3 months since I drove my old gal, and I wanted to see if the Tension rod bushings made any difference, and just let her move some gas through the carbs.
    WHen driving down the road, with the windows down I heard what sounded like a SHT, SHT, SHT, coming from what I think is the drivers rear. I thought perhaps I may have let it sit too long with the emergency brake on. So I figured I would just get her up to about 40 and wait for a safe distance and lock up the brakes to see if maybe something was rubbing. Believe it or not, that seemed to help. But when I drove home, I heard it again, more faint, but definitely there. It may be ebrake related, or just perhaps, I froze up a wheel cylinder. I have not had the drums off since I bought the car, so I need to figure out whats what. Perhaps I am down to the wear bars on the drums.
    Any advice? I have another tire wheel question, but I will post it in another thread.
    1971 240Z HLS30-38691
    93.9% done and getting better every day
    Now with 100% more DATSUN SPIRIT L28 Power
    1968 Datsun 2000 SRL311-03416
  2. #2
    Registered User doradox's Avatar
    Member ID
    CZCC-14809
    Join Date
    Aug 2007
    Location
    Colfax, IN
    Posts
    708
    Default
    Might be a slight film of rust on the drum. If so it should wear off after a few stops and stop making the noise.
    Steve
  3. #3
    Registered User 70 Cam Guy's Avatar
    Member ID
    CZCC-18904
    Join Date
    Mar 2009
    Location
    Walnut Creek, CA
    Age
    40
    Posts
    567
    Default
    I agree, could be rust on the drum or the rotors. My car made a similar noise, like a brake sensor rubbing the rotor without the squeal. After a few drives, the noise has gone away. Still, if you've never removed the drums, it might be a good idea to inspect your brake shoes and hardware.
    -Andy
    1973 HLS30-166105
    RB20DET swap, HKS GT2530 turbo, HKS Actuator, Hallman MBC, ebay intake manifold, ebay dump pipe, straight pipe, 14 psi boost
  4. #4
    Parts Hero WingZr0's Avatar
    Member ID
    CZCC-13541
    Join Date
    Dec 2006
    Location
    Racerville California
    Age
    40
    Posts
    1,871
    Default
    Just got my brakes ordered from Les Schab tires ( a big chain on the west coast anyway), turns out all I need is front calipers and I got the last the last set in the company. Thye got 1 drivers side and 2 right sides ! Anyhow the dude who works there used a hubcap puller to get the aluminum drum off the drivers side and slightly bent the "backing plate", I guess it's called, and when I drove off I heard just what you were talking about and turned around to have them see what it was. First thing that came to mind was your description as the sound came on around 15 to 20 miles then died off around 50 and up only because it was going so fast. Pried it back into shape with the hubcap puller in a hot secound and off I went good as new. If you ain't found the source this might be what your hearing ^_^ Let us know if you found what ever it is. ~Z~
    Speeding is fun,
    As long as you out run,
    The cops! ! !
    ~Z~ Seek Truth
    ウイングゼロ 競争 GangLoadOParts.com
  5. #5
    Registered User
    Member ID
    CZCC-18571
    Join Date
    Jan 2009
    Location
    Houston, Texas USA
    Posts
    85
    Default
    It says SHT - Go Faster!
    It says SHT - Go More!!
    It says SHT - Go beat that 260!!!
  6. #6
    Member ID
    CZCC-16285
    Join Date
    Mar 2008
    Location
    Houston
    Age
    47
    Posts
    2,919
    Default
    Kirk, you are a harsh man! hahaha
  7. #7
    Registered User
    Member ID
    CZCC-4044
    Join Date
    Apr 2003
    Location
    Denver
    Posts
    1,008
    Default
    2nd on the backing plate.
    You will probably see some shiny aluminum where the backing plate was rubbing the brake drum.
    things will only bother you if you let them.
    82 280zxt 4 spd auto
    73 240z--lsd, cv axles
    short throw info
  8. #8
    Member ID
    CZCC-16285
    Join Date
    Mar 2008
    Location
    Houston
    Age
    47
    Posts
    2,919
    Default
    UPDATE: Well guys, pulled the drums off and to my surprise there was nothing. Zippo. Every looked good, shoes still looked serviceable with decent life in them. Took it for a drive and nothing. Quiet as a mouse. Well a mouse with an ANSA on it. The car braked as straight as it always did. I think I just may have had a slight stiction or build up from letting the car sit too long. THE problem is gone.
Thread Information
Users Browsing this Thread
Similar Threads
  1. 240Z/260Z/280Z auto to 4/5 speed swap
    By Arne in forum Tech Pubs and HowTo
    Last Post: 08-29-2008, 04:05 PM
  2. Japanese Classic Car Show
    By Victor Laury in forum United States
    Last Post: 07-13-2006, 02:40 PM
  3. The first Z pace car
    By HS30-H in forum Open Racing Discussions
    Last Post: 06-15-2005, 08:10 AM
  4. Carbs Sat to long?
    By Xargon321 in forum Carburetors (S30)
    Last Post: 08-12-2003, 04:11 PM
Bookmarks
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
