Results 1 to 5 of 5
Thread: Camber Bushing Kit Questions
  1. #1
    Registered User JohnnyO's Avatar
    Member ID
    CZCC-17819
    Join Date
    Sep 2008
    Location
    Hudson, WI
    Posts
    935
    Default Camber Bushing Kit Questions
    Reposting this with a different title because I wasn't getting any hits.
    I am rebuilding my front end this weekend and during dismantling I came across a suspension upgrade the PO had installed. After searching here I found this thread:
    http://www.classiczcars.com/forums/s...ad.php?t=25877
    It describes my lower control arm bushings but doesn't talk about my T/C arm bushings. You can see in the picture the parts in question. From what I read in the above thread the control arm bushings are worth keeping to help with camber adjustment. As for the T/C bushings, I was planning on going stock with the rubber replacements for these.
    My questions are as follows:
    I did not make note of the offset on the control arm bushings when I removed them from the crossmember. How do I set them initially during install and how do I adjust them once the car is on the ground? Do I loosen the nuts and give them a 1/6th turn on each side until I get the camber correct?
    I am assuming the large Hex part of the bushing goes towards the firewall based on the fact that standard bushings have the offset towards the rear. Is this a correct assumption?
    The Tension Control Arm bushings look cool but I want to get back to stock where visible. Do these really offer that great of an improvement over stock?
    Pictures below.
    Thanks in advance,
    John
    Attached Thumbnails Attached Thumbnails Click image for larger version.
Name:	DSCF0224 (Large).JPG
ID:	34757   Click image for larger version.
Name:	DSCF0225 (Large).JPG
ID:	34758   Click image for larger version.
Name:	DSCF0226 (Large).JPG
  2. #2
    Registered User Curtis240Z's Avatar
    Member ID
    CZCC-4128
    Join Date
    May 2003
    Location
    Hawaii
    Posts
    539
    Default
    The T/C kit also comes with a boot that covers and ball and socket (which is greased up) to prevent comtamination. The tension is set with the included sheetmetal gauge. The T/C kit keeps your suspension under braking more stabile. Also the ball and socket has less suspension bind that OEM.
    The offset LCA bushings should be set my your alignment guy.
  3. #3
    Member ID
    CZCC-17819
    Join Date
    Sep 2008
    Location
    Hudson, WI
    Posts
    935
    Default
    Curtis, I was hoping you would reply. Yes, I do have the boots for both sides, they just need to be cleaned up. Because I want a stock look I am going to install rubber t/c bushings and put this one on the shelf for the next car.
    I mounted the LCA bushings today in relatively the same position in respect to each other. I will have my alignment guy tweak it for me.
    Was I correct in my description on the installation of the LCA bushing? I have them mounted now but have not bolted the suspension to the car yet.
    Thanks,
    John
    P.S. Glad to hear Hawaii came out OK today with the weather scare. Take care.
  4. #4
    Member ID
    CZCC-4128
    Join Date
    May 2003
    Location
    Hawaii
    Posts
    539
    Default
    Yes the hex nut section is toward the rear. Be careful installing it in the crossmember because the tolerance is tight and forcing it in shaves the nylon bushing material (not desireable).
  5. #5
    Member ID
    CZCC-17819
    Join Date
    Sep 2008
    Location
    Hudson, WI
    Posts
    935
    Default
    I greased up both ends and tapped the control arm lightly and evenly until it sat in position. No damage done.
    Thanks for the help.
    John
Thread Information
Users Browsing this Thread
Similar Threads
  1. Interpart Suspension Upgrade Kit Help Please
    By JohnnyO in forum Suspension and Steering (S30)
    Last Post: 03-08-2010, 12:55 AM
  2. REAR Transverse link OEM INNER Bushing alignment questions
    By PATZ in forum Suspension and Steering (S30)
    Last Post: 03-18-2009, 08:53 PM
  3. Camber Bushing kit - front
    By Doehring in forum Suspension and Steering (S30)
    Last Post: 04-29-2007, 12:08 PM
  4. HYPERFLEX Major Polyurethane Bushing Kit - Datsun 240Z
    By bemmerguy714 in forum Suspension and Steering (S30)
    Last Post: 08-18-2005, 08:32 AM
  5. TC rod aftermarket bushing kit question
    By EricB in forum Suspension and Steering (S30)
    Last Post: 05-30-2002, 09:42 AM
Bookmarks
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
