The T/C kit also comes with a boot that covers and ball and socket (which is greased up) to prevent comtamination. The tension is set with the included sheetmetal gauge. The T/C kit keeps your suspension under braking more stabile. Also the ball and socket has less suspension bind that OEM.
The offset LCA bushings should be set my your alignment guy.
Bookmarks
